Hi has anyone seen this on Dashboard 2.0 template node.
I missed the closing Curly bracket {{item.appKey} and that crashed NR and requires a stop/start?
I also tried on a simple example in the template node this does the same {{msg.payload}.
Though missing the opening Curly bracket {msg.payload} works.
Hi Steve I've tried this on two different Nr instances and the same behaviour.
Hit deploy flow becomes unresponsive and dashboard just shows loading.
NR v3.1.9 & Dashboard 2 v1.7.1
Sadly it is all too easy to lockup the browser with silly errors in a template node, I seem to manage it regurlarly. Part of the problem is the lack of syntax checking in the template editor.
