Create a PDF with Node-Red and JSON
Hello everyone
I want to generate a pdf-file in Node-Red and use "node-red-contrib-pdfmake".
With the inject node I enter a json "content". Now my question, how do I create a layout in this file and can I add more text that is not in json format?
Below how I do this.
In addition, I cannot open the pfd file as long as node-red is running. What could be the reason for this?
Thanks for your help. Kind regards Mauri
Hi & welcome to the forum.
Yes. Check out the built in example (CTRL-I --> examples --> PDFMAKE)
Also, search the forum (there was a PDFMAKE thread only this week that will give you clues on how to generate sections)
Because using a fixed file name keeps the file open (for later additions)
In simple terms, dont specify a fixed file name, instead, pass the filename in via msg.filename as is explained in the file node built in help.
Have a look at this thread and the link to some examples.
Thanks for your fast answers!
Can you link the thread please? I can't find it
:point_up_2: Look up :point_up_2:
:wink:
Try this entry in particular from that thread
It demonstrates a few techniques - in particular adding text dynamically to the PDF document definition
:man_facepalming:t5: :see_no_evil:
Thanks a lot! :pray:t5:
