CSS question - template / ui-template node CSS
[{"id":"1b987d6f1b3ed9d3","type":"ui_template","z":"5b623fd31ca86a42","group":"6339e2ead216512f","name":"","order":1,"width":"30","height":"22","format":"","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":765,"y":1525,"wires":[[]]},{"id":"db98fecd74502f33","type":"template","z":"5b623fd31ca86a42","name":"","field":"template","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<style>\n* {\n  border: 0;\n  box-sizing: border-box;\n  margin: 0;\n  padding: 0;\n}\n\n:root {\n  font-size: calc(32px + (40 - 32)*(100vw - 320px)/ (1024 - 320));\n}\n\nbody {\n  background-image: url(\"https://assets.codepen.io/416221/light_wood.jpeg\");\n  background-position: 50% 50%;\n  color: #381803;\n  display: flex;\n  font: 1em Nunito, sans-serif;\n  height: 100vh;\n  line-height: 1.5;\n}\n\nform {\n  margin: auto;\n  max-width: 10em;\n  padding: 1.5em 0;\n  position: relative;\n}\nform label:before, form span:before {\n  border-radius: 50%;\n  content: \"\";\n}\nform label {\n  cursor: pointer;\n  display: flex;\n  letter-spacing: 0.1em;\n  text-transform: uppercase;\n}\nform label:before {\n  background: radial-gradient(100% 100% at 33% 33%, rgba(0, 0, 0, 0.25) 25%, rgba(0, 0, 0, 0) 50%), radial-gradient(100% 100% at 67% 67%, rgba(255, 255, 255, 0.15), rgba(255, 255, 255, 0) 50%);\n  box-shadow: 0 0 0.75em #000 inset;\n  display: inline-block;\n  margin-right: 0.375em;\n  width: 1.5em;\n  height: 1.5em;\n}\nform label:not(:last-of-type) {\n  margin-bottom: 1.5em;\n}\nform span {\n  position: absolute;\n  top: 1.75em;\n  left: 0.25em;\n  width: 1em;\n  height: 1em;\n  transition: transform 0.25s linear;\n  z-index: 1;\n}\nform span, form span:before {\n  display: block;\n}\nform span:before {\n  background-color: #2762f3;\n  background-image: radial-gradient(10% 10% at 50% 50%, rgba(255, 255, 255, 0.6) 50%, rgba(255, 255, 255, 0)), radial-gradient(12% 12% at 60% 25%, rgba(255, 255, 255, 0.6) 50%, rgba(255, 255, 255, 0)), radial-gradient(100% 100% at 60% 50%, rgba(0, 0, 0, 0) 25%, rgba(0, 0, 0, 0.25) 50%);\n  border-radius: 50%;\n  box-shadow: 0 0.1em 0.1em 0 rgba(0, 0, 0, 0.5), 0 0 0.1em 0.1em rgba(0, 0, 0, 0.25) inset;\n  width: 100%;\n  height: 100%;\n}\n\ninput {\n  position: fixed;\n  top: -1.5em;\n  left: -1.5em;\n}\n\ninput:nth-of-type(1):checked ~ span {\n  transform: translateY(0em);\n}\ninput:nth-of-type(1):checked ~ span:before {\n  animation: wobble1 0.5s linear forwards;\n}\n\n@keyframes wobble1 {\n  from, to {\n    transform: translateY(0) scale(1);\n  }\n  25% {\n    transform: translateY(0) scale(1.33);\n  }\n  50% {\n    transform: translateY(0.25em) scale(1);\n  }\n  67% {\n    transform: translateY(-0.15em) scale(1);\n  }\n  83% {\n    transform: translateY(0.07em) scale(1);\n  }\n}\ninput:nth-of-type(2):checked ~ span {\n  transform: translateY(3em);\n}\ninput:nth-of-type(2):checked ~ span:before {\n  animation: wobble2 0.5s linear forwards;\n}\n\n@keyframes wobble2 {\n  from, to {\n    transform: translateY(0) scale(1);\n  }\n  25% {\n    transform: translateY(0) scale(1.33);\n  }\n  50% {\n    transform: translateY(0.25em) scale(1);\n  }\n  67% {\n    transform: translateY(-0.15em) scale(1);\n  }\n  83% {\n    transform: translateY(0.07em) scale(1);\n  }\n}\ninput:nth-of-type(3):checked ~ span {\n  transform: translateY(6em);\n}\ninput:nth-of-type(3):checked ~ span:before {\n  animation: wobble3 0.5s linear forwards;\n}\n\n@keyframes wobble3 {\n  from, to {\n    transform: translateY(0) scale(1);\n  }\n  25% {\n    transform: translateY(0) scale(1.33);\n  }\n  50% {\n    transform: translateY(0.25em) scale(1);\n  }\n  67% {\n    transform: translateY(-0.15em) scale(1);\n  }\n  83% {\n    transform: translateY(0.07em) scale(1);\n  }\n}\ninput:nth-of-type(4):checked ~ span {\n  transform: translateY(9em);\n}\ninput:nth-of-type(4):checked ~ span:before {\n  animation: wobble4 0.5s linear forwards;\n}\n\n@keyframes wobble4 {\n  from, to {\n    transform: translateY(0) scale(1);\n  }\n  25% {\n    transform: translateY(0) scale(1.33);\n  }\n  50% {\n    transform: translateY(0.25em) scale(1);\n  }\n  67% {\n    transform: translateY(-0.15em) scale(1);\n  }\n  83% {\n    transform: translateY(0.07em) scale(1);\n  }\n}\n/* Dark mode */\n@media screen and (prefers-color-scheme: dark) {\n  body {\n    background-image: url(\"https://assets.codepen.io/416221/dark_wood.jpeg\");\n    color: #c58b50;\n  }\n}\n</style>\n\n<form>\n  <input id=\"one\" type=\"radio\" name=\"radios\" value=\"one\">\n  <input id=\"two\" type=\"radio\" name=\"radios\" value=\"two\">\n  <input id=\"three\" type=\"radio\" name=\"radios\" value=\"three\">\n  <input id=\"four\" type=\"radio\" name=\"radios\" value=\"four\">\n  <span></span>\n  <label for=\"one\">One</label>\n  <label for=\"two\">Two</label>\n  <label for=\"three\">Three</label>\n  <label for=\"four\">Four</label>\n</form>","output":"str","x":585,"y":1525,"wires":[["1b987d6f1b3ed9d3"]]},{"id":"afdad0a5f20b2a0d","type":"inject","z":"5b623fd31ca86a42","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":415,"y":1525,"wires":[["db98fecd74502f33"]]},{"id":"6339e2ead216512f","type":"ui_group","name":"Group 2","tab":"5e0dd10e66fdea95","order":2,"disp":false,"width":"30","collapse":false,"className":""},{"id":"5e0dd10e66fdea95","type":"ui_tab","name":"TEST","icon":"dashboard","order":8,"disabled":false,"hidden":false}]
I was trying to get some ideas of fancy radio buttons, and landed on this page,
and tried to copy that into DB-1 with a template node. i got it almost right except that the background is not what it is supposed to be, could someone tell where did it go wrong ?
radio
radio1
also, what changes are required if I want to make this arrangement horizontal ?
