I am getting a daily crash where the system restarts but the error log does not identify the offending node as there is no trace dump. Any pointers appreciated on how to find it.
npm ERR! errno 1
npm ERR! node-red-docker@1.1.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"`
npm ERR! Exit status 1
npm ERR! Failed at the node-red-docker@1.1.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /data/.npm/_logs/2020-07-07T17_23_54_716Z-debug.log
Looking at the debug log leaves me with not much either.
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node',
1 verbose cli '/usr/local/bin/npm',
1 verbose cli 'start',
1 verbose cli '--cache',
1 verbose cli '/data/.npm',
1 verbose cli '--',
1 verbose cli '--userDir',
1 verbose cli '/data' ]
2 info using npm@6.14.4
3 info using node@v10.21.0
4 verbose config Skipping project config: /usr/src/node-red/.npmrc. (matches userconfig)
5 verbose run-script [ 'prestart', 'start', 'poststart' ]
6 info lifecycle node-red-docker@1.1.0~prestart: node-red-docker@1.1.0
7 info lifecycle node-red-docker@1.1.0~start: node-red-docker@1.1.0
8 verbose lifecycle node-red-docker@1.1.0~start: unsafe-perm in lifecycle true
9 verbose lifecycle node-red-docker@1.1.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/usr/src/node-red/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
10 verbose lifecycle node-red-docker@1.1.0~start: CWD: /usr/src/node-red
11 silly lifecycle node-red-docker@1.1.0~start: Args: [ '-c',
11 silly lifecycle 'node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"' ]
12 silly lifecycle node-red-docker@1.1.0~start: Returned: code: 1 signal: null
13 info lifecycle node-red-docker@1.1.0~start: Failed to exec start script
14 verbose stack Error: node-red-docker@1.1.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"`
14 verbose stack Exit status 1
14 verbose stack at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
14 verbose stack at EventEmitter.emit (events.js:198:13)
14 verbose stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
14 verbose stack at ChildProcess.emit (events.js:198:13)
14 verbose stack at maybeClose (internal/child_process.js:982:16)
14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
15 verbose pkgid node-red-docker@1.1.0
16 verbose cwd /usr/src/node-red
17 verbose Linux 4.19.118-v7l+
18 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" "--cache" "/data/.npm" "--" "--userDir" "/data"
19 verbose node v10.21.0
20 verbose npm v6.14.4
21 error code ELIFECYCLE
22 error errno 1
23 error node-red-docker@1.1.0 start: `node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"`
23 error Exit status 1
24 error Failed at the node-red-docker@1.1.0 start script.
24 error This is probably not a problem with npm. There is likely additional logging output above.
25 verbose exit [ 1, true ]
I have tried the suggestions solutions found by a search that involved cleaning the cache and deleting the node_modules folder followed by a new install. Even completely deployed a freshly build container instance and ported the flows. I am convinced this is related to a installed node, but which one?
