Or maybe a simple trigger node -
[{"id":"ed12c1bf.3428a","type":"trigger","z":"f86be7c2.1183b8","op1":"","op2":"off","op1type":"nul","op2type":"str","duration":"10","extend":false,"units":"s","reset":"on","bytopic":"all","name":"","x":890,"y":580,"wires":[["a96f1c44.2f153"]]},{"id":"a96f1c44.2f153","type":"debug","z":"f86be7c2.1183b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1090,"y":540,"wires":[]},{"id":"54c827ef.592b08","type":"switch","z":"f86be7c2.1183b8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":870,"y":540,"wires":[["a96f1c44.2f153"]]},{"id":"7a50ec33.2364f4","type":"ui_switch","z":"f86be7c2.1183b8","name":"","label":"switch","tooltip":"","group":"d69449d4.8ad738","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":710,"y":540,"wires":[["54c827ef.592b08","ed12c1bf.3428a"]]},{"id":"d69449d4.8ad738","type":"ui_group","z":"f86be7c2.1183b8","name":"Default","tab":"b5f4b6fa.52a578","order":1,"disp":true,"width":"9","collapse":false},{"id":"b5f4b6fa.52a578","type":"ui_tab","z":"f86be7c2.1183b8","name":"Home","icon":"dashboard","order":1}]
