Data from dropdownlist to set value in SNMP-set
In Node-red I would like to use e.g. the values from a dropdown list to send to an SNMP-set command. As I understand the snmp-set node uses msg.varbinds to get its data. But how do I refer to the value coming from the dropdown list in the msg.varbinds input, as it looks JSON to me
This is what I have in the Varbinds window. I thought I just had to refer to the msg.payload coming from the dropdown element, but that seems to be too easy.
            "oid" : "1.3.6.1.4.1.5835.3.1.3.1.38.1.1",
            "type" : "OctetString",
            "value" : msg.payload
This is by the way the output from my dropdown list in the debug window.
9/23/2019, 8:13:04 PMnode: b4c9ef70.0f38d
msg : Object
object payload: "14300000000"
socketid: "Xc-CPsZX-CouQVRAAAAA"
_msgid: "b77a7c3f.8645c"
Problem solved:
After the dropdownlist node I needed a function with this:
var inputValue = msg.payload;
msg.varbinds = [
        "host": "192.168.0.35",
        "version": "1",
        "oid":   "1.3.6.1.4.1.5835.3.1.3.1.38.1.1",
        "type":  "OctetString",
         "value": ""+msg.payload+""
After the function node comes the SNMP Set node where I had to leave the varbinds box empty.
Thanks for posting this, it helped me understand and get this right. I still have an issue, using this code with a Syntax Error, Unexpected end of JSON input. Any ideas?
