Dashboard tips. Let the ui_text act as level gauge ... DIY gauge examples
A "poor-man" level gauge created with a few lines of jquery and css.
[{"id":"36bcc3c8.68771c","type":"ui_template","z":"a05ff4cd.1ae7e8","group":"19f5ed07.08a453","name":"loll","order":12,"width":"1","height":"0","format":"<style>\n    .levelbody{\n        background: #2626b4f7;\n        height: 0%;\n        position: absolute;\n        width: 100%;\n        bottom: 0;\n        z-index:0;\n        transition: height 1s;\n        box-shadow: inset 0px 0px 10px 0px #00000080;\n        \n    }\n    .levelframe{\n        position:absolute;\n        background:transparent;\n        height:100%;\n        width: 100%;\n        border:2px solid #0000ff57 ;\n        box-shadow:inset 0px 0px 41px 0px #000000b5;\n        bottom:0;\n        z-index:1;\n    }\n    .leveltext{\n       text-shadow: 0px 0px 9px #191938c2;\n       z-index:2;\n    }\n</style>\n<script>\n(function(scope) {\n   \n  scope.$watch('msg', function(msg) {\n    if (msg) {\n        if(!$(\".nr-dashboard-widget-Level\")){\n            return\n            \n        }\n        \n        if (!$('.nr-dashboard-widget-Level').find('.levelbody').length) {\n            $(\".nr-dashboard-widget-Level\").find(\"p\").addClass(\"leveltext\")\n            $(\".nr-dashboard-widget-Level\").find(\".value\").css(\"font-size\",\"25px\")\n            $(\".nr-dashboard-widget-Level\").prepend(\"<div class='levelbody'></div>\")\n            $(\".nr-dashboard-widget-Level\").prepend(\"<div class='levelframe'></div>\")\n        }\n        $(\".levelbody\").css(\"height\",msg.payload+\"%\")\n    }\n  });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":590,"y":220,"wires":[["a00e9a56.b42a58"]]},{"id":"a00e9a56.b42a58","type":"ui_text","z":"a05ff4cd.1ae7e8","group":"19f5ed07.08a453","order":5,"width":"4","height":3,"name":"","label":"Level","format":"{{msg.payload}}%","layout":"col-center","x":730,"y":220,"wires":[]},{"id":"971b7001.1b3f2","type":"inject","z":"a05ff4cd.1ae7e8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":310,"y":220,"wires":[["35be2967.0edfd6"]]},{"id":"35be2967.0edfd6","type":"random","z":"a05ff4cd.1ae7e8","name":"","low":1,"high":"100","inte":"true","property":"payload","x":460,"y":220,"wires":[["36bcc3c8.68771c"]]},{"id":"19f5ed07.08a453","type":"ui_group","name":"Default","tab":"c71e2691.3704f8","order":1,"disp":true,"width":"6","collapse":false},{"id":"c71e2691.3704f8","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Real purpose of this post is to popularize the useful addition in widgets class list
class="nr-dashboard-text _md layout-column layout-align-center-center nr-dashboard-widget-Level visible"
The nr-dashboard-widget-Level in this list may come very handy in many situations when dealing with CSS for dashboard :slight_smile:
For actual use, here is ui_template version of similarly looking thing. Acts in many ways, from bottom up, from top down, from side or from both sides. And can be round.
[{"id":"9821976d.81e4a8","type":"inject","z":"9f4fbba4.68ceb8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":250,"y":1300,"wires":[["5d17609.94dd2a","9d583201.b3e3","7ceb37db.bf6158","9f86e34f.b94b5"]]},{"id":"5d17609.94dd2a","type":"random","z":"9f4fbba4.68ceb8","name":"","low":1,"high":"100","inte":"true","property":"payload","x":420,"y":1260,"wires":[["ff079329.434ad"]]},{"id":"9d583201.b3e3","type":"random","z":"9f4fbba4.68ceb8","name":"","low":1,"high":"100","inte":"true","property":"payload","x":420,"y":1340,"wires":[["a8b35e60.cbf8b","6a797db2.668714"]]},{"id":"a8b35e60.cbf8b","type":"ui_template","z":"9f4fbba4.68ceb8","group":"19f5ed07.08a453","name":"simple level blue ","order":9,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n    <div class=\"leveltext title\">LEVEL</div>\n    <div class=\"leveltext value\"></div>\n    <div class='levelbody' style='background:#2196f399;'></div>\n    <div class='levelframe' style='border-color:#2196f3; border-width:2px;'></div>\n</div>\n<script>\n(function(scope) {\n   \n  scope.$watch('msg', function(msg) {\n    if (msg) {\n        if(!$(\"#level_\"+scope.$id)){\n            return\n        }\n        $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"height\",msg.payload+\"%\")\n        $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n    }\n  });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":640,"y":1340,"wires":[[]]},{"id":"9139794a.12e668","type":"ui_template","z":"9f4fbba4.68ceb8","group":"19f5ed07.08a453","name":"simple level top down","order":12,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n    <div class=\"leveltext title\">BLINDS</div>\n    <div class=\"leveltext value\"></div>\n    <div class='levelbody topdown' style='background:\"#FFFFCCf7\";'></div>\n    <div class='levelframe' style='border-color:\"#FFFFFF\"; border-width:6px;'></div>\n</div>\n\n<script>\n(function(scope) {\n   \n  scope.$watch('msg', function(msg) {\n    if (msg) {\n        if(!$(\"#level_\"+scope.$id)){\n            return\n        }\n        $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"height\",msg.payload+\"%\")\n        $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n    }\n  });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":660,"y":1300,"wires":[[]]},{"id":"a78d7f3c.66fc6","type":"ui_template","z":"9f4fbba4.68ceb8","group":"19f5ed07.08a453","name":"simple-gauge css","order":3,"width":0,"height":0,"format":"<style id=\"simple-gauge\">\n\n.simple-gauge{\n    overflow:hidden;\n    position:relative;\n    width:100%;\n    height:100%;\n}\n.levelbody.side.right {\n    right:0;\n}\n.levelbody.side.left {\n    left:0;\n}\n.levelbody.side {\n    height:100%;\n    width:0%;\n}\n.levelbody.topdown {\n    bottom: unset;\n    top:0;\n}\n.levelbody.round {\n    height:100%;\n    width:100%;\n}\n.levelbody{\n    background: #FFFFCCf7;\n    height: 0%;\n    position: absolute;\n    width: 100%;\n    bottom: 0;\n    z-index:0;\n    transition: all 1s;\n    box-shadow: inset 0px 0px 10px 0px #00000080;\n}\n.bodywrap{\n    position: absolute;\n    clip-path: circle(50%);\n    width: 100%;\n    height: 100%;\n    bottom: 0;\n}\n.levelframe.round{\n    border-radius:50%;\n}\n.levelframe{\n    position:absolute;\n    box-sizing:border-box;\n    background:transparent;\n    height:100%;\n    width: 100%;\n    border:1px solid #FFFFFF ;\n    box-shadow:inset 0px 0px 41px 0px #000000b5;\n    bottom:0;\n    z-index:1;\n}\n.leveltext{\n    top:30%;\n    position:relative;\n    width:100%;\n    text-align:center;\n    text-shadow: 0px 0px 9px #191938c2;\n    z-index:2;\n    mix-blend-mode: exclusion;\n}\n.leveltext.value{\n    font-size:25px;\n}\n.leveltext.title{\n}\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","x":650,"y":1420,"wires":[[]]},{"id":"ff079329.434ad","type":"ui_template","z":"9f4fbba4.68ceb8","group":"19f5ed07.08a453","name":"simple level side","order":11,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n    <div class=\"leveltext title\">BLINDS</div>\n    <div class=\"leveltext value\"></div>\n    <div class='levelbody side' style='background:\"#FFFFCCf7\";'></div>\n    <div class='levelframe' style='border-color:\"#FFFFFF\"; border-width:6px;'></div>\n</div>\n\n<script>\n(function(scope) {\n   \n  scope.$watch('msg', function(msg) {\n    if (msg) {\n        if(!$(\"#level_\"+scope.$id)){\n            return\n        }\n        $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"width\",msg.payload+\"%\")\n        $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n    }\n  });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":640,"y":1260,"wires":[[]]},{"id":"e9e664c6.c84b48","type":"ui_template","z":"9f4fbba4.68ceb8","group":"19f5ed07.08a453","name":"simple level double side","order":13,"width":6,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge\">\n    <div class=\"leveltext title\">CURTAINS</div>\n    <div class=\"leveltext value\"></div>\n    <div class='levelbody side left' style='background:\"#FFFFCCf7\";'></div>\n    <div class='levelbody side right' style='background:\"#FFFFCCf7\";'></div>\n    <div class='levelframe' style='border-color:\"#FFFFFF\"; border-width:6px;'></div>\n</div>\n\n<script>\n(function(scope) {\n   \n  scope.$watch('msg', function(msg) {\n    if (msg) {\n        if(!$(\"#level_\"+scope.$id)){\n            return\n        }\n        $(\"#level_\"+scope.$id).find(\".levelbody.side\").css(\"width\",(msg.payload/2)+\"%\")\n       \n        $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n    }\n  });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":670,"y":1220,"wires":[[]]},{"id":"6a797db2.668714","type":"ui_template","z":"9f4fbba4.68ceb8","group":"19f5ed07.08a453","name":"simple level blue round","order":10,"width":3,"height":3,"format":"<div id=\"{{'level_'+$id}}\" class=\"simple-gauge round\">\n    <div class=\"leveltext title\">LEVEL</div>\n    <div class=\"leveltext value\"></div>\n    <div class=bodywrap>\n    <div class='levelbody round' style='background:#2196f399;'></div>\n    </div>\n    <div class='levelframe round' style='border-color:#2196f3; border-width:2px;'></div>\n</div>\n<script>\n(function(scope) {\n   \n  scope.$watch('msg', function(msg) {\n    if (msg) {\n        if(!$(\"#level_\"+scope.$id)){\n            return\n        }\n        $(\"#level_\"+scope.$id).find(\".levelbody\").css(\"top\",(100-msg.payload)+\"%\")\n        $(\"#level_\"+scope.$id).find(\".value\").text(msg.payload+\"%\")\n    }\n  });\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":660,"y":1380,"wires":[[]]},{"id":"9f86e34f.b94b5","type":"random","z":"9f4fbba4.68ceb8","name":"","low":1,"high":"100","inte":"true","property":"payload","x":420,"y":1220,"wires":[["e9e664c6.c84b48"]]},{"id":"7ceb37db.bf6158","type":"random","z":"9f4fbba4.68ceb8","name":"","low":1,"high":"100","inte":"true","property":"payload","x":420,"y":1300,"wires":[["9139794a.12e668"]]},{"id":"19f5ed07.08a453","type":"ui_group","name":"Default","tab":"c71e2691.3704f8","order":1,"disp":true,"width":"6","collapse":false},{"id":"c71e2691.3704f8","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
And if your expectations are a bit higher than abstract art can do, you are still on the land of CSS possibilities ... yes it is possible to put same gauge into the tank
You are the best @hotNipi .
We can only bow to your skills. :wink:
