Dashboard Form Bugs
Dashboard Form Bugs屏幕录制2024-04-29 17.24.21
node-red-dashboard 3.6.5
node-red 3.1.9
I want to use the form component to select a time range, such as selecting a time range between 12:00 on April 27, 2024 and 12:30 on April 27, 2024.
If the form of dashboard has two same element ui,the data will be same, you can see the gif.
when I pick two date and time ui ,the data always is same. It was a Bug,so who can fix it,thanks.
That would be expected as they would output just one property when submitted, you would need to give each time you pick a different name in the config.
The below image would output an object with 2 properties a and b. if i wanted 3 I would have to change an name a to c.
many thanks .your answer is the solution!
