DEC to ASCII characters display
Look very ambiguous as to what you have is it an array or buffer?
From array using JS in function node.
msg.payload = String.fromCharCode.apply(null, msg.payload);
returns HILSCHYW
When supplying data it is best to supply text. You can gain this by using the copy value in the debug sidebar
BX00Cy7yHi
Then paste in thread using
   code goes here
You can edit and correct your post by clicking the pencil :pencil: icon.
Or have a look at node-red-contrib-buffer-parser (node) - Node-RED
