Dashboard 1 - icons in buttons and text nodes
dear all
I am wanting to use material design icons from pictogrammers in buttons and text nodes. and to place those icons above the text (i.e. the button label or the contents of a text node).
with buttons I am getting mixed results - I can't reliably get the icon to position above the label, and with some icons (e.g. mi-ph) are not fully visible.
with text nodes I am getting nowhere. there doesn't seem to be a UI friendly way of adding an icon.
is there a common workaround for this use-case?
thanks
justin
This thread may be interesting to read then ..
Thank you
I am unable to reproduce the effect that you created, I suspect that there has been a breaking change in the dashboard code. It does give me a direction though.
Whilst testing this I have also uncovered a bug in the material design icon implementation on buttons (assigned icons revert to font-awesome on refresh).
I have now reproduced the effect with font-awesome icons. thank you for the pointer.
I am unable to do so with material design icons. they seem not to centre and not to scale reliably with font-size directives. in fact, with a 4x4 button, anything over 2rem as a font-size seems to make the parent (the div and the tags) become wider than the constraining box and to make the glyph disappear. I am experimenting with the speedometer and pH icons.
is there any best practice for using material design icons? I'm looking to use them at 10rem in a 4x4 size in a 12 width grid screen.
