I've give it to you this screenshot this afternoon
Is there a problem with it ?
Thanks Steve,
I will read it carefully...
Do you think that it's better to scope it with @flowfuse (for easier search) or with @cyprien ?
The json keys are not the same. Perhaps you can use sql directive "AS" to change the keys ? Could you post me your query ?
sure
msg.topic = SELECT COLUMN_NAME, DATA_TYPE, CHARACTER_MAXIMUM_LENGTH, IS_NULLABLE FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = '${msg.tableName}' AND ( (COLUMN_NAME = 'Schedule' AND DATA_TYPE = 'varchar') OR (COLUMN_NAME = 'Lines' AND DATA_TYPE = 'varchar') OR (COLUMN_NAME = 'Scrap' AND DATA_TYPE = 'int') OR (COLUMN_NAME = 'Rework' AND DATA_TYPE = 'int') OR (COLUMN_NAME = 'Duration' AND DATA_TYPE = 'int') OR (COLUMN_NAME = 'Countermeasure' AND DATA_TYPE = 'varchar') ) ;
msg.action = 'pragma';
Could you test by changing the begining of your query ?
Not sure that your WHERE clause is correct, why don't you return all your fields ?
SELECT COLUMN_NAME AS name, DATA_TYPE AS type, CHARACTER_MAXIMUM_LENGTH, IS_NULLABLE FROM
msg.topic = SELECT COLUMN_NAME AS name, DATA_TYPE AS type, CHARACTER_MAXIMUM_LENGTH, IS_NULLABLE FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = '${msg.tableName}' AND ( (COLUMN_NAME = 'Schedule' AND DATA_TYPE = 'varchar') OR (COLUMN_NAME = 'Lines' AND DATA_TYPE = 'varchar') OR (COLUMN_NAME = 'Scrap' AND DATA_TYPE = 'int') OR (COLUMN_NAME = 'Rework' AND DATA_TYPE = 'int') OR (COLUMN_NAME = 'Duration' AND DATA_TYPE = 'int') OR (COLUMN_NAME = 'Countermeasure' AND DATA_TYPE = 'varchar') );
like this?
Yes ! like this !
I think best start off on the right path & use scope but Not FlowFuse. That's our company name ![]()
Use you're own scope (whatever you chose).
+1 here, the idea of the scoping is to link it to the author. Anything we build, we use @flowfuse, any third-party/community pieces should be scoped to the relevant author.
Are you on MS SQL ? On sqlite, i use INSERT INTO query and it auto increment the ID, so, i don't specify it.
I think that it's the same on MS SQL, but i'm not sure... Anyway, it's a database configuration problem.
