Dashboard 2 Color picker
I am slowly leaving the old good dashboard towards dashboard 2. And I also have just learned that all components from Vuetify can be implemented by simply using the template node. This is really great; after some trial and error (I am neither a java script nor a html expert) I fell in love with the v-data-table component which makes life so much easier if compared to the former approaches.
I am sure I can deal with all remaining stuff to be moved, however, exept for the color picker. Until now I am using the node-red-contrib-ui-iro-color-picker (as provided by Christian aka Christian-Me ). But the pickers from Vuetify are different. What I need is a color picker wheel with a saturation slider and a temperatur slider. I don't see that it is possible to use a wheel (instead in Vuetify there is a canvas approach which I don't like). What are my options to get over that hurdle ?
Thank you in advance...
Dear my friends, I did it and would like to share my flow (which is based on IRO.JS) and is directly implemented into a template node. Maybe it's useful for you.
        "id": "e03b471f00fe73b4",
        "type": "ui-template",
        "z": "7845132b7bdf9787",
        "group": "ca7441a009eecd98",
        "page": "",
        "ui": "",
        "name": "iro.js",
        "order": 1,
        "width": "6",
        "height": "6",
        "head": "",
        "format": "<template>\n  <div id=\"color-picker\"></div>\n</template>\n\n<script src=\"https://cdn.jsdelivr.net/npm/@jaames/iro@5.5.2/dist/iro.min.js\"></script>\n\n<script>\nexport default {\n  mounted() {\n    // Initialisiere den Farbpicker\n    this.colorPicker = new iro.ColorPicker('#color-picker', {\n      width: 250,\n      color: { r: 255, g: 0, b: 0 }, // Standardfarbe\n      wheelLightness: false,\n      layout: [\n        {\n          component: iro.ui.Wheel,\n          options: {\n            wheelAngle: 270, // Rot nach oben\n            wheelDirection: 'clockwise' // Drehrichtung im Uhrzeigersinn\n          }\n        }\n      ]\n    });\n\n    // Event-Listener für Farbänderungen\n    this.colorPicker.on('input:end', (color) => {\n      this.send({ payload: color.rgb });\n    });\n\n    // Listener für eingehende Nachrichten\n    this.$socket.on('msg-input:' + this.id, (msg) => {\n      if (msg.payload && msg.payload.r !== undefined) {\n        this.colorPicker.color.set(msg.payload);\n      }\n    });\n  }\n}\n</script>",
        "storeOutMessages": true,
        "passthru": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 850,
        "y": 300,
                "0f06582173f7203a"
        "id": "0f06582173f7203a",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1020,
        "y": 300,
        "id": "38f9ebb55e0285ae",
        "type": "inject",
        "name": "red",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{\"r\": 255, \"g\":0, \"b\":0}",
        "payloadType": "json",
        "x": 630,
        "y": 260,
                "e03b471f00fe73b4"
        "id": "567e14c325785168",
        "type": "inject",
        "name": "green",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{\"r\": 0, \"g\":255, \"b\":0}",
        "x": 630,
        "y": 300,
                "e03b471f00fe73b4"
        "id": "19e59aa24d3a12e7",
        "type": "inject",
        "name": "blue",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{\"r\": 0, \"g\":0, \"b\":255}",
        "x": 630,
        "y": 340,
                "e03b471f00fe73b4"
        "id": "ca7441a009eecd98",
        "type": "ui-group",
        "name": "IRO.JS",
        "page": "a71e15af5f8a5ba8",
        "width": "6",
        "height": "6",
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "a71e15af5f8a5ba8",
        "type": "ui-page",
        "name": "Colors",
        "ui": "14a551a96b61dade",
        "path": "/page1",
        "icon": "home",
        "layout": "grid",
        "theme": "acc4d7417e8a63c7",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "6"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "6"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "14a551a96b61dade",
        "type": "ui-base",
        "name": "My Dashboard 2 Next Level",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "page",
        "navigationStyle": "default",
        "titleBarStyle": "default",
        "showReconnectNotification": true,
        "notificationDisplayTime": "1",
        "showDisconnectNotification": true
        "id": "acc4d7417e8a63c7",
        "type": "ui-theme",
        "name": "STD_THEME",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094ce",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "density": "default",
            "pagePadding": "0px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "4px"
But what I could not get managed is to implement a function to enable/disable it and greying it out (by sending a msg.enabled true/false). Any help appreciated...
Regards
While trying around (my iro.js variant is not workingquite satisfactorily) I found something beautiful ;-). The best picker I have ever seen. Don't want a working solution. But just to know, if this could be implemented (without much effort) into our dashboard 2.0 environment. Short description is: A Color Wheel Picker for Vue, built on top of Vite & Vue 3
Demonstration / Webpage
Github
