Decrypt LoRa packet
Hi for all
I'm a newbie to node red , I'm trying to receive and send a LoRa packet to my server. I put a TCPin to listen on a port and I get a similar packet as string
01879004:ffffffcf0000005a10020100;
or as buffer
48,49,56,55,57,48,48,52,58,102,102,102,102,102,102,99,49,48,48,48,48,48,48,53,50,49,48,48,54,48,49, 48,48,59,13,10
i would like to fetch some data to put into my my sql and fetch data from my db to send it to the end node.
I receive the packet in TCPin , I have already implemented the writing and reading in mysql but I can't decipher this data.
I tried contrib nodes but they don't work.
Has anyone faced a similar problem before?
Regards
NEX
Hi, normally your message is encoded in Hexadecimal, so you have to convert Hex to String:
const buffer = Buffer.from(msg.payload, "hex");
const data = buffer.toString("base64");
return { payload: data };
thanks a lot
I test your code at soon possible
Regards
