Hi There!
I think I found an inconsistency in cron-plus compared to switch node and I'm not sure whether it's desired or not.
If I have multiple outputs in a switch and I move the conditions around in the list:
the outputs will be "sticky", i.e. connections are maintained as they are. Moving 3 above 2 in the above would cause crossed wires - visually.
If I do the same in the cron-plus node:
If I move schedule2 above schedule1 then the node that was connected to schedule1 will then be connected to schedule2 and conversely: the node that was connected to schedule2 will be connected to schedule1.
That's confusing but visual since after moving the schedules around, the wires visually looked the same - swapping two schedules should have caused cross wires.
Is that intended?
Cheers!
