Creating a Chart from MSQL-Database
Hi folks,
i hope you can help me.
I collect data in a mysql database.
When i read out data, the payload is in that format:
 array[99]
  [0 … 9]
     0: object
         date: "2024-02-10T23:00:00.000Z
         max_power: 0.52
    1: object
    2: object
    3: object
    4: object
    5: object
    6: object
    7: object
    8: object
    9: object
  [10 … 19]
  [20 … 29]
  [30 … 39]
  [40 … 49]
  [50 … 59]
  [60 … 69]
  [70 … 79]
  [80 … 89]
  [90 … 99]
I want to create a chart that displays the date on the x-axis and max_power on the y-axis.
What function or node do i need, to transform the data in a format that can be used by a chart node?
I read a lot about about that issue i this forum and others, but i did not get the conclusion.
Thanks for your help.
Greetings
Thomas
I use MS SQL but the output of the connection node is the same.
I Work with the function node and use the following code (translate with your variables)
var data=[];
var series= ["max_power"];
var labels = [];
var labelX= "";
var labelY= "";
msg.payload.forEach(function(value) {
    data.push(value["max_power"]);
    labels.push(value['date']);
data=[data];
msg.payload=[{series,data,labels}];
msg.ui_control = {
    options:{
        scales:{
            yAxes: [{
                scaleLabel:{
                    display:true,
                    labelString: "Max Power"
            xAxes: [{
                //type: 'time',
                scaleLabel: {
                    display: true,
                    labelString: "Date"
This work fine with chart in Dashboard 1.0.
Regards
Hi, welcome to the forum.
Here is an existing working demo
Some notes on your posting.
How to copy data from node-red debug for posting on forum
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
How to post data/flows to the forum so that is is both readable and useable
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil: icon.
Note that the two examples above are for the original dashboard node-red-dashboard.
There is a newer dashboard @flowfuse/node-red-dashboard.
If that's the version you installed you'll need to search the forum for dashboard-2 examples from within the last year. The ones above won't work.
If you are using @flowforge-dashboad (Dashboard 2) then you do not need to format the sql return. Except I believe the timestamp has to be unix millisecond timestamp, which of course you can have the sql request return. Chart ui-chart | Node-RED Dashboard 2.0
If you are still using the Angular node-red-dashboad then you have to use the format for data here. You can also have the sql query return the data in the [{"x":1234567891234", "y": 24.6}] format using AS key word syntax.
There is an example of SQL database (not specifically MSSQL) to Dashboard v1 chart here
Just emphasising this - use Dashboard 2.0 - the original Dashboard is now deprecated.
It'll save you have to do any data transforms at all, as you can just use "Key Mapping" options on the ui-chart:
No need to modify your date structure, that should just work as you have it.
Hallo Raffaele, you were right, it worked perfectly on Dashboard 1.0.Thanks
Dear Steve, thanks for your recommendations on posting into the forum.
