I have a few dashboard switches in one tab which have stopped working. First, they lost sync with the dashboard. Meaning, they showed off in the flow, while the dashboard showed on. Trying to change status on the dashboard sent a command, but the status on the dashboard did not change. I restarted Node Red. All my switches turned off. I can send a on in the flow, they will not change state either in the flow, or the dashboard. To eliminate other influences. I created a test switch, with injects on the on off. Looking at the debug, they send the message, but the switch does not change ! I checked on anotehr NR flow I have to see if I inadvertedly changed something, but the use the same payload and the switches there still work. Very weird.
As you can see from the debug, the last command was on. The switch is still off...
[{"id":"f3844ac592f01520","type":"change","z":"620ffedbfaeeb4e8","name":"Set payload On","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"On\"}","tot":"json"},{"t":"set","p":"strongcolor","pt":"msg","to":"deepskyblue","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":3800,"wires":[["fa17c7b5c057caba","1266b0a0c71a5830"]]},{"id":"6ac62a85a87e3c39","type":"change","z":"620ffedbfaeeb4e8","name":"Set payload Off","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"status\":\"Off\"}","tot":"json"},{"t":"set","p":"strongcolor","pt":"msg","to":"deepskyblue","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":3840,"wires":[["fa17c7b5c057caba","1266b0a0c71a5830"]]},{"id":"fa17c7b5c057caba","type":"ui_switch","z":"620ffedbfaeeb4e8","name":"Test TRV","label":"<font color= {{msg.strongcolor}} > {{\"Test TRV\"}} </font>","tooltip":"","group":"07554a310ef48bc2","order":1,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"control","topicType":"str","style":"","onvalue":"{\"value\":\"1\"}","onvalueType":"json","onicon":"","oncolor":"","offvalue":"{\"value\":\"0\"}","offvalueType":"json","officon":"","offcolor":"","animate":false,"className":"red-on-off","x":1020,"y":3820,"wires":[[]]},{"id":"da160f8107373946","type":"inject","z":"620ffedbfaeeb4e8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":600,"y":3800,"wires":[["f3844ac592f01520"]]},{"id":"caa5cc0ea44d729d","type":"inject","z":"620ffedbfaeeb4e8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":600,"y":3840,"wires":[["6ac62a85a87e3c39"]]},{"id":"1266b0a0c71a5830","type":"debug","z":"620ffedbfaeeb4e8","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1040,"y":3740,"wires":[]},{"id":"07554a310ef48bc2","type":"ui_group","name":"TRVs","tab":"f62ea21253d08c19","order":2,"disp":true,"width":5,"collapse":false,"className":""},{"id":"f62ea21253d08c19","type":"ui_tab","name":"System","icon":"dashboard","order":6,"disabled":false,"hidden":false}]
