Create html from csv using just few columns
i'd like to create a HTML page using the data coming from csv. Some data come to "header", some should go as a table data.
I manged to visualize a complete csv using the tabliefy and template node. But can't a way to parse first a csv and then use a JSON object I get to create a table using a template node.
csv is like this:
Data Modello Cod. Risultato Descrizione risultato Peaks Thickness Att Gain CatNo CenterPeacks Result SpotID TestID
18/12/2018 09:01 M161 0 Buono 2 3,39 3,25 38 WP0806 Q+ 0 1 12061 7799
18/12/2018 09:01 M161 0 Buono 2 3,33 2,52 35 WP0807 Q+ 0 1 12062 7799
18/12/2018 09:01 M161 0 Buono 2 3,28 4 35 WP0808 Q+ 0 1 12063 7799
and i need to get the Data and Modello to the header, I used the flow variable to get them from csv. After that i create a JSON object for the rest of the field i need. But can't find a way how to put these data into html template.
here is my flow:
[{"id":"7c2582a1.e3912c","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"6722c10c.732b48","type":"inject","z":"7c2582a1.e3912c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["db01ad75.187108"]]},{"id":"db01ad75.187108","type":"file in","z":"7c2582a1.e3912c","name":"","filename":"/home/ros_test/ADDSRL-PC_T1_07-10-2019.csv","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":440,"y":120,"wires":[["f8e61f6d.6b99f"]]},{"id":"f8e61f6d.6b99f","type":"csv","z":"7c2582a1.e3912c","name":"","sep":"\\t","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":730,"y":120,"wires":[["d5bcd946.d1ae2"]]},{"id":"d5bcd946.d1ae2","type":"function","z":"7c2582a1.e3912c","name":"","func":"var data = msg.payload;\nvar jsonObj = {};\nflow.set('date',data[0].Data);\nflow.set('modello',data[0].Modello);\nfor (let index = 0; index < 5; index++) {\n jsonObj.CodRes = data[index][\"Cod. Risultato\"];\n jsonObj.Peaks = data[index].Peaks;\n jsonObj.DesrRes = data[index][\"Descrizione risultato\"];\n jsonObj.thickness = data[index].Thickness;\n jsonObj.att = data[index].Att;\n jsonObj.gain = data[index].Gain;\n jsonObj.catNo = data[index].CatNo;\n jsonObj.centPeak = data[index].CenterPeacks;\n jsonObj.result = data[index].Result;\n jsonObj.spotID = data[index].SpotID;\n jsonObj.testID = data[index].TestID;\n console.log(\"element = \" + JSON.stringify(jsonObj))\n \n}\nmsg.payload = jsonObj;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":880,"y":120,"wires":[["cfb273d7.f1fe88"]]},{"id":"cfb273d7.f1fe88","type":"template","z":"7c2582a1.e3912c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n <meta charset=\"UTF-8\">\n <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n <title>TEST</title>\n <style>\n body {\n font-family: Arial, Helvetica, sans-serif;\n }\n table, tr {\n border:1px solid black;\n}\n\n </style>\n</head>\n<body>\n <h1>Welding Quality data</h1>\n\n<table style=\"width:100%\">\n \n <tr>\n <td>Operatore: </td>\n <td> Primary Account</td>\n <td>Modello: </td>\n <td>{{flow.\"modello\"}} </td>\n <td>Disegno: </td>\n <td> </td>\n <td>Provati: </td>\n <td>60/60</td> \n </tr>\n \n \n \n <tr>\n <td>Data: </td>\n <td> {{flow.\"date\"}} </td>\n \n </tr>\n </table>\n \n \n </body>\n</html>\n<table style=\"width:100%\">\n <tr>\n <td {{{msg.payload}}}</td>\n </tr>\n </table> ","output":"str","x":1060,"y":120,"wires":[["dae4e870.dc5e3"]]},{"id":"dae4e870.dc5e3","type":"ui_template","z":"7c2582a1.e3912c","group":"8b5cde76.edd58","name":"template table","order":1,"width":"12","height":"18","format":"\n<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":1260,"y":120,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"30bf4544.04a522","order":1,"disp":true,"width":"12","collapse":false},{"id":"30bf4544.04a522","type":"ui_tab","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]Processing: ADDSRL-PC_T1_07-10-2019 - Copy.csv...
ADDSRL-PC_T1_07-10-2019.txt (944 Bytes)
Without the original csv data its impossible to replicate this.
Can you upload image the file ?
(rename your .csv to .txt so the forum will allow you to post it)
i've uploaded the example, but the extension is txt, hope this is enaught.
i can see another problem in my script. The JSON object at the end contain only last elaborated line. Can't figure out why.
here is an example the cod.in the header row gives issues so i added new names in csv node to remove the .
the template is an example and you will have to finish it
[{"id":"55fa8af6.3485a4","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":230,"y":4880,"wires":[["6c47b762.622d38"]]},{"id":"6c47b762.622d38","type":"template","z":"b779de97.b1b46","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"plain","template":"Data\tModello\tCod. Risultato\tDescrizione risultato\tPeaks\tThickness\tAtt\tGain\tCatNo\tCenterPeacks\tResult\tSpotID\tTestID\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t2\t3,39\t3,25\t38\tWP0806 Q+\t0\t1\t12061\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t2\t3,33\t2,52\t35\tWP0807 Q+\t0\t1\t12062\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t2\t3,28\t4\t35\tWP0808 Q+\t0\t1\t12063\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t3\t2,95\t2,33\t32\tWP0809 Q+\t0\t1\t12064\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t2\t3,42\t3,45\t32\tWP0810 Q+\t0\t1\t12065\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t1\tBruciato\t1\t5,56\t-1\t35\tWP0811 Q+\t0\t2\t12066\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t3\tSottile\t2\t3,63\t3,3\t37\tWP0812 Q+\t0\t2\t12067\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t3\t2,08\t3,07\t37\tWP0509\t0\t1\t12060\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t3\t2,25\t2,09\t37\tWP0508\t0\t1\t12143\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t0\tBuono\t3\t2,22\t3,22\t37\tWP0505\t0\t1\t12140\t7799\t\t\t\t\n18/12/2018 09:01\tM161\t10\tDifetto Interno\t1\t5,18\t-1\t41\tWP0813 Q+\t1\t2\t12068\t7799\t","output":"str","x":420,"y":4880,"wires":[["989f5825.95fcf8"]]},{"id":"989f5825.95fcf8","type":"csv","z":"b779de97.b1b46","name":"","sep":"\\t","hdrin":false,"hdrout":"none","multi":"mult","ret":"\\n","temp":"Data,Modello,Cod Risultato,Descrizione risultato,Peaks,Thickness,Att,Gain,CatNo,CenterPeacks,Result,SpotID,TestID","skip":"1","strings":true,"include_empty_strings":"","include_null_values":"","x":580,"y":4880,"wires":[["de94863c.2eb88","f0fd38fb.47a258"]]},{"id":"de94863c.2eb88","type":"debug","z":"b779de97.b1b46","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":610,"y":4980,"wires":[]},{"id":"f0fd38fb.47a258","type":"template","z":"b779de97.b1b46","name":"","field":"template","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n <meta charset=\"UTF-8\">\n <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n <title>TEST</title>\n <style>\n body {\n font-family: Arial, Helvetica, sans-serif;\n }\n table, tr {\n border:1px solid black;\n}\n\n </style>\n</head>\n<body>\n <h1>Welding Quality data</h1>\n\n<table style=\"width:100%\">\n \n <tr>\n <td>Operatore: </td>\n <td> Primary Account</td>\n <td>Modello: </td>\n <td>{{payload.0.Modello}} </td>\n <td>Disegno: </td>\n <td> </td>\n <td>Provati: </td>\n <td>60/60</td> \n </tr>\n \n \n \n <tr>\n <td>Data: </td>\n <td> {{payload.0.Data}} </td>\n \n </tr>\n </table>\n \n \n\n\n \n \n<table style=\"width:100%\">\n</tr>\n<tr><td>cod Risultato</td><td>Descrizione</td><td>Peaks</td><td>Thickness</td></tr>\n {{#payload}}\n<tr> \n    <td>{{Cod Risultato}}</td>\n    <td>{{Descrizione risultato}}</td>\n    <td>{{Peaks}}</td>\n    <td>{{Thickness}}</td>\n</tr>\n{{/payload}}\n </table>\n </body>\n</html>","output":"str","x":760,"y":4880,"wires":[["b11f0796.41ddb"]]},{"id":"b11f0796.41ddb","type":"ui_template","z":"b779de97.b1b46","group":"8b5cde76.edd58","name":"template table","order":1,"width":"12","height":"18","format":"","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":960,"y":4880,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
[edit] set first two to header table and removed first two columns.
you dont need the function node .. the data is just fine from the csv node.
also no need for template but you do need the ui_template
and with the magic of angular's ng-repeat you can loop through the data
Flow:
[{"id":"6722c10c.732b48","type":"inject","z":"7c2582a1.e3912c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":120,"wires":[["db01ad75.187108"]]},{"id":"db01ad75.187108","type":"file in","z":"7c2582a1.e3912c","name":"","filename":"/home/ros_test/ADDSRL-PC_T1_07-10-2019.csv","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":410,"y":120,"wires":[["f8e61f6d.6b99f"]]},{"id":"f8e61f6d.6b99f","type":"csv","z":"7c2582a1.e3912c","name":"","sep":"\\t","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":690,"y":120,"wires":[["e61c9653146c08de","dae4e870.dc5e3"]]},{"id":"dae4e870.dc5e3","type":"ui_template","z":"7c2582a1.e3912c","group":"8b5cde76.edd58","name":"template table","order":1,"width":"23","height":"18","format":"<!DOCTYPE html>\n<html lang=\"en\">\n\n<head>\n    <meta charset=\"UTF-8\">\n    <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n    <title>TEST</title>\n    <style>\n        body {\n            font-family: Arial, Helvetica, sans-serif;\n        }\n\n        .content-table {\n            border-collapse: collapse;\n            margin: 25px 0;\n            font-size: 0.9em;\n            min-width: 400px;\n            border-radius: 5px 5px 0 0;\n            overflow: hidden;\n            box-shadow: 0 0 20px rgba(0, 0, 0, 0.15);\n        }\n\n        .content-table thead tr {\n            background-color: #009879;\n            color: #ffffff;\n            text-align: left;\n            font-weight: bold;\n        }\n\n        .content-table th,\n        .content-table td {\n            padding: 12px 15px;\n        }\n\n        .content-table tbody tr {\n            border-bottom: 1px solid #dddddd;\n        }\n\n        .content-table tbody tr:nth-of-type(even) {\n            background-color: #f3f3f3;\n        }\n\n        .content-table tbody tr:last-of-type {\n            border-bottom: 2px solid #009879;\n        }\n\n        .content-table tbody tr.active-row {\n            font-weight: bold;\n            color: #009879;\n        }\n    </style>\n</head>\n\n<body>\n    <h1>Welding Quality data</h1>\n\n    <table class=\"content-table\" style=\"width:100%\">\n\n        <thead>\n            <tr>\n                <th>Data</th>\n                <th>Modello</th>\n                <th>Cod. Risultato</th>\n                <th>Descrizione risultato</th>\n                <th>Peaks</th>\n                <th>Thickness</th>\n                <th>Att</th>\n                <th>Gain</th>\n                <th>CatNo</th>\n                <th>CenterPeacks</th>\n                <th>Result</th>\n                <th>SpotID</th>\n                <th>TestID</th>\n            </tr>\n        </thead>\n\n\n        <tbody>\n            <tr ng-repeat=\"row in msg.payload\">\n                <th>{{row.Data}}</td>\n                <td>{{row.Modello}}</td>\n                <td>{{row[\"Cod. Risultato\"]}}</td>\n                <td>{{row[\"Descrizione risultato\"]}}</td>\n                <td>{{row.Peaks}}</td>\n                <td>{{row.Thickness}}</td>\n                <td>{{row.Att}}</td>\n                <td>{{row.Gain}}</td>\n                <td>{{row.CatNo}}</td>\n                <td>{{row.CenterPeacks}}</td>\n                <td>{{row.Result}}</td>\n                <td>{{row.SpotID}}</td>\n                <td>{{row.TestID}}</td>\n            </tr>\n        </tbody>\n\n\n    </table>\n\n\n</body>\n\n</html>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":880,"y":120,"wires":[[]]},{"id":"e61c9653146c08de","type":"debug","z":"7c2582a1.e3912c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":800,"y":60,"wires":[]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"30bf4544.04a522","order":1,"disp":true,"width":"24","collapse":false,"className":""},{"id":"30bf4544.04a522","type":"ui_tab","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]
css styling from dcode
well, this is cool, but i need the first two columns to be out of the table, they are part of the header, thats why i used the function node trying to parse the csv. is there any way to do it?
i see .. those two columns seem to be repeated in every array element so simply picking from the first will do
<h1>Welding Quality data - {{ msg.payload[0].Data }} - {{msg.payload[0].Modello}}</h1>
Example:
[{"id":"dae4e870.dc5e3","type":"ui_template","z":"7c2582a1.e3912c","group":"8b5cde76.edd58","name":"template table","order":1,"width":"23","height":"18","format":"<!DOCTYPE html>\n<html lang=\"en\">\n\n<head>\n    <meta charset=\"UTF-8\">\n    <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n    <title>TEST</title>\n    <style>\n        body {\n            font-family: Arial, Helvetica, sans-serif;\n        }\n\n        .content-table {\n            border-collapse: collapse;\n            margin: 25px 0;\n            font-size: 0.9em;\n            min-width: 400px;\n            border-radius: 5px 5px 0 0;\n            overflow: hidden;\n            box-shadow: 0 0 20px rgba(0, 0, 0, 0.15);\n        }\n\n        .content-table thead tr {\n            background-color: #009879;\n            color: #ffffff;\n            text-align: left;\n            font-weight: bold;\n        }\n\n        .content-table th,\n        .content-table td {\n            padding: 12px 15px;\n        }\n\n        .content-table tbody tr {\n            border-bottom: 1px solid #dddddd;\n        }\n\n        .content-table tbody tr:nth-of-type(even) {\n            background-color: #f3f3f3;\n        }\n\n        .content-table tbody tr:last-of-type {\n            border-bottom: 2px solid #009879;\n        }\n\n        .content-table tbody tr.active-row {\n            font-weight: bold;\n            color: #009879;\n        }\n    </style>\n</head>\n\n<body>\n    <h1>Welding Quality data - {{ msg.payload[0].Data }} - {{msg.payload[0].Modello}}</h1>\n\n    <table class=\"content-table\" style=\"width:100%\">\n\n        <thead>\n            <tr>\n                <th>Cod. Risultato</th>\n                <th>Descrizione risultato</th>\n                <th>Peaks</th>\n                <th>Thickness</th>\n                <th>Att</th>\n                <th>Gain</th>\n                <th>CatNo</th>\n                <th>CenterPeacks</th>\n                <th>Result</th>\n                <th>SpotID</th>\n                <th>TestID</th>\n            </tr>\n        </thead>\n\n\n        <tbody>\n            <tr ng-repeat=\"row in msg.payload\">\n                <td>{{row[\"Cod. Risultato\"]}}</td>\n                <td>{{row[\"Descrizione risultato\"]}}</td>\n                <td>{{row.Peaks}}</td>\n                <td>{{row.Thickness}}</td>\n                <td>{{row.Att}}</td>\n                <td>{{row.Gain}}</td>\n                <td>{{row.CatNo}}</td>\n                <td>{{row.CenterPeacks}}</td>\n                <td>{{row.Result}}</td>\n                <td>{{row.SpotID}}</td>\n                <td>{{row.TestID}}</td>\n            </tr>\n        </tbody>\n\n\n    </table>\n\n\n</body>\n\n</html>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":880,"y":120,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"30bf4544.04a522","order":1,"disp":true,"width":"24","collapse":false,"className":""},{"id":"30bf4544.04a522","type":"ui_tab","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]
thanks a lot! your suggestion is working perfectly. Another question then, i do need to get the .html file out from html template node. i need to send it to another component to visualize as is. Looks like it pass throgh only array of JSON objects with the data and not the html structure though. i use the "file" node to store it, but get the
You can use JS template literals and javascript forEach to replicate what Angular does in the ui_template
[{"id":"6722c10c.732b48","type":"inject","z":"7c2582a1.e3912c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":120,"wires":[["db01ad75.187108"]]},{"id":"db01ad75.187108","type":"file in","z":"7c2582a1.e3912c","name":"","filename":"c:/share/ADDSRL-PC_T1_07-10-2019.csv","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":420,"y":120,"wires":[["f8e61f6d.6b99f"]]},{"id":"f8e61f6d.6b99f","type":"csv","z":"7c2582a1.e3912c","name":"","sep":"\\t","hdrin":true,"hdrout":"none","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":690,"y":120,"wires":[["e61c9653146c08de","dae4e870.dc5e3","75a23ba2cd405a73"]]},{"id":"dae4e870.dc5e3","type":"ui_template","z":"7c2582a1.e3912c","group":"8b5cde76.edd58","name":"template table","order":1,"width":"23","height":"18","format":"<!DOCTYPE html>\n<html lang=\"en\">\n\n<head>\n    <meta charset=\"UTF-8\">\n    <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n    <title>TEST</title>\n    <style>\n        body {\n            font-family: Arial, Helvetica, sans-serif;\n        }\n\n        .content-table {\n            border-collapse: collapse;\n            margin: 25px 0;\n            font-size: 0.9em;\n            min-width: 400px;\n            border-radius: 5px 5px 0 0;\n            overflow: hidden;\n            box-shadow: 0 0 20px rgba(0, 0, 0, 0.15);\n        }\n\n        .content-table thead tr {\n            background-color: #009879;\n            color: #ffffff;\n            text-align: left;\n            font-weight: bold;\n        }\n\n        .content-table th,\n        .content-table td {\n            padding: 12px 15px;\n        }\n\n        .content-table tbody tr {\n            border-bottom: 1px solid #dddddd;\n        }\n\n        .content-table tbody tr:nth-of-type(even) {\n            background-color: #f3f3f3;\n        }\n\n        .content-table tbody tr:last-of-type {\n            border-bottom: 2px solid #009879;\n        }\n\n        .content-table tbody tr.active-row {\n            font-weight: bold;\n            color: #009879;\n        }\n    </style>\n</head>\n\n<body>\n    <h1>Welding Quality data - {{ msg.payload[0].Data }} - {{msg.payload[0].Modello}}</h1>\n\n    <table class=\"content-table\" style=\"width:100%\">\n\n        <thead>\n            <tr>\n                <th>Cod. Risultato</th>\n                <th>Descrizione risultato</th>\n                <th>Peaks</th>\n                <th>Thickness</th>\n                <th>Att</th>\n                <th>Gain</th>\n                <th>CatNo</th>\n                <th>CenterPeacks</th>\n                <th>Result</th>\n                <th>SpotID</th>\n                <th>TestID</th>\n            </tr>\n        </thead>\n\n\n        <tbody>\n            <tr ng-repeat=\"row in msg.payload\">\n                <td>{{row[\"Cod. Risultato\"]}}</td>\n                <td>{{row[\"Descrizione risultato\"]}}</td>\n                <td>{{row.Peaks}}</td>\n                <td>{{row.Thickness}}</td>\n                <td>{{row.Att}}</td>\n                <td>{{row.Gain}}</td>\n                <td>{{row.CatNo}}</td>\n                <td>{{row.CenterPeacks}}</td>\n                <td>{{row.Result}}</td>\n                <td>{{row.SpotID}}</td>\n                <td>{{row.TestID}}</td>\n            </tr>\n        </tbody>\n\n\n    </table>\n\n\n</body>\n\n</html>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":960,"y":120,"wires":[[]]},{"id":"e61c9653146c08de","type":"debug","z":"7c2582a1.e3912c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":800,"y":60,"wires":[]},{"id":"75a23ba2cd405a73","type":"function","z":"7c2582a1.e3912c","name":"create html","func":"\nlet html = `<!DOCTYPE html>\n<html lang=\"en\">\n\n<head>\n    <meta charset=\"UTF-8\">\n    <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n    <title>${msg.payload[0].Modello} - ${ msg.payload[0].Data }</title>\n    <style>\n        body {\n            font-family: Arial, Helvetica, sans-serif;\n        }\n\n        .content-table {\n            border-collapse: collapse;\n            margin: 25px 0;\n            font-size: 0.9em;\n            min-width: 400px;\n            border-radius: 5px 5px 0 0;\n            overflow: hidden;\n            box-shadow: 0 0 20px rgba(0, 0, 0, 0.15);\n        }\n\n        .content-table thead tr {\n            background-color: #009879;\n            color: #ffffff;\n            text-align: left;\n            font-weight: bold;\n        }\n\n        .content-table th,\n        .content-table td {\n            padding: 12px 15px;\n        }\n\n        .content-table tbody tr {\n            border-bottom: 1px solid #dddddd;\n        }\n\n        .content-table tbody tr:nth-of-type(even) {\n            background-color: #f3f3f3;\n        }\n\n        .content-table tbody tr:last-of-type {\n            border-bottom: 2px solid #009879;\n        }\n\n        .content-table tbody tr.active-row {\n            font-weight: bold;\n            color: #009879;\n        }\n    </style>\n</head>\n\n<body>\n    <h1>Welding Quality data - ${ msg.payload[0].Data } - ${msg.payload[0].Modello}</h1>\n\n    <table class=\"content-table\" style=\"width:100%\">\n\n        <thead>\n            <tr>\n                <th>Cod. Risultato</th>\n                <th>Descrizione risultato</th>\n                <th>Peaks</th>\n                <th>Thickness</th>\n                <th>Att</th>\n                <th>Gain</th>\n                <th>CatNo</th>\n                <th>CenterPeacks</th>\n                <th>Result</th>\n                <th>SpotID</th>\n                <th>TestID</th>\n            </tr>\n        </thead>\n\n        <tbody>`\n\nlet rows = \"\"\n\nmsg.payload.forEach(el => {\n    rows += `\n<tr>\n    <td>${el[\"Cod. Risultato\"]}</td>\n    <td>${el[\"Descrizione risultato\"]}</td>\n    <td>${el.Peaks}</td>\n    <td>${el.Thickness}</td>\n    <td>${el.Att}</td>\n    <td>${el.Gain}</td>\n    <td>${el.CatNo}</td>\n    <td>${el.CenterPeacks}</td>\n    <td>${el.Result}</td>\n    <td>${el.SpotID}</td>\n    <td>${el.TestID}</td>\n</tr>` })\n\n\nhtml = html + rows + `</tbody>\n    </table>\n</body>\n</html>`\n\nmsg.payload = html\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":790,"y":280,"wires":[["f04eef7c3fcdb5c8"]]},{"id":"f04eef7c3fcdb5c8","type":"file","z":"7c2582a1.e3912c","name":"","filename":"c:\\share\\table.html","appendNewline":false,"createDir":false,"overwriteFile":"true","encoding":"none","x":990,"y":280,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"30bf4544.04a522","order":1,"disp":true,"width":"24","collapse":false,"className":""},{"id":"30bf4544.04a522","type":"ui_tab","name":"Home1","icon":"dashboard","disabled":false,"hidden":false}]
ps. Change the paths in the file nodes to match for your system
this is exactly what i was looking for! Thanks a lot!
