Csv value to mqtt
HI,
i read a csv file from a ftp server and want to sent the values to a mqtt broker. My point know is, how can i create for each value in a line separate topic.
The csv have this fields:
sn; volume 1; volume 2; volume 3
22; 99; 33; 44; 77
11; 99; 33; 44; 77
At the end the topics should look like this:
/foo/bar/22/volume1/
/foo/bar/22/volume2/
/foo/bar/11/volume2/
At the moment i need this for something like 10-15 rows. So i can us copy and paste.
But if everything works fine, i will need a script or function where i can handle 400-450 lines. And my knowledge with functions are pretty basicly :frowning:
Thanks for any support
Start, I think, by sending the file into a CSV node to convert it to an array of objects with named properties. Then you can feed it into a Split node to convert into a stream of individual messages. Then you can massage each one of those to generate the topics and values that you want.
Here is an example for you to study.
Note
Topics should not start or end with a /, if you want to folow convention and not have blank topic paths.
[{"id":"2b1db6cff0ff0516","type":"inject","z":"613df62afc8a16bf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"foo/bar/22/","payload":"","payloadType":"date","x":140,"y":100,"wires":[["8b3f8de947600fc5"]]},{"id":"8b3f8de947600fc5","type":"template","z":"613df62afc8a16bf","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"sn;volume 1;volume 2;volume 3\n22;99;33;44;77\n11;99;33;44;77","output":"str","x":340,"y":100,"wires":[["ca46d07b493daf73"]]},{"id":"ca46d07b493daf73","type":"csv","z":"613df62afc8a16bf","name":"split csv per line","spec":"rfc","sep":";","hdrin":true,"hdrout":"none","multi":"one","ret":"\\r\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":520,"y":100,"wires":[["73e884455bf7ed90"]]},{"id":"73e884455bf7ed90","type":"split","z":"613df62afc8a16bf","name":"Split line","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"key","property":"payload","x":100,"y":160,"wires":[["16cdc214b575df73"]]},{"id":"16cdc214b575df73","type":"delay","z":"613df62afc8a16bf","name":"Limit rate","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"5","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":240,"y":160,"wires":[["fa3896cec22f101b"]]},{"id":"fa3896cec22f101b","type":"change","z":"613df62afc8a16bf","name":"remove spaces","rules":[{"t":"change","p":"key","pt":"msg","from":" ","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":160,"wires":[["32b8895ed1daabac"]]},{"id":"32b8895ed1daabac","type":"template","z":"613df62afc8a16bf","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{{topic}}}{{{key}}}","output":"str","x":700,"y":160,"wires":[["e3d2e85561651a6a"]]},{"id":"e3d2e85561651a6a","type":"debug","z":"613df62afc8a16bf","name":"humidity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":220,"wires":[]}
Thanks for your help.
The example from E1cid is basicly this what i need and it also fit for me. It´s basicly the same like colin discript.
At the moment in only struggeling with the topic. I want that the SN is part of the topic to get a better overview in the broker.
The basic topic looks like
/foo/baar/xxxx/
The topic for the second row should be
/foo/baar/xxxx/22/22
/foo/baar/xxxx/22/99
/foo/baar/xxxx/22/33
/foo/baar/xxxx/11/11
/foo/baar/xxxx/11/99
/foo/baar/xxxx/11/33
How can i put the value from sn in to the topic? I guess it works if i use the msg.payload.sn as a variable but my JSON knowledge isn´t so good :frowning:
move payload.sn prior to the split, then add it to the template.
e.g
[{"id":"2b1db6cff0ff0516","type":"inject","z":"613df62afc8a16bf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"foo/bar","payload":"","payloadType":"date","x":130,"y":100,"wires":[["8b3f8de947600fc5"]]},{"id":"8b3f8de947600fc5","type":"template","z":"613df62afc8a16bf","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"sn;volume 1;volume 2;volume 3\n22;99;33;44;77\n11;99;33;44;77","output":"str","x":340,"y":100,"wires":[["ca46d07b493daf73"]]},{"id":"ca46d07b493daf73","type":"csv","z":"613df62afc8a16bf","name":"split csv per line","spec":"rfc","sep":";","hdrin":true,"hdrout":"none","multi":"one","ret":"\\r\\n","temp":"","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":520,"y":100,"wires":[["58617d5cd23ddf5a"]]},{"id":"58617d5cd23ddf5a","type":"change","z":"613df62afc8a16bf","name":"","rules":[{"t":"move","p":"payload.sn","pt":"msg","to":"sn","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":100,"wires":[["73e884455bf7ed90"]]},{"id":"73e884455bf7ed90","type":"split","z":"613df62afc8a16bf","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"key","property":"payload","x":90,"y":160,"wires":[["16cdc214b575df73"]]},{"id":"16cdc214b575df73","type":"delay","z":"613df62afc8a16bf","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"5","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":250,"y":160,"wires":[["fa3896cec22f101b"]]},{"id":"fa3896cec22f101b","type":"change","z":"613df62afc8a16bf","name":"","rules":[{"t":"change","p":"key","pt":"msg","from":" ","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":160,"wires":[["32b8895ed1daabac"]]},{"id":"32b8895ed1daabac","type":"template","z":"613df62afc8a16bf","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{{topic}}}/{{{sn}}}/{{{key}}}","output":"str","x":700,"y":160,"wires":[["e3d2e85561651a6a"]]},{"id":"e3d2e85561651a6a","type":"debug","z":"613df62afc8a16bf","name":"humidity","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":220,"wires":[]}]
I note again topics should not start or end with a /.
Thanks for the hint again - i now :innocent:
The point is, in most our other tools we need to specifi a topic in this way [1] - so im used to this. Lately after the first deploy in nodered i remeber to remove the first and last / :rofl:
[1]
...and thanks for the help
