Cronplus Sunset
If the creator of the node intended that they were wrong, as illustrated by the examples we have shown you.
Probably not.
It does seem that you have uncovered a shortcoming in the node, well done.
You should really raise an issue on the node's github page.
Meanwhile, the work-around is to use a location. If as you contend the location doesn't make much difference, it can't do any harm.
The red outline around the location field indicates that the field must be filled in for solar events.
I wonder if it defaults to 0,0?
