DB2 CSS - Change chart line thickness
Fixed
[{"id":"ea7c02fa77fe6efc","type":"ui-template","z":"a1ded7aeb5c2fa56","group":"1c6f457dfe15977b","page":"","ui":"","name":"Custom Line Chart","order":1,"width":"6","height":"5","head":"","format":"<template>\n    <div class=\"base-container\">\n        <div class=\"chart-container\" ><canvas ref=\"chart\" /></div>\n    </div>    \n</template>\n\n<script src=\"https://cdn.jsdelivr.net/npm/chart.js\"></script>\n\n<script>\n    export default {\n        data() {           \n            return {\n                keep:10000,  //keep data for 10 seconds                             \n            }\n        },\n        \n        mounted() {\n            this.$socket.on('msg-input:' + this.id, this.onInput)\n\n            // code here when the component is first loaded\n            let interval = setInterval(() => {\n                if (window.Chart) {\n                    // the chart.js is loaded, so we can now use it\n                    clearInterval(interval);\n                    this.draw()\n                }\n            }, 100);\n        },\n        methods: {\n            draw () {\n                const ctx = this.$refs.chart\n                const datasets = []\n                \n                // Render the chart\n                const chart = new Chart(ctx, {\n                                       \n                    type: 'line',\n                    data: {\n                        datasets: [\n                            {label: \"first\", data:[]},\n                            {label: \"second\",data:[]}\n                        ]\n                    },\n                    options: {\n                        maintainAspectRatio: false,//let the chart take the shape of the container\n                        animation: false,// do not animate\n                        responsive: true,// and please be responisve\n                        scales: {\n                            x: {\n                                type: 'time',//x-axis is configured to be time\n                                time: {\n                                    unit: 'second',//time resolution second\n                                    displayFormats: {\n                                        second: 'HH:mm:ss' // render ticks in that format\n                                    }\n                                },\n                                ticks: {\n                                    stepSize: 1, // by default render gridlaine and tick for defined step (1 here means every second)\n                                    autoSkip: false, // turn off automatic tick count calculations\n                                    maxTicksLimit:10, //limit total ticks amount (overrides setpSize obviously)\n                                    maxRotation:0 //do not allow ticks to be rotated\n                                }\n                            }\n                        },\n                        elements:{\n                            line:{\n                                borderWidth:2,//line thickness\n                                tension:0.3 //line curvature  \n                            },\n                            point:{\n                                pointRadius:0 //remove points (any positive number makes points at defined size)\n                            }\n                        },\n                        parsing: {\n                            xAxisKey: 'time',\n                            yAxisKey: 'value'\n                        },\n                        plugins: {\n                            legend: {\n                                position: 'top',\n                            },\n                            title: {\n                                display: true,\n                                text: 'Chart.js Line Chart. Basic Options'\n                            }\n                        }   \n                    },\n                });\n                // make this available to all elements of the component\n                this.chart = chart\n                console.log(this.data)\n            },\n            clearOldData(){\n                this.chart.data.datasets.forEach(dataset => {\n                    dataset.data = dataset.data.filter(point => point.time > Date.now() - this.keep)\n                })\n            },\n            clearChart(){\n                this.chart.data.datasets.forEach(dataset => {\n                    dataset.data = []\n                })\n                this.chart.update()\n            },\n\n            addDataPoint(topic,valueOrFulldata){\n                let dataset = this.chart.data.datasets.find(ds => ds.label == topic)\n                if(typeof valueOrFulldata === \"number\"){\n                    dataset.data.push({\n                        time: (new Date()).getTime(),\n                        value: valueOrFulldata\n                    })\n                } \n                else{\n                    dataset.data.push({\n                        time: valueOrFulldata.time,\n                        value: valueOrFulldata.value\n                    })\n                }              \n               \n                this.chart.update()\n            },\n            onInput (msg) {\n                if(Array.isArray(msg.payload)){\n                    if(msg.payload.length == 0){\n                        this.clearChart()\n                        return\n                    }\n                    else{\n                        // historycal data. for each item in array add the data to proper dataset\n                        // the data has format [{topic:\"first\",time:123456789,value:120}, and many more of such ...]\n                        msg.payload.forEach(point => {\n                            this.addDataPoint(point.topic,point)\n                        })                        \n                    }\n                }\n                else{\n                    this.clearOldData()\n                    this.addDataPoint(msg.topic,msg.payload)\n                }\n            }\n        }\n    }\n</script>\n<style>\n.base-container{\n    width:100%;\n    height:100%;\n    display: flex;\n    justify-content: center;\n    align-items: center;\n    container: chat / size;/*make this container available for container querys*/\n}\n.chart-container{\n    position: relative;\n    margin: auto;\n    height: 100cqb;/*use container query units to give full height of the container (100% of container height) */\n    width: 100cqi;/*use container query units to give full width of the container (100% of container height)*/\n    display: flex;\n    justify-content: center;\n    align-items: center;\n}\n     \n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":710,"y":500,"wires":[[]]},{"id":"caff24894c090d95","type":"ui-slider","z":"a1ded7aeb5c2fa56","group":"1c6f457dfe15977b","name":"Slider 1","label":"Slider 1","tooltip":"","order":2,"width":0,"height":0,"passthru":false,"outs":"all","topic":"slider-1","topicType":"str","thumbLabel":"true","showTicks":"always","min":0,"max":10,"step":1,"className":"","color":"","colorTrack":"","colorThumb":"","x":260,"y":500,"wires":[["7470f177a4852b22"]]},{"id":"7470f177a4852b22","type":"function","z":"a1ded7aeb5c2fa56","name":"randomly choose topic","func":"const t = Math.random() > .5 ? \"second\" : \"first\"\nmsg.topic = t\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":500,"wires":[["ea7c02fa77fe6efc"]]},{"id":"1c6f457dfe15977b","type":"ui-group","name":"Custom Bar Chart","page":"d0621b8f20aee671","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"d0621b8f20aee671","type":"ui-page","name":"Charts","ui":"29792df7d7b05e2e","path":"/charts","icon":"home","layout":"notebook","theme":"5075a7d8e4947586","order":2,"className":"","visible":"true","disabled":"false"},{"id":"29792df7d7b05e2e","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"default","titleBarStyle":"default"},{"id":"5075a7d8e4947586","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
