Define msg.topic in function node
Hello everyone, need help to create one function node
below is the given flow
[{"id":"4476fe10.e2765","type":"simpletime","z":"1f149e22.43a482","name":"","mydate":true,"myymd":true,"myyear":true,"mymonth":true,"mymonthn":true,"mydom":true,"mydoy":true,"myday":true,"myhourpm":true,"myhour":true,"mytime":true,"mytimes":true,"myminute":true,"myminutes":true,"mysecond":true,"mymillis":true,"myepoch":true,"myrawdate":true,"mypm":true,"x":450,"y":960,"wires":[["ed99652.1402f98"]]},{"id":"ed99652.1402f98","type":"template","z":"1f149e22.43a482","name":"date","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"from 01-{{mymonthn}}-{{myyear}} to {{mydom}}-{{mymonthn}}-{{myyear}}","output":"str","x":610,"y":960,"wires":[["e352cec1.fb968"]]},{"id":"e352cec1.fb968","type":"function","z":"1f149e22.43a482","name":"date, time","func":"msg.payload = msg.payload;\nmsg.topic='date';\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":960,"wires":[["1d1920d3.2a95ef"]]},{"id":"e2a56fda.b415","type":"MSSQL","z":"1f149e22.43a482","mssqlCN":"898d2a6f.9fb7b8","name":"A, P, Q, OEE (all machines)","query":"SELECT \n(((SUM (CAST([MACHINE SHIFT TIME (X)(Min.)] AS FLOAT))- SUM (CAST([AVAILABILITY LOSS TIME(Min.)] AS FLOAT)))/SUM (CAST([MACHINE SHIFT TIME (X)(Min.)] AS FLOAT)))*100) \nAS availability,\n((SUM(CAST([OK PRODUCTION] AS FLOAT)) / SUM(COALESCE((((CAST([MACHINE SHIFT TIME (X)(Min.)] AS FLOAT)-CAST([AVAILABILITY LOSS TIME(Min.)] AS FLOAT))/(NULLIF(CAST([TOTAL STANDARD CYCLE TIME(Sec.)] AS FLOAT),0)))*60*CAST([PARTS PER CYCLE (U)] AS FLOAT)),0)))*100)\nAS performance,\n((SUM(CAST([OK PRODUCTION] AS FLOAT)) / SUM(CAST([TOTAL PRODUCTION] AS FLOAT)))*100) \nAS quality,\n(((((SUM (CAST([MACHINE SHIFT TIME (X)(Min.)] AS FLOAT))- SUM (CAST([AVAILABILITY LOSS TIME(Min.)] AS FLOAT)))/SUM (CAST([MACHINE SHIFT TIME (X)(Min.)] AS FLOAT)))*100) \n*((SUM(CAST([OK PRODUCTION] AS FLOAT)) / SUM(COALESCE((((CAST([MACHINE SHIFT TIME (X)(Min.)] AS FLOAT)-CAST([AVAILABILITY LOSS TIME(Min.)] AS FLOAT))/(NULLIF(CAST([TOTAL STANDARD CYCLE TIME(Sec.)] AS FLOAT),0)))*60*CAST([PARTS PER CYCLE (U)] AS FLOAT)),0)))*100)\n*((SUM(CAST([OK PRODUCTION] AS FLOAT)) / SUM(CAST([TOTAL PRODUCTION] AS FLOAT)))*100))/10000)\nAS oee\nFROM dbo.SHIFT_DATA \nWHERE \ndatepart(mm,DATE) =month(getdate())   \nAND datepart(yyyy,DATE) =year(getdate()) \n    AND [MACHINE CODE]='M02CN001'\n    OR [MACHINE CODE]='M02CN002'\n    OR [MACHINE CODE]='M02CN003'\n    OR [MACHINE CODE]='M02CN004'\n    OR [MACHINE CODE]='M02CN005'\n    OR [MACHINE CODE]='M02CN006'\n    OR [MACHINE CODE]='M02CN007'\n    OR [MACHINE CODE]='M02CN008'\n    OR [MACHINE CODE]='M02CN009'\n    OR [MACHINE CODE]='M02CN010'\n    OR [MACHINE CODE]='M02CN011'\n    OR [MACHINE CODE]='M02CN012'\n    OR [MACHINE CODE]='M02CN013'\n    OR [MACHINE CODE]='M02HB001'\n    OR [MACHINE CODE]='M02HB002'\n    OR [MACHINE CODE]='M02HB004'\n    OR [MACHINE CODE]='M02HB006'","outField":"payload","x":500,"y":860,"wires":[["78e7f81e.b0a038","a5820e64.dc55c","48ac6140.2c50c","17534980.bcb117","26cbf43b.40eaec","d95f858f.451bb8"]]},{"id":"78e7f81e.b0a038","type":"debug","z":"1f149e22.43a482","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":850,"y":860,"wires":[]},{"id":"5a910858.f025a8","type":"inject","z":"1f149e22.43a482","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":860,"wires":[["e2a56fda.b415","4476fe10.e2765"]]},{"id":"a5820e64.dc55c","type":"ui_gauge","z":"1f149e22.43a482","name":"","group":"1c20b4b1.269adb","order":1,"width":"3","height":"3","gtype":"donut","title":"availability","label":"% age","format":"{{msg.payload[0].availability | number: 0}} %","min":0,"max":"100","colors":["#ff0000","#e6e600","#2ed600"],"seg1":"50","seg2":"70","x":850,"y":700,"wires":[]},{"id":"48ac6140.2c50c","type":"ui_gauge","z":"1f149e22.43a482","name":"","group":"1c20b4b1.269adb","order":1,"width":"3","height":"3","gtype":"donut","title":"performance","label":"% age","format":"{{msg.payload[0].performance | number: 0}} %","min":0,"max":"100","colors":["#ff0000","#e6e600","#2ed600"],"seg1":"50","seg2":"70","x":850,"y":740,"wires":[]},{"id":"17534980.bcb117","type":"ui_gauge","z":"1f149e22.43a482","name":"","group":"1c20b4b1.269adb","order":1,"width":"3","height":"3","gtype":"donut","title":"quality","label":"% age","format":"{{msg.payload[0].quality | number: 0}} %","min":0,"max":"100","colors":["#ff0000","#e6e600","#2ed600"],"seg1":"50","seg2":"70","x":830,"y":780,"wires":[]},{"id":"26cbf43b.40eaec","type":"ui_gauge","z":"1f149e22.43a482","name":"","group":"1c20b4b1.269adb","order":1,"width":"3","height":"3","gtype":"donut","title":"oee","label":"% age","format":"{{msg.payload[0].oee | number: 0}} %","min":0,"max":"100","colors":["#ff0000","#e6e600","#2ed600"],"seg1":"50","seg2":"70","x":830,"y":820,"wires":[]},{"id":"1d1920d3.2a95ef","type":"join","z":"1f149e22.43a482","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":930,"y":940,"wires":[["594910d.0957ef"]]},{"id":"d95f858f.451bb8","type":"function","z":"1f149e22.43a482","name":"","func":"msg.payload.availability=a;\nmsg.topic='availability';\nmsg.payload.performance=b;\nmsg.topic='performance';\nmsg.payload.quality=c;\nmsg.topic='quality';\nmsg.payload.oee=d;\nmsg.tpoic=e;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":920,"wires":[["1d1920d3.2a95ef"]]},{"id":"594910d.0957ef","type":"template","z":"1f149e22.43a482","name":"mail","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Hello! This is an auto generated test mail from Node Red.\n<div>OEE for MT-2's Small Shed from date {{payload.date}} is observed to be {{d}} %</div>\n<div>where</div>\n<div>Availability = {{a}} % </div>\n<div>Performance = {{a}} % </div>\n<div>Quality = {{c}} % </div>","output":"str","x":1050,"y":940,"wires":[["deb014af.7400a8"]]},{"id":"deb014af.7400a8","type":"debug","z":"1f149e22.43a482","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1190,"y":980,"wires":[]},{"id":"898d2a6f.9fb7b8","type":"MSSQL-CN","tdsVersion":"7_3_B","name":"MT02","server":"192.168.21.169\\SCADASQL","port":"1433","encyption":false,"database":"MT02","useUTC":true,"connectTimeout":"15000","requestTimeout":"15000","cancelTimeout":"5000","pool":"5"},{"id":"1c20b4b1.269adb","type":"ui_group","name":"Group 2","tab":"5074feb8.5be66","order":3,"disp":true,"width":6},{"id":"5074feb8.5be66","type":"ui_tab","name":"home","icon":"dashboard","order":13,"disabled":false,"hidden":false}]
I don't want to use multiple function nodes can any one help. Also I'm not able to make the first function node to work as my coding skills are not good.
Hi sahsha,
In future you should probably provide more info on what the issue is and what you are trying to do.
Anyhow, I recognise what you are trying to do so i will explain for future -
To avoid having to use join nodes (where not necessary), instead of branching off to separate paths, put everything in series e.g...
inject ->> Database >> move payload somewhere safe >> convert times >> build mail >> send mail.
As I dont have simpletime node, i just did the from + to dates in the function...
Result...
flow...
[{"id":"34522b81.0f6f24","type":"inject","z":"167a2e98.ad02c1","name":"demo data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"oee\":78.6,\"quality\":94,\"performance\":92,\"availability\":91}]","payloadType":"json","x":840,"y":860,"wires":[["d95f858f.451bb8"]]},{"id":"d95f858f.451bb8","type":"function","z":"167a2e98.ad02c1","name":"add dateStart and dateEnd","func":"//calculate 1st and last day of month\nvar date = new Date(), y = date.getFullYear(), m = date.getMonth();\nvar firstDay = new Date(y, m, 1);\nvar lastDay = new Date(y, m + 1, 0);\n\n//format date to dd-mmm-yyyy\nmsg.dateStart = formatDate(firstDay);\nmsg.dateEnd = formatDate(lastDay);\n\nmsg.payload = msg.payload[0]; //move 1st data row into payload\n\nreturn msg;\n\n\nfunction formatDate(d) {\n    let ye = new Intl.DateTimeFormat('en', { year: 'numeric' }).format(d);\n    let mo = new Intl.DateTimeFormat('en', { month: 'short' }).format(d);\n    let da = new Intl.DateTimeFormat('en', { day: '2-digit' }).format(d);\n    return `${da}-${mo}-${ye}`;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1170,"y":820,"wires":[["594910d.0957ef"]]},{"id":"594910d.0957ef","type":"template","z":"167a2e98.ad02c1","name":"mail","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Hello! This is an auto generated test mail from Node Red.\n<div>OEE for MT-2's Small Shed from '{{dateStart}}' to '{{dateEnd}}' is observed to be {{payload.oee}} %</div>\n<div>where</div>\n<div>Availability = {{payload.availability}} % </div>\n<div>Performance = {{payload.performance}} % </div>\n<div>Quality = {{payload.quality}} % </div>","output":"str","x":1390,"y":820,"wires":[["deb014af.7400a8"]]},{"id":"deb014af.7400a8","type":"debug","z":"167a2e98.ad02c1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1550,"y":820,"wires":[]}]
@Steve-Mcl Thankyou soo much. Will keep in mind to describe the problem briefly.
I also need function node to give date as below, but will try it myself & if I fail then will request for help again :pleading_face:
  1. current date
  2. fiscal year i.e. from 'April 2021' to 'March 2022'.
Here is a function you can use inline (in series)
It adds msg.dates to the msg object (doesn't alter or change other msg properties like payload)
You can access things like msg.dates.thisMonth.start in a function or you can access values in a template like this FY from {{dates.lastFY.start}} to {{dates.lastFY.end}}
here is a demo...
[{"id":"9a4615e5.dbc3f8","type":"inject","z":"45563bb1.635ce4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":540,"y":560,"wires":[["ce281cd5.8b903"]]},{"id":"ce281cd5.8b903","type":"function","z":"45563bb1.635ce4","name":"Get dates","func":"var date = new Date(), y = date.getFullYear(), m = date.getMonth();\nvar aprThisYear = new Date(y, 3, 1);\nvar marNextYear = new Date(y+1, 2, 1);\nvar aprLastYear = new Date(y - 1, 3, 1);\nvar marThisYear = new Date(y, 2, 1);\nvar firstDayOfThisMonth = new Date(y, m, 1);\nvar lastDayOfThisMonth =  new Date(y, m + 1, 0);\nvar firstDayOfLastMonth = new Date(y, m - 1, 1);\nvar lastDayOfLastMonth = new Date(y, m, 0);\n\n\nmsg.dates = {};\n\nmsg.dates.datetime = date;\nmsg.dates.date = formatDateDDMMMYYYY(date);\n\n\nmsg.dates.thisMonth = {\n    start : formatDateDDMMMYYYY(firstDayOfThisMonth),\n    end: formatDateDDMMMYYYY(lastDayOfThisMonth),\n}\n\nmsg.dates.lastMonth = {\n    start: formatDateDDMMMYYYY(firstDayOfLastMonth),\n    end: formatDateDDMMMYYYY(lastDayOfLastMonth),\n}\n\nmsg.dates.thisFY = {\n    start : formatDateMMMMYYYY(aprThisYear),\n    end : formatDateMMMMYYYY(marNextYear)\n}\n\nmsg.dates.lastFY = {\n    start : formatDateMMMMYYYY(aprLastYear),\n    end : formatDateMMMMYYYY(marThisYear)\n}\n\nfunction formatDateMMMMYYYY(d) {\n    let ye = new Intl.DateTimeFormat('en', { year: 'numeric' }).format(d);\n    let mo = new Intl.DateTimeFormat('en', { month: 'long' }).format(d);\n    return `${mo}-${ye}`;\n}\n\nfunction formatDateDDMMMYYYY(d) {\n    let ye = new Intl.DateTimeFormat('en', { year: 'numeric' }).format(d);\n    let mo = new Intl.DateTimeFormat('en', { month: 'short' }).format(d);\n    let da = new Intl.DateTimeFormat('en', { day: '2-digit' }).format(d);\n    return `${da}-${mo}-${ye}`;\n}\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":700,"y":560,"wires":[["44619f3b.d76f4","a3542e90.5052"]]},{"id":"44619f3b.d76f4","type":"debug","z":"45563bb1.635ce4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"dates","targetType":"msg","statusVal":"","statusType":"auto","x":930,"y":560,"wires":[]},{"id":"a3542e90.5052","type":"template","z":"45563bb1.635ce4","name":"demo usage","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Todays date is '{{dates.date}}'\n\nThis FY starts '{{dates.thisFY.start}}' and ends '{{dates.thisFY.end}}'\nLast FY starts '{{dates.lastFY.start}}' and ends '{{dates.lastFY.end}}'\n\nThis month starts '{{dates.thisMonth.start}}' and ends '{{dates.thisMonth.end}}'\nLast month starts '{{dates.lastMonth.start}}' and ends '{{dates.lastMonth.end}}'","output":"str","x":750,"y":640,"wires":[["70110b99.d28b24"]]},{"id":"70110b99.d28b24","type":"debug","z":"45563bb1.635ce4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":640,"wires":[]}]
@Steve-Mcl, Thanks again. couldn't have done it with you.
@Steve-Mcl , one more question if I want to get previous day date. Then am I doing it right?
:grimacing:
check below image
screenshot 6
No. You need to use the date functions...
var yesterday = new Date();
yesterday.setDate(yesterday.getDate() - 1);
@Steve-Mcl Arigatogozaimashita, Sensei .... :pray:
itashimashite
