gerry
5 October 2024 17:53
1
Working on migrating to DB2 and this is a long slog. I have a basic 3X3 grid with seven buttons and although I am somewhat happy with this there was a issue trying to get the buttons to indicate pushed. When I push one on one row it deselects a button on the next row. So I stuffed the code into chat gpt and it spit out a new file and then wanted me to create a buttoncard component. Is this something that node red supports? Just for giggles I have attached my code.
<template>
<v-container>
<v-col style="height: 25px; width: 300px; background-color: black">
<v-row>
<v-card class="containerTop">Timer 1</v-card>
<v-card class="containerTop"></v-card>
<v-card class="containerTop">Reset</v-card>
</v-row>
</v-col>
<v-col style="height: 80px; width: 300px; background-color: black">
<v-row>
<v-card class="container">
<v-btn rounded @click="btn1">Timer1</v-btn>
</v-card>
<v-btn rounded @click="btn2"></v-btn>
</v-card>
<v-btn rounded @click="btn3" :class="{ 'active': clicked === 3 }">Reset</v-btn>
</v-card>
</v-row>
</v-col>
<v-row>
<v-btn rounded @click="btn4" :class="{ 'active': clicked === 4 }">Rnd</v-btn>
</v-card>
<v-btn rounded @click="btn5" :class="{ 'active': clicked === 5 }">On</v-btn>
</v-card>
<v-btn rounded @click="btn6" :class="{ 'active': clicked === 6 }">Off</v-btn>
</v-card>
</v-row>
</v-col>
<v-row>
<v-btn rounded @click="btn7" :class="{ 'active': clicked === 7 }">24 Hr</v-btn>
</v-card>
<v-btn rounded @click="btn8"></v-btn>
</v-card>
<v-btn rounded @click="btn9" :class="{ 'active': clicked === 9 }">Nite</v-btn>
</v-card>
</v-row>
</v-col>
</v-container>
</template>
<script>
export default {
data() {
return {
buttonText1: 'Timer1', // Initial button text
buttonText2: '', // Initial button text
buttonText3: 'Reset', // Initial button text
clicked: 1, // Initial clicked state
methods: {
btn1() {
this.clicked = 1;
btn2() {
btn3() {
this.clicked = 3;
this.send({ payload: "reset" }); // Example: Replace with your MQTT message send logic
btn4() {
this.clicked = 4;
this.send({ payload: "rnd" }); // Example: Replace with your MQTT message send logic
btn5() {
this.clicked = 5;
this.send({ payload: "on" }); // Example: Replace with your MQTT message send logic
btn6() {
this.clicked = 6;
this.send({ payload: "off" }); // Example: Replace with your MQTT message send logic
btn7() {
this.clicked = 7;
this.send({ payload: "24hr" }); // Example: Replace with your MQTT message send logic
btn8() {
btn9() {
this.clicked = 9;
this.send({ payload: "nite" }); // Example: Replace with your MQTT message send logic
watch: {
msg: {
deep: true,
handler(newVal) {
if (newVal.payload === 1) {
this.clicked = 1;
this.buttonText1 = 'Timer1';
this.buttonText2 = '';
this.buttonText3 = 'Reset';
} else if (newVal.payload === 2) {
this.clicked = 2;
} else if (newVal.payload === 3) {
this.clicked = 3;
created() {
// Example: Fetch initial data from an API or subscribe to MQTT topics
// this.$mqtt.subscribe('topic1');
// this.$mqtt.subscribe('topic2');
// this.$mqtt.subscribe('topic3');
</script>
<style scoped>
.containerTop {
display: flex;
justify-content: center;
align-items: center;
width: 100px;
height: 25px; /* Adjust height as needed */
background-color: black;
color: white;
font-size: 12px;
text-align: center;
border-bottom: 2px solid #dd7f00;
border-top: 3px solid #6689a1;
border-left: 3px solid #6689a1;
border-right: 3px solid #6689a1;
.container {
display: flex;
width: 100px;
height: 80px; /* Adjust height as needed */
border-bottom: 3px solid #6689a1;
.box {
width: 25px; /* Adjust box width as needed */
height: 80px; /* Adjust box height as needed */
display: flex;
.centered-button {
padding: 10px 20px;
color: white;
font-size: 16px;
cursor: pointer;
button {
display: flex;
width: 75px;
padding-top: 2px;
border-top: 5px;
background-color: grey; /* Default background color */
color: white;
font-size: 12px;
border: none;
cursor: pointer;
.active {
background-color: green; /* Changed background color when active */
.a1 {
text-align: center;
height: 25px !important;
width: 140px !important;
margin-top: 5px;
margin-bottom: 1px;
margin-left: 5px;
margin-right: 5px;
font-size: 16px;
color: #6689a1;
padding-bottom: 4px;
border-top: 2px solid #6689a1;
border-left: 2px solid #6689a1;
border-right: 2px solid #6689a1;
.a2 {
text-align: center;
height: 50px !important;
width: 100px !important;
margin-top: 1px;
margin-bottom: 5px;
margin-left: 5px;
margin-right: 5px;
font-size: 16px;
color: #6689a1;
padding-bottom: 2px;
border-bottom: 2px solid #6689a1;
</style>
Node red? Or dashboard 2?
And what are you asking really? What part are you asking is supported? Did you try this code in a ui-template? At first glance it looks like it would work (very quick glance)
gerry
5 October 2024 18:16
3
So yes it does work... sort of. When I click on a button in row 2 that button turns green. It should stay green unless I push another button in row 2. But if I push a button in row 3 then it turns off the button in row 2 and only high lights the button in row 3. Does that make sense?
jbudd
5 October 2024 18:19
5
One button group per row maybe?
gerry
5 October 2024 18:22
6
yes, but what occurs is that I need three button groups to get the same functionality. Then when I put them on the dashboard there is a gap between the button groups. I am trying to get all the buttons stacked closer together, visually. Can't seem to accomplish that with the individual button groups. Then it became a man vs. machine to try to do it in a template and the machine is winning. This is more of making it look like what I want than doing it the easy way.
[edit]
I have a good working dashboard on my existing installation, and I like the way it looks. It's now trying to duplicate my existing stuff in DB2 and make it look the same. I'm in no hurry to update and that's a good thing as this is taking forever but I want to take the time and do it like I want rather than just slap something together. .
jbudd
5 October 2024 18:41
7
You can adjust the "Widget Gap" in the theme settings for any single dashboard page.
For example this is 2px and the three button groups are pretty close together.
It affects all widgets on that page.
It looks like you'll need some CSS jiggery-pokery to make all the buttons the same width .
Edit: Grr there's no "class" field in the button group config!
Clearly an oversight. If you raise an issue we'll get it added.
gerry
5 October 2024 20:15
10
here's my final button group
<template>
<v-container>
<!-- Row 1: Timer number and reset -->
<v-row>
<v-btn rounded >Timer 1</v-btn>
</v-card>
</v-card>
<v-btn rounded @click="btnReset('reset')" :class="{ 'active': isActive['reset'] }">Reset</v-btn>
</v-card>
</v-row>
</v-col>
<!-- Row 2: rnd on off -->
<v-row>
<v-btn rounded @click="btnRnd('rnd')" :class="{ 'active': isActive['rnd'] }">Rnd</v-btn>
</v-card>
<v-btn rounded @click="btnOn('on')" :class="{ 'active': isActive['on'] }">On</v-btn>
</v-card>
<v-btn rounded @click="btnOff('off')" :class="{ 'active': isActive['off'] }">Off</v-btn>
</v-card>
</v-row>
</v-col>
<!-- Row 3: 24hr nite -->
<v-row>
<v-btn rounded @click="btn24hr('24hr')" :class="{ 'active': isActive['24hr'] }">24Hr
</v-btn>
</v-card>
</v-card>
<v-btn rounded @click="btnNite('nite')" :class="{ 'active': isActive['nite'] }">Nite
</v-btn>
</v-card>
</v-row>
</v-col>
</v-container>
</template>
<script>
export default {
data() {
return {
isActive: {
buttonText: {
watch: {
msg: {
deep: true,
handler(newVal) {
if (newVal.topic === 'Rnd' && newVal.payload === true) {
this.isActive['rnd'] = true;
this.isActive['on'] = false;
this.isActive['off'] = false;
if (newVal.topic === 'On' && newVal.payload === true) {
this.isActive['rnd'] = false;
this.isActive['on'] = true;
if (newVal.topic === 'Off' && newVal.payload === true) {
this.isActive['off'] = true;
if (newVal.topic === '24hr' && newVal.payload === true) {
this.isActive['24hr'] = true;
this.isActive['nite'] = false;
if (newVal.topic === 'Nite' && newVal.payload === true) {
this.isActive['24hr'] = false;
this.isActive['nite'] = true;
methods: {
btnReset() {
btnRnd() {
btnOn() {
btnOff() {
btn24hr() {
btnNite() {
</script>
<style scoped>
.containerTop {
display: flex;
width: 100px;
color: white;
font-size: 12px;
text-align: center;
.container {
display: flex;
width: 100px;
.box {
display: flex;
.centered-button {
padding: 10px 20px;
color: white;
font-size: 16px;
cursor: pointer;
.button {
display: flex;
width: 75px;
padding-top: 2px;
border-top: 5px;
color: white;
font-size: 12px;
border: none;
cursor: pointer;
.active {
.a1 {
text-align: center;
margin-top: 5px;
margin-bottom: 1px;
margin-left: 5px;
margin-right: 5px;
font-size: 16px;
color: #6689a1;
.a2 {
text-align: center;
margin-top: 1px;
margin-bottom: 5px;
margin-left: 5px;
margin-right: 5px;
font-size: 16px;
color: #6689a1;
</style>
I have modified the code you posted and it now does what I think you were after. It is a bit rough & ready and could be streamlined but it works
<template>
<v-container>
<v-row>
</v-row>
</v-col>
<v-row>
</v-card>
</v-card>
<v-btn rounded @click="btn3" :class="{ 'active': buttonGroup[0] == 3 }">Reset</v-btn>
</v-card>
</v-row>
</v-col>
<v-row>
<v-btn rounded @click="btn4" :class="{ 'active': buttonGroup[1] === 1 }">Rnd</v-btn>
</v-card>
<v-btn rounded @click="btn5" :class="{ 'active': buttonGroup[1] === 2 }">On</v-btn>
</v-card>
<v-btn rounded @click="btn6" :class="{ 'active': buttonGroup[1] === 3 }">Off</v-btn>
</v-card>
</v-row>
</v-col>
<v-row>
<v-btn rounded @click="btn7" :class="{ 'active': buttonGroup[2] === 1 }">24 Hr</v-btn>
</v-card>
</v-card>
<v-btn rounded @click="btn9" :class="{ 'active': buttonGroup[2] === 3 }">Nite</v-btn>
</v-card>
</v-row>
</v-col>
</v-container>
</template>
<script>
export default {
data: () => {
return {
buttonGroup: [1, 0, 0],
methods: {
btn1() {
this.buttonGroup[0] = 1
btn2() {
btn3() {
this.buttonGroup[0] = 3
btn4() {
this.buttonGroup[1] = 1
btn5() {
this.buttonGroup[1] = 2
btn6() {
this.buttonGroup[1] = 3
btn7() {
this.buttonGroup[2] = 1
btn8() {
btn9() {
this.buttonGroup[2] = 3
watch: {
msg: {
deep: true,
handler(newVal) {
this.buttonGroup[0] = 2
mounted() {
</script>
<style scoped>
.containerTop {
display: flex;
width: 100px;
color: white;
font-size: 12px;
text-align: center;
.container {
display: flex;
width: 100px;
.box {
display: flex;
.centered-button {
padding: 10px 20px;
color: white;
font-size: 16px;
cursor: pointer;
button {
display: flex;
width: 75px;
padding-top: 2px;
border-top: 5px;
color: white;
font-size: 12px;
border: none;
cursor: pointer;
.active {
.a1 {
text-align: center;
margin-top: 5px;
margin-bottom: 1px;
margin-left: 5px;
margin-right: 5px;
font-size: 16px;
color: #6689a1;
.a2 {
text-align: center;
margin-top: 1px;
margin-bottom: 5px;
margin-left: 5px;
margin-right: 5px;
font-size: 16px;
color: #6689a1;
</style>
