Dashboard-template-node prints incoming msg on its own
Hello people,
I'm currently implementing a tabulator-table to my node-RED-dashboard and facing a weird issue.
The table imports a JSON which is pulled from a database. The data is getting imported and everything is fine. But the whole JSON is getting displayed below the table somehow:
That's the template-node:
<script type="text/javascript" src="/tabulator-tables/dist/js/tabulator.min.js"></script>
<link rel="stylesheet" href="/tabulator-tables/dist/css/tabulator.min.css" />
<div id="example-table"></div>
<div ng-bind-html="msg.payload"></div>
<script>
(function(scope) {
        //var data = [];
        if(msg) var tabledata = msg.payload;
        var table = new Tabulator("#example-table", {
            data:tabledata,
            //placeholder:"Keine Daten verfĂĽgbar!",
            layout:"fitColumns",
            columns:[
                {title:"Register", field:"Register", width:100},
                {title:"Beschreibung", field:"Beschreibung"},
                {title:"Druck", field:"Druck"},
})(scope);
</script>
Thanks in advice
Justin
Remove this line.
Thank you! How easy was that :joy:
