Ok colin,
So i edited my function node like this :
and i put all debug node in my entry and you can show this :
EDIT : I just find a node (node-red-contrib match) and it's work, If is right go on top, if is fasle go on bottom.
But i've new problem now, i've a problem when i start my flow, my join node take directly one value so, i need to push, long to make an error and reset the join node, and push short and my dashboard button to make the rules. and my vidéo start. so i don't understand why.
Ok guys,
So, i found the solution this is my new flow with the match node :
I needed to change the join flow to this, i changed key/value to string :
And my match node :
So, all is work, just now, i've a problem with message sending, like my preview post, when i start my flow, the value long is directly send, so my join node wait only one other value and not 2, so how to remove the first value at start ?
Hi everybody,
Sorry for the repost a ne message again but i found the solution !
I use the node séquence detector it is perfect for me. node-red-contrib-sequence-detector (node) - Node-RED.
This is my flow :
Is not really clean but it's work.
and my node sequence detector very easy :
So it's much easier to use this node that join node for me.
Thanks for all guys !
