Hello, I'm having an issue with my property validation when setting up the editor UI. My invalid input does not have a red border around it and the code I set up to toggle a validation message for the URL field does not run. Inside my node HTML I have this:
<script type="text/html" data-template-name="custom-node">
<div class="form-row">
<label for="node-input-name"><i class="fa fa-tag"></i> Name</label>
<input type="text" id="node-input-name" placeholder="Name" />
<input type="hidden" id="node-input-name-type" />
</div>
<label for="node-input-url"><i class="fa fa-globe"></i> URL</label>
<input type="text" id="node-input-url" placeholder="https://example.com/file.wasm" />
<input type="hidden" id="node-input-url-type" />
</div>
<div class="form-row form-tips" id="node-validation-url" style="display:none;">
<b>ℹ️</b> This must be a valid URL
</div>
</script>
I think this is fine as it is at the moment. My oneditprepare function looks like this:
oneditprepare: function () {
let strs = ["name", "url"];
* Set up the input types for strings
* with optional validation if a message element is present
const addValidation = (el) => {
let id = el.id;
let validationEl = document.getElementById(`node-validation-${id}`);
if (validationEl) {
console.log("Adding validation check for", id);
el.on("input", function (event, type, value) {
let isValid = el.typedInput("validate");
console.log("input ", id, "valid:", isValid);
validationEl.style.display = isValid ? "none" : "block";
for (let id of strs) {
let el = $(`#node-input-${id}`).typedInput({
type: "str",
types: ["str"],
typeField: `#node-input-${id}-type`,
addValidation(el);
The validate function for the URL looks like this:
function (v) {
//check it is a valid URL.
try {
let u = new URL(v);
console.log(v, "is a valid url", u);
return true;
} catch (e) {
console.log("url NOT valid for", `'${v}'`, e);
return false;
The idea is that it's set up to allow for more than just string-typed inputs later on. The questions I have are:
- Is the
typedInput()call inside theforloop the correct way to ensure inputs are typed? - Can you see any issues in the
addValidation?
The node and properties appear in the interface, but the red border I'm expecting around the URL field never appears. The console.log calls I've added appear for the validate function but not for the input event listeners, but I can't work out why.
