Hi all,
So I have some great dashboards built. However, I have a lot of inject nodes running every few seconds to query a database and display data.
My question is, is there something I can do to check if someone is actually viewing the dashboard page and if so, then run the inject queries.
Right now I am chewing up CPU and RAM by doing all there queries if someone is looking at the dashboard or not.
I am thinking a websocket...but have no idea how that works so any suggestions or examples would be fantastic.
Thanks everyone!!
look at the ui_control node. It outputs an event whenever anyone connects - so you can use that to trigger or start your queries (and then stop when =0)
E1cid
16 October 2020 12:56
3
The ui_control node will do what you require.
When any browser client connects or loses connection, changes tab, or expands or collapses a group this node will emit a msg containing:
payload - connect , lost , change , or group .
socketid - the ID of the socket (this will change every time the browser reloads the page).
socketip - the ip address from where the connection originated.
tab - the number of the tab. (only for 'change' event).
name - the name of the tab. (only for 'change' event).
group - the name of the group. (only for 'group' event).
open - the state of the group. (only for 'group' event).
Optional - report only connect events - useful to use to trigger a resend of data to a new client without needing to filter out other events.
