Days left from date to date
Hi
I´m struggling with my function node.
collection data from an API, get dates in this format: "2021-04-19T00:00:00"
I would like to take the date from today, and show remaining days to the date from the api.
tried various of different combinations, but only get "NaN" in the debug window.
here are my code snippet:
var d = new Date();
var diff = Math.round((d - msg.payload.date));
msg = {payload:diff};
Also tried this:
var d = new Date();
var daysLeft;
daysLeft = Math.floor((d-msg.payload.date)/(1000*60*60*24));
msg = { payload:daysLeft};
kind of hit the wall here.
any good suggestions?
Regards,
Anders
Off the top of my head
const apiDt = new Date("2021-04-19T00:00:00")
const nowDt = new Date()
const diff = apiDt - nowDt
Should result in a number of milliseconds. That should be fairly easy to convert.
Not terribly efficient:
[{"id":"5509f63c.303728","type":"inject","z":"ef122f0d.d488b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":200,"wires":[["a35c299b.3731f8"]]},{"id":"a35c299b.3731f8","type":"function","z":"ef122f0d.d488b","name":"","func":"const apiDt = new Date(\"2021-04-19T00:00:00\")\nconst nowDt = new Date()\nconst diff  = apiDt - nowDt\n\nmsg.payload = {\n    \"millisec\": diff,\n    \"sec\": diff / 1000,\n    \"minutes\": diff / (1000*60),\n    \"hours\": diff / (1000*60*60),\n    \"days\": diff / (1000*60*60*24),\n    \"weeks\": diff / (1000*60*60*24*7),\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":340,"y":200,"wires":[["94a7aec6.4f6d1"]]},{"id":"94a7aec6.4f6d1","type":"debug","z":"ef122f0d.d488b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":200,"wires":[]}]
msg.payload = {
    "millisec": diff,
    "sec": diff / 1000,
    "minutes": diff / (1000*60),
    "hours": diff / (1000*60*60),
    "days": diff / (1000*60*60*24),
    "weeks": diff / (1000*60*60*24*7),
   "millisec":3376114685,
   "sec":3376114.685,
   "minutes":56268.578083333334,
   "hours":937.8096347222222,
   "days":39.07540144675926,
   "weeks":5.582200206679894
Hi and thanks for a fast reply :slight_smile:
I need to take the apiDt from the msg.payload.date object.
Can I use that directly like the quote below?
You certainly can as long as you are sure that property will exist.
