I am trying to make a node-red application as lite as possible.
I understand different API's contribute to different functionality/components of the application.
How can i use API Reference : Node-RED to customise the app like a developer wants for his usecase.
For example,
If i only want to run the node-red application using only the run time modules or i want to remove the editor component( UI components) of the node-red (because after the flow is deployed it is not needed during the application runtime on a device)
How do i acheive this? from where should i start??
#general #development
