Dashboard UI "max try" login
Hi
Seems like UI Dashboard does not have a "max try" option for its login,. I have been trying to find a way to limit the login try on my UI Dashboard, but no success.
for example if I navigate to my UI address http://my_ip:my_port/ui, it prompts user/password dialog, and seems like it prompts you infinite times if you put the wrong user/password. how I can limit this number of try to 3 time lets say.
Thanks.
I use a nginx reverse proxy then fail2ban with a custom filter for 403 Forbidden
if you enter the wrong details for login node-red will send back 403 Forbidden
I'm not going to cover how to setup a nginx reverse proxy here or installing fail2ban but here is how I setup fail2ban for rejecting failed login attempts and other failed requests on the server.
Create a new fail2ban filter for 404, 444, 403, 400 responses from the server.
$ sudo nano /etc/fail2ban/filter.d/nginx-4xx.conf
add the following to the file
[Definition]
failregex = ^<HOST>.*"(GET|POST).*" (404|444|403|400) .*$
ignoreregex =
exit and save changes to file
CTRL+x
Now, edit your /etc/fail2ban/jail.conf, to use the new filter we created and ban after 3 failed attempts.
$ sudo nano /etc/fail2ban/jail.conf
add/edit the following in the file
[nginx-4xx]
enabled = true
port = http,https
logpath = %(nginx_access_log)s
maxretry = 3
CTRL+x
restart fail2ban
$ sudo service fail2ban restart
check that the new rule is working
$ sudo fail2ban-client status nginx-4xx
now the user will be banned for the amount of time you have set in fail2ban after 3 failed attempts
you can check this is working with the logs.
$ sudo cat /var/log/fail2ban.log | grep Ban
and in nginx
$ sudo cat /var/log/nginx/access.log
Just checked in on the server as its been a few weeks.
fail to ban is working just fine.
Looks like @#@# from china got the msg that its not worth his time
https://www.abuseipdb.com/check/115.159.123.29
Just finished the whole guide if you need more information on fail2ban
https://discourse.nodered.org/t/node-red-server-with-nginx-reverse-proxy-howto-guide/27397
Thank you for your reply, it adds too much complexity in my system as I am already using ngnix for other purpose. I prefer to remove the whole node-red and start learning Django, rather than dealing with such a complexity.
I would have thought that if you already use nginx that the effort of adding a node-red server and fail2ban to it would have been almost trivial.
@meeki007 nice write up, thanks for taking the time to document.
I'm sure other users will find it of interest.
