CSS button not working
I am playing a lot with CSS buttons.
For the most they are working.
But this one isn't playing the game.
Given all the other buttons are working and when I set the icon name it doesn't show.
Code:
<div id="GButtonM_ANA">
    <md-button class="md-button program-names darkred">
        <i class="material-icons">
            <span>analytics</span>
            <md-tooltip>Device status</md-tooltip>
        </i>
    </md-button>
</div>
<script>
(function($scope) {
$('#GButtonM_ANA').on('click', function(e) {
    e.preventDefault(); //prevent default behavior
    $scope.send({"topic":"momentary_regular","payload": "Big device status"});
})(scope);
</script>
The other weird thing is the popup appears on the button beside it.
Screenshot from 2020-06-08 08-53-44
Oops
Ok, my bad on the pop up.
It is just how it is popping up.
Other buttons the pop up is on the button. For reasons unknown: this is beside the button.
^ that's a tooltip & it's right there in the code you posted...
(See my oops part)
Show us the code of a working icon in a button Vs this code.
Its likely quite obvious if you look at 2 side by side.
Working:
<div id="GButtonM_TEL">
            <span> track_changes</span>
            <md-tooltip>Telemetry</md-tooltip>
        </i>
    </md-button>
</div>
<script>
(function($scope) {
$('#GButtonM_TEL').on('click', function(e) {
    $scope.send({"topic":"momentary_regular","payload": "TelePi Telemetry"});
})(scope);
</script>
Not working:
        </i>
    </md-button>
</div>
<script>
(function($scope) {
})(scope);
</script>
The only difference is the icon.
If I copy the track_changes icon to the button, it works.
So.....
I suspect that all the md-icons are not loaded.
How do I do that?
Oh, back to the popup thing.
This is a comparison of the popups that threw me.
Expected:
Screenshot from 2020-06-08 09-11-42
The button in question:
Screenshot from 2020-06-08 09-11-45
That seems strange that in one button the popup is over the button, and on the other it is in another post code to the button.
I don't think you use material icons like that. Its something like <md-icon> and you don't use class try searching the forum or internet on using material icons in angular
Edit...
Maybe not md-icon but pretty sure you put the icon name inside the tag (not in the class)
There you go...
Copy the code this ^ guy did here ^ into your button
Edit...
Forgot to say, it's probably not gonna work with extra stuff inside the <i>
Try this...
            analytics
        </i>
    </md-button>
Thanks.
You are correct that it doesn't work. But I don't think it is for the reason you say.
There are a lot of other buttons which have that attribute and they work.
I'll have to keep digging to see what I find.
