Hello! I’m trying to create an entry form where
- I select a value in “work center” field which is fetched from a CSV file
- After selecting, applies a filter on the same CSV file to show the rows with selected work center and shows it in a table node.
- Then feeding the filtered order no. in "Order no" field and selecting it
- After filling all fields and clicking submit button, all the selected fields are stored in another CSV file which then shown in another table as an entry confirmation.
Can anyone help or direct me to a solution.
Below is the flow:
[{"id":"87ac3b01.909018","type":"tab","label":"Breakdown","disabled":false,"info":""},{"id":"e642510e.a315f","type":"ui_text","z":"87ac3b01.909018","group":"f9e41b13.1fe7a8","order":1,"width":6,"height":1,"name":"","label":"Posting Date :","format":"{{myymd}}","layout":"row-left","x":820,"y":160,"wires":[]},{"id":"aeae155f.451868","type":"simpletime","z":"87ac3b01.909018","name":"","mydate":true,"myymd":true,"myyear":true,"mymonth":true,"mymonthn":true,"mydom":true,"mydoy":true,"myday":true,"myhourpm":true,"myhour":true,"mytime":true,"mytimes":true,"myminute":true,"myminutes":true,"mysecond":true,"mymillis":true,"myepoch":true,"myrawdate":true,"mypm":true,"x":630,"y":160,"wires":[["e642510e.a315f"]]},{"id":"1096e6ce.85eff9","type":"inject","z":"87ac3b01.909018","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":460,"y":160,"wires":[["aeae155f.451868"]]},{"id":"2ddf0d85.ea1dc2","type":"ui_dropdown","z":"87ac3b01.909018","name":"","label":"Shift","tooltip":"","place":"Select shift","group":"f9e41b13.1fe7a8","order":10,"width":3,"height":1,"passthru":true,"multiple":false,"options":[{"label":"A","value":"A","type":"str"},{"label":"B","value":"B","type":"str"}],"payload":"","topic":"topic","topicType":"msg","x":410,"y":540,"wires":[[]]},{"id":"1635f63b.70501a","type":"inject","z":"87ac3b01.909018","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":440,"y":320,"wires":[["b3f182dc.95637"]]},{"id":"b3f182dc.95637","type":"file in","z":"87ac3b01.909018","name":"","filename":"C:\\Users\\Sahil\\Desktop\\testing\\mt02order.csv","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":710,"y":320,"wires":[["22f4750f.3db1ca"]]},{"id":"22f4750f.3db1ca","type":"csv","z":"87ac3b01.909018","name":"","sep":",","hdrin":true,"hdrout":"all","multi":"mult","ret":"\\r\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":950,"y":320,"wires":[["f2a68631.770ad8","264cd440.e8690c","ea66fdd4.ce5d5"]]},{"id":"c8e65eb3.fedd7","type":"debug","z":"87ac3b01.909018","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1510,"y":280,"wires":[]},{"id":"f2a68631.770ad8","type":"function","z":"87ac3b01.909018","name":"transform data","func":"//as per info panel, the data needs to be formatted\n//as [ \"Choice 1\", \"Choice 2\", {\"Choice 3\":\"3\"} ]\n//and sent in msg.options.\nmsg.options = [];//create empty array\nfor(let i = 0; i < msg.payload.length; i++){\n let row = msg.payload[i]; //get the row\n let opt = {};//make new opt object\n opt[row.Work_Center] = row.Work_Center; \n msg.options.push(opt);//add the opt to array \n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1140,"y":320,"wires":[["f4ed0b9d.66aef8"]]},{"id":"f4ed0b9d.66aef8","type":"ui_dropdown","z":"87ac3b01.909018","name":"","label":"Work center","tooltip":"","place":"Select Machine","group":"f9e41b13.1fe7a8","order":3,"width":6,"height":1,"passthru":false,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"machinecode","topicType":"msg","x":1330,"y":320,"wires":[["c8e65eb3.fedd7","3832c97b.fd3ba6","1c233064.2dd4b"]]},{"id":"264cd440.e8690c","type":"function","z":"87ac3b01.909018","name":"Make lookup","func":"var data = msg.payload;\nvar map = {};\nfor (let index = 0; index < data.length; index++) {\n const element = data[index];\n map[element.Work_Center] = element.Order_No;\n}\nmsg.payload = map;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1130,"y":360,"wires":[["2cfb19fd.8863d6","a9532548.208828"]]},{"id":"2cfb19fd.8863d6","type":"debug","z":"87ac3b01.909018","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1330,"y":420,"wires":[]},{"id":"a9532548.208828","type":"change","z":"87ac3b01.909018","name":"","rules":[{"t":"set","p":"partLookup","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1350,"y":380,"wires":[[]]},{"id":"3832c97b.fd3ba6","type":"change","z":"87ac3b01.909018","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"partLookup[msg.payload]","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1520,"y":320,"wires":[["494e47b1.167818","d3a6f345.e0e35","d39c6c93.158dd"]]},{"id":"494e47b1.167818","type":"debug","z":"87ac3b01.909018","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"msg","x":1710,"y":320,"wires":[]},{"id":"d3a6f345.e0e35","type":"ui_dropdown","z":"87ac3b01.909018","name":"","label":"Order No.","tooltip":"","place":"Select","group":"f9e41b13.1fe7a8","order":4,"width":6,"height":1,"passthru":false,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"machinecode","topicType":"msg","x":1720,"y":360,"wires":[[]]},{"id":"d39c6c93.158dd","type":"ui_text","z":"87ac3b01.909018","group":"f9e41b13.1fe7a8","order":5,"width":4,"height":1,"name":"","label":"Order No.","format":"{{msg.payload}}","layout":"row-spread","x":1720,"y":400,"wires":[]},{"id":"ea66fdd4.ce5d5","type":"ui_table","z":"87ac3b01.909018","group":"f9e41b13.1fe7a8","name":"","order":7,"width":28,"height":3,"columns":[],"outputs":0,"cts":false,"x":1110,"y":280,"wires":[]},{"id":"f24d7e50.20701","type":"ui_text_input","z":"87ac3b01.909018","name":"Start Time","label":"Start Time","tooltip":"Start Time","group":"f9e41b13.1fe7a8","order":12,"width":3,"height":1,"passthru":false,"mode":"time","delay":300,"topic":"Start Time","topicType":"str","x":920,"y":540,"wires":[["d0bf4f47.05a94"]]},{"id":"d7e88a39.a6de98","type":"ui_date_picker","z":"87ac3b01.909018","name":"","label":"Start date","group":"f9e41b13.1fe7a8","order":11,"width":5,"height":1,"passthru":false,"topic":"Start date","topicType":"str","x":580,"y":540,"wires":[["b1955da5.c99f6"]]},{"id":"a169e909.f6b518","type":"ui_date_picker","z":"87ac3b01.909018","name":"","label":"End date","group":"f9e41b13.1fe7a8","order":17,"width":5,"height":1,"passthru":false,"topic":"End date","topicType":"str","x":580,"y":580,"wires":[["f089f523.5724c8"]]},{"id":"c2411f69.be4d4","type":"ui_text_input","z":"87ac3b01.909018","name":"End Time","label":"End Time","tooltip":"End Time","group":"f9e41b13.1fe7a8","order":18,"width":3,"height":1,"passthru":true,"mode":"time","delay":300,"topic":"End Time","topicType":"str","x":920,"y":580,"wires":[["99726772.f027f8"]]},{"id":"b1955da5.c99f6","type":"change","z":"87ac3b01.909018","name":"dd-mm-yyyy","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload).tz(\"Europe/London\").format(\"DD-MM-YYYY\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":540,"wires":[["1c233064.2dd4b"]]},{"id":"d0bf4f47.05a94","type":"change","z":"87ac3b01.909018","name":"hh:mm","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload).tz(\"Europe/London\").format(\"HH:mm\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":540,"wires":[["1c233064.2dd4b"]]},{"id":"f089f523.5724c8","type":"change","z":"87ac3b01.909018","name":"dd-mm-yyyy","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload).tz(\"Europe/London\").format(\"DD-MM-YYYY\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":580,"wires":[["1c233064.2dd4b"]]},{"id":"99726772.f027f8","type":"change","z":"87ac3b01.909018","name":"hh:mm","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload).tz(\"Europe/London\").format(\"HH:mm\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":580,"wires":[["1c233064.2dd4b"]]},{"id":"c971cce5.88a9c","type":"ui_dropdown","z":"87ac3b01.909018","name":"Breakdown reasons","label":"Breakdown reason","tooltip":"Breakdown reason","place":"Select Breakdown reason","group":"f9e41b13.1fe7a8","order":14,"width":9,"height":2,"passthru":false,"multiple":true,"options":[{"label":"Breakdown reason 1","value":"Reason 1","type":"str"},{"label":"Breakdown reason 2","value":"Reason 2","type":"str"},{"label":"Breakdown reason 3","value":"Reason 3","type":"str"},{"label":"Breakdown reason 4","value":"Reason 4","type":"str"}],"payload":"","topic":"Breakdown reason","topicType":"str","x":930,"y":640,"wires":[["1c233064.2dd4b"]]},{"id":"2d869a98.7e0f16","type":"ui_button","z":"87ac3b01.909018","name":"","group":"f9e41b13.1fe7a8","order":21,"width":4,"height":1,"passthru":false,"label":"Submit","tooltip":"","color":"","bgcolor":"","icon":"","payload":"complete","payloadType":"str","topic":"","topicType":"str","x":1010,"y":760,"wires":[["16c6115f.e5bcbf","ba495f3d.bc474"]]},{"id":"1632493f.a4d6a7","type":"ui_text","z":"87ac3b01.909018","group":"f9e41b13.1fe7a8","order":13,"width":3,"height":2,"name":"","label":"Breakdown time (in hours)","format":"<font size=5>{{msg.payload}}","layout":"col-center","x":950,"y":680,"wires":[]},{"id":"e2741ebc.977cc","type":"inject","z":"87ac3b01.909018","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"3","payloadType":"num","x":710,"y":740,"wires":[["1632493f.a4d6a7"]]},{"id":"179bd0b8.89044f","type":"ui_table","z":"87ac3b01.909018","group":"f9e41b13.1fe7a8","name":"","order":23,"width":28,"height":2,"columns":[],"outputs":0,"cts":false,"x":1570,"y":940,"wires":[]},{"id":"1c233064.2dd4b","type":"join","z":"87ac3b01.909018","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1670,"y":600,"wires":[["5521cf97.4e1f3"]]},{"id":"41e4ff59.840ee","type":"link in","z":"87ac3b01.909018","name":"","links":["9dc0d65b.64a128"],"x":195,"y":760,"wires":[["2ddf0d85.ea1dc2","91f54c58.30a4f","f24d7e50.20701","c2411f69.be4d4","f4ed0b9d.66aef8","c971cce5.88a9c"]]},{"id":"9dc0d65b.64a128","type":"link out","z":"87ac3b01.909018","name":"","links":["41e4ff59.840ee"],"x":1595,"y":840,"wires":[]},{"id":"16c6115f.e5bcbf","type":"change","z":"87ac3b01.909018","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"complete","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1270,"y":740,"wires":[["1c233064.2dd4b"]]},{"id":"ba495f3d.bc474","type":"change","z":"87ac3b01.909018","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1260,"y":780,"wires":[["9786f876.7c39f8"]]},{"id":"9786f876.7c39f8","type":"delay","z":"87ac3b01.909018","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1440,"y":780,"wires":[["9dc0d65b.64a128","179bd0b8.89044f"]]},{"id":"91f54c58.30a4f","type":"change","z":"87ac3b01.909018","name":"timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":440,"wires":[["d7e88a39.a6de98","a169e909.f6b518"]]},{"id":"5521cf97.4e1f3","type":"file","z":"87ac3b01.909018","name":"","filename":"","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":1850,"y":580,"wires":[[]]},{"id":"1959427e.99693e","type":"file in","z":"87ac3b01.909018","name":"","filename":"C:\\Users\\Sahil\\Desktop\\testing\\breakdown.csv","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":1160,"y":940,"wires":[["d46547e6.219768"]]},{"id":"262688ac.5398c8","type":"inject","z":"87ac3b01.909018","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":840,"y":940,"wires":[["1959427e.99693e"]]},{"id":"d46547e6.219768","type":"csv","z":"87ac3b01.909018","name":"","sep":",","hdrin":true,"hdrout":"all","multi":"mult","ret":"\\r\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":1430,"y":940,"wires":[["179bd0b8.89044f"]]},{"id":"f9e41b13.1fe7a8","type":"ui_group","name":"Group 1","tab":"74fd02f9.b99b3c","order":1,"disp":false,"width":28,"collapse":false},{"id":"74fd02f9.b99b3c","type":"ui_tab","name":"Breakdown entry form","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Screenshot
