DB2: Problem open a new tab with given url
Hiho friends,
i ve a problem with a simple thing:
I want to open a new tab with a given url when clicking on a button. I tested stuff out but failed at the point where a tab was opened (like I wish) but when making a reload or revisiting the site I opened the tab from it opened it from just the revisiting. Here i where I ve got to:
[{"id":"cff55d870276896d","type":"ui-template","z":"9ab7988b0e4273a5","d":true,"group":"e25a141b0e6a7d47","page":"","ui":"","name":"clickLinkDB2","order":4,"width":"6","height":"2","head":"","format":"<script>\n    export default {\n        data() {\n            return {\n                macId: \"\",\n                hasProcessedMessage: false // Flag für verarbeitete Nachrichten\n            };\n        },\n        watch: {\n            msg: {\n                handler: function(newMsg) {\n                    // Prüfen ob eine gültige Nachricht vorliegt\n                    if (!newMsg || !newMsg.mac) {\n                        return;\n                    }\n\n                    // MacId beim ersten Mal setzen\n                    if (!this.macId) {\n                        this.macId = newMsg.mac;\n                    }\n\n                    // Nur verarbeiten wenn es die richtige MAC ist und ein Payload vorhanden ist\n                    if (newMsg.mac === this.macId && newMsg.payload && newMsg.payload !== null) {\n                        // Verhindern von mehrfacher Verarbeitung derselben Nachricht\n                        if (!this.hasProcessedMessage) {\n                            this.hasProcessedMessage = true;\n                            \n                            // Neues Tab öffnen\n                            window.open(newMsg.payload, '_blank');\n                            \n                            // Flag nach kurzer Zeit zurücksetzen für nächsten Klick\n                            setTimeout(() => {\n                                this.hasProcessedMessage = false;\n                            }, 1000);\n                        }\n                    }\n                },\n                immediate: false // Verhindert Ausführung beim Component-Mount\n            }\n        },\n        mounted() {\n            // Beim Laden der Komponente nichts tun\n        }\n    }\n</script>\n<style>\n    .hidden-template {\n        display: none !important;\n    }\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"hidden-template","x":1970,"y":700,"wires":[[]]},{"id":"7852f186e1b499a6","type":"function","z":"9ab7988b0e4273a5","d":true,"name":"getIpFormMac","func":"let mac = \"18:01:f1:94:85:d4\";\nmac = mac.toLowerCase();\nlet arp = msg.payload;\nif(arp === \"empty\") return null;\n\nlet macFound = false;\nlet arryCounter = 0;\nfor(let entry in arp)\n{\n    if (arp[arryCounter].mac === mac) \n    {\n        macFound = true;\n        break;\n    } \n    arryCounter+=1;\n}\n\nif(macFound === true) {\n    msg.ip = arp[arryCounter].ip;\n    msg.mac = mac;\n    msg.linkId = mac;\n    msg.payload = \"http://\" + msg.ip;\n    \n    // Nach kurzer Zeit Payload zurücksetzen (optional)\n    setTimeout(() => {\n        flow.set(\"lastProcessed\", Date.now());\n    }, 100);\n    \n    return msg;\n}\n\nmsg.arryCounter = arryCounter;\nmsg.mac = mac;\nmsg.arp = arp;\nmsg.payload = 0;\n//return msg;\nreturn null;\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1980,"y":660,"wires":[["cff55d870276896d"]]},{"id":"244dbbcb828390fc","type":"ui-button","z":"9ab7988b0e4273a5","d":true,"group":"e25a141b0e6a7d47","name":"Cam 4 - Garten - Oberfläche","label":"Cam 4 - Garten - Oberfläche","order":3,"width":0,"height":0,"emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"true","payloadType":"bool","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","x":1940,"y":620,"wires":[["7852f186e1b499a6"]]},{"id":"e25a141b0e6a7d47","type":"ui-group","name":"Webcams Ansichten","page":"94749b1b8a1d2fa3","width":"14","height":"1","order":4,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"94749b1b8a1d2fa3","type":"ui-page","name":"Webcams","ui":"282ba4e5c6170cd2","path":"/webcams","icon":"home","layout":"flex","theme":"97db8f45911448c5","breakpoints":[{"name":"Default","px":0,"cols":3},{"name":"Tablet","px":576,"cols":6},{"name":"Small Desktop","px":768,"cols":9},{"name":"Desktop","px":1024,"cols":12}],"order":15,"className":"","visible":true,"disabled":false},{"id":"282ba4e5c6170cd2","type":"ui-base","name":"Dashboard 2.0","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":5,"showDisconnectNotification":true,"allowInstall":true},{"id":"97db8f45911448c5","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px","density":"default"}},{"id":"3318d37bf9878300","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.26.0"}}]
