I have been considering a move to Dashboard Two, but see there is no DashBoard Two equivalent of the Dashboard One Level Widget. Like this:
What are my alternatives to do this in Dashboard Two?
Alan
Closest should be the Linear gauge
hotNIpi Thanks. perfect. Alan
Just to add, this kind of thing is perfectly possible in a template node:
Demo flow (Use CTRL+I to import)
[{"id":"d10f4be8b83cb824","type":"ui-template","z":"7ecf422396bf31b4","group":"d92eb51f258edce2","page":"","ui":"","name":"","order":1,"width":0,"height":0,"head":"","format":"<template>\n <div class=\"meter-container\">\n <div class=\"meter-header\">\n <span class=\"meter-label\">{{ msg.label || '' }}</span>\n <span class=\"meter-value\">\n <span class=\"value-num\">{{ msg.payload }}</span>\n <span class=\"value-unit\">{{ msg.topic }}</span>\n </span>\n </div>\n \n <div class=\"meter-scale-labels\">\n <span>{{ min }}</span>\n <span>{{ max }}</span>\n </div>\n\n <div class=\"meter-bar\">\n <div \n v-for=\"i in segments\" \n :key=\"i\" \n class=\"segment\"\n :class=\"getSegmentClass(i - 1)\"\n ></div>\n </div>\n </div>\n</template>\n\n<script>\nexport default {\n data() {\n return {\n segments: 60, // Increased density for a smoother look\n }\n },\n computed: {\n min() { return this.msg.min ?? 0 },\n max() { return this.msg.max ?? 100 },\n low() { return this.msg.low ?? 10 },\n high() { return this.msg.high ?? 90 }\n },\n methods: {\n getSegmentClass(index) {\n // Calculate value based on a 0-indexed segment\n const segmentValue = this.min + (index / (this.segments - 1)) * (this.max - this.min)\n \n // Is this bar filled?\n const isActive = segmentValue <= this.msg.payload\n \n // Determine the color zone for this specific segment\n const isLowZone = segmentValue <= this.low\n const isHighZone = segmentValue >= this.high\n \n return {\n 'active': isActive,\n 'is-low': isLowZone,\n 'is-high': isHighZone,\n 'is-neutral': !isLowZone && !isHighZone\n }\n }\n }\n}\n</script>\n\n<style scoped>\n.meter-container {\n background: #000;\n color: #fff;\n padding: 20px;\n border-radius: 4px;\n font-family: -apple-system, BlinkMacSystemFont, \"Segoe UI\", Roboto, sans-serif;\n}\n\n.meter-header {\n display: flex;\n justify-content: center;\n align-items: baseline;\n gap: 12px;\n margin-bottom: 8px;\n}\n\n.meter-label { font-size: 1.4rem; font-weight: 300; }\n.meter-value { font-size: 2.8rem; font-weight: 700; }\n.value-unit { font-size: 1.6rem; font-weight: 400; margin-left: 4px; }\n\n.meter-scale-labels {\n display: flex;\n justify-content: space-between;\n font-size: 1.1rem;\n color: #ccc;\n margin-bottom: 4px;\n}\n\n.meter-bar {\n display: flex;\n flex-direction: row;\n gap: 2px;\n height: 35px; /* Increased height to match image */\n width: 100%;\n}\n\n.segment {\n flex: 1;\n background: #222; /* Dimmer background for inactive segments */\n transition: background 0.1s ease;\n}\n\n/* Logic for Active Segments */\n.segment.active.is-low { background: #ff4444; } /* Red */\n.segment.active.is-neutral { background: #44ff44; } /* Green */\n.segment.active.is-high { background: #ff4444; } /* Red */\n\n/* Small Glow effect (Optional - remove if you want flat look) */\n.segment.active {\n box-shadow: 0 0 2px rgba(255,255,255,0.1);\n}\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":2340,"y":700,"wires":[[]]},{"id":"79e5124bf9bed370","type":"inject","z":"7ecf422396bf31b4","name":"","props":[{"p":"label","v":"Bus 1:","vt":"str"},{"p":"payload"},{"p":"topic","vt":"str"},{"p":"min","v":"12","vt":"num"},{"p":"max","v":"15","vt":"num"},{"p":"low","v":"12.5","vt":"num"},{"p":"high","v":"14.75","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volts","payload":"(\t $minimum := 12.1;\t $maximum := 14.95;\t $round(($random() * ($maximum-$minimum)) + $minimum, 2)\t)","payloadType":"jsonata","x":2187,"y":700,"wires":[["d10f4be8b83cb824"]]},{"id":"d92eb51f258edce2","type":"ui-group","name":"Group 1","page":"58c1725ba4ca6bda","width":6,"height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"58c1725ba4ca6bda","type":"ui-page","name":"Page 1","ui":"03482f22997a66ac","path":"/page1cdl","icon":"home","layout":"grid","theme":"0ac22d5584a0964a","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":"true","disabled":"false"},{"id":"03482f22997a66ac","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control","ui-chat"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":1,"showDisconnectNotification":true,"allowInstall":false},{"id":"0ac22d5584a0964a","type":"ui-theme","name":"Theme Name","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"compact","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"22px"}},{"id":"6c3e3bac07c65e20","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.30.2"}}]
