Hi guys
tried hours and manny manny searches but I cannot find a way how to.
de array's in chart 1, 2 and 3 arre the same but once trought a msg it's not working.
see de flow below. I cannot get the payload back to an array for the 3d chart.
the format of de payload is the same as the array's from chart 1 and 2.
In the flow below you can test it
[{"id":"2431cf69.efb77","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"6e50a9a6.db3b18","type":"ui_chart","z":"2431cf69.efb77","name":"","group":"8c38a681.5c3c38","order":6,"width":0,"height":0,"label":"bar chart 3","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"No Data","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":490,"y":200,"wires":[[],[]]},{"id":"5726c821.796b18","type":"function","z":"2431cf69.efb77","name":"","func":"var test = msg.payload\nvar m={};\nm.labels = [10,20,30,40,50,60,70];\nm.series = ['Series A', 'Series B', 'Series C', 'Series D'];\nm.data = [\n test,\n \n ];\nreturn {payload:[m]};","outputs":1,"noerr":0,"x":310,"y":200,"wires":[["6e50a9a6.db3b18","58933951.d11eb8"]]},{"id":"b93d23e0.ac2bd","type":"ui_button","z":"2431cf69.efb77","name":"","group":"8c38a681.5c3c38","order":5,"width":0,"height":0,"passthru":false,"label":"array3","color":"","bgcolor":"","icon":"","payload":"80, 81, 56, 55, 40","payloadType":"str","topic":"","x":130,"y":200,"wires":[["5726c821.796b18","d9c036cd.654db8"]]},{"id":"733eb6fe.3ae6f8","type":"function","z":"2431cf69.efb77","name":"","func":"var m={};\nm.labels = [10,20,30,40,50,60,70];\nm.series = ['Series A', 'Series B', 'Series C', 'Series D'];\nm.data = [\n [80, 81, 56, 55, 40],\n \n ];\nreturn {payload:[m]};","outputs":1,"noerr":0,"x":310,"y":80,"wires":[["7b4e533.cb4ecac","db321e11.f75f3"]]},{"id":"d9c036cd.654db8","type":"debug","z":"2431cf69.efb77","name":"PAYLOAD ARRAY 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":360,"y":280,"wires":[]},{"id":"7b4e533.cb4ecac","type":"ui_chart","z":"2431cf69.efb77","name":"","group":"8c38a681.5c3c38","order":2,"width":0,"height":0,"label":"bar chart 1","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"No Data","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":490,"y":80,"wires":[[],[]]},{"id":"f138f3d8.44011","type":"ui_button","z":"2431cf69.efb77","name":"","group":"8c38a681.5c3c38","order":1,"width":0,"height":0,"passthru":false,"label":"array1","color":"","bgcolor":"","icon":"","payload":"","payloadType":"num","topic":"","x":130,"y":80,"wires":[["733eb6fe.3ae6f8"]]},{"id":"df4feb63.1e1468","type":"ui_chart","z":"2431cf69.efb77","name":"","group":"8c38a681.5c3c38","order":4,"width":0,"height":0,"label":"bar chart 2","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"No Data","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":490,"y":140,"wires":[[],[]]},{"id":"dec1f358.7f744","type":"function","z":"2431cf69.efb77","name":"","func":"var test = [80, 81, 56, 55, 40];\nvar m={};\nm.labels = [10,20,30,40,50,60,70];\nm.series = ['Series A', 'Series B', 'Series C', 'Series D'];\nm.data = [\n test,\n \n ];\nreturn {payload:[m]};","outputs":1,"noerr":0,"x":310,"y":140,"wires":[["df4feb63.1e1468","742afa5.168db04"]]},{"id":"e89f8627.20c478","type":"ui_button","z":"2431cf69.efb77","name":"","group":"8c38a681.5c3c38","order":3,"width":0,"height":0,"passthru":false,"label":"array2","color":"","bgcolor":"","icon":"","payload":"","payloadType":"num","topic":"","x":130,"y":140,"wires":[["dec1f358.7f744"]]},{"id":"db321e11.f75f3","type":"debug","z":"2431cf69.efb77","name":"ARRAY 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":680,"y":100,"wires":[]},{"id":"742afa5.168db04","type":"debug","z":"2431cf69.efb77","name":"ARRAY 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":680,"y":160,"wires":[]},{"id":"58933951.d11eb8","type":"debug","z":"2431cf69.efb77","name":"ARRAY 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":680,"y":220,"wires":[]},{"id":"8c38a681.5c3c38","type":"ui_group","z":"","name":"bar chart","tab":"e02ec498.531178","order":1,"disp":true,"width":"6","collapse":false},{"id":"e02ec498.531178","type":"ui_tab","name":"Tab 7","icon":"dashboard","order":7}]
TNX
Mark
