Dashboard 2 ui-audio not playing
ui-audio is playing on device where node red server is installed but not playing on dashboard of client page. Is there any issue with multi tenancy of ui-audio.
ui-button is working fine.
If any example with of ui-audio with multi tenancy example is highly helpful.
Hi and welcome to the forum.
Have you delete any client data in the message properties that will direct the audio to a specific device Building Multi-Tenant Dashboards | Node-RED Dashboard 2.0
Use the debug node prior to the audio node, set it to complete message object to inspect for any client data.
