Dashboard 2 widget in template not using space available
If I have a v-select widget in a ui-template I find that it does not use the available space in the same way as the core Dropdown widget does.
For example with this in the template
<template>
  <div>
    <v-select
      label="Dropdown template"
      variant="outlined"
    ></v-select>
  </div>
</template>
and a default Dropdown widget, both sized 6x1 I see this
Am I missing a class or something? I have tried to work it out by inspecting and comparing the DOM but my skills and knowledge are insufficient to work it out.
Here's the trick
<v-select hide-details label="Dropdown template" variant="outlined"></v-select>
hide-details
Excellent, thanks. It had not occurred to me that it was a v-select specific issue
