Msg.reset causes delay node to not delay the next message after the reset
Using the delay node with a fixed amount of time. If the node is delaying a message and I send it a msg.reset the delayed message is 'deleted' like it should be.
But when I sent a new message to the delay node after it has been 'reset' the new message also gets 'deleted'. So the first message after a msg.reset gets dropped, the second message and all the messages after it do get delayed properly.
What am I doing wrong?
That's not what I see.
What version of Node-red and node.js do you have?
After reset, the status blob under the delay node turns to an empty square. Does it go back to solid blue after another inject?
Untitled 1
Thanks you for trying to help out.
I'm running node red under HomeAssistant, node red version 3.0.2.
After your comment I made an empty flow put in just an insert, delay and debug. Now it works like it should so it must be an other mistake in my flow.
It turn solid far a fraction of a second, looks like it gets triggered again. I'm injecting 'on' and 'off' in the flow. But the first inject 'on' after an 'off' also triggers and 'off' on all other nodes.
So now I need to figure out why the inject node is triggering an 'off', might be the switch node, not sure yet.
[{"id":"d4e49684.c7b908","type":"tab","label":"Rook Melders","disabled":false,"info":""},{"id":"54dfd2ff.201bfc","type":"switch","z":"d4e49684.c7b908","name":"On or Off?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":650,"y":40,"wires":[["995563a2.8b24e","b7ed0916.42d458","54c80f1a6a67a1c3","89c307492652ea21"],["b4fb356e.e09888","cd629d57.6e19a","ffaa738d.8dbb6","e3b4ff3e5945987d","e01d9adf99d646a8","8d4c3169126b470e"]]},{"id":"64de7d95.a96bd4","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 11 Keuken","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_keuken_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":240,"wires":[["54dfd2ff.201bfc","132b67a3.dcec28"]]},{"id":"4e8c4ec3.49c84","type":"inject","z":"d4e49684.c7b908","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":110,"y":100,"wires":[["54dfd2ff.201bfc","54c80f1a6a67a1c3"]]},{"id":"33d94071.f1f0d","type":"inject","z":"d4e49684.c7b908","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":110,"y":160,"wires":[["54dfd2ff.201bfc","e01d9adf99d646a8","e3b4ff3e5945987d"]]},{"id":"501f15f9.dad72c","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 12 Kantoor","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_kantoor_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":280,"wires":[["54dfd2ff.201bfc","439c307a.f66fa"]]},{"id":"85adc6d.0e6f338","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 13 Woonkamer","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_woonkamer_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":320,"wires":[["54dfd2ff.201bfc","b8225e.85939da"]]},{"id":"5c292c6b.199c64","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 14 Kelder","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_kelder_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":360,"wires":[["54dfd2ff.201bfc","817ba97.5efa858"]]},{"id":"7439f241.2016dc","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 15 Overloop","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_overloop_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":400,"wires":[["54dfd2ff.201bfc","48dba081.9f9c9"]]},{"id":"b08f7131.8ee6a","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 16 Slaapkamer","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_slaapkamer_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":440,"wires":[["54dfd2ff.201bfc","b391a3e7.07a16"]]},{"id":"3884ddf9.2bf512","type":"server-state-changed","z":"d4e49684.c7b908","name":"Sensor 17 Zolder","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.smoke_sensor_zolder_iaszone","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":true,"ignoreCurrentStateUnavailable":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":480,"wires":[["54dfd2ff.201bfc","8e81d4ec.08d228"]]},{"id":"f14b9e4b.2142e","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Keuken","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Keuken.\", \"message\": \"Rookmelder Keuken Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":600,"wires":[[]]},{"id":"10dc8365.2e52cd","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Kantoor","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Kantoor.\", \"message\": \"Rookmelder Kantoor Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":640,"wires":[[]]},{"id":"5107a1e3.5611e","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Woonkamer","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Woonkamer.\", \"message\": \"Rookmelder Woonkamer Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":900,"y":680,"wires":[[]]},{"id":"9d9bbc48.9413","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Kelder","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Kelder.\", \"message\": \"Rookmelder Kelder Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":880,"y":720,"wires":[[]]},{"id":"3070cf21.d658b","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Overloop","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Overloop.\", \"message\": \"Rookmelder Overloop Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":890,"y":760,"wires":[[]]},{"id":"7d9fcc3c.aefcc4","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Slaapkamer","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Slaapkamer.\", \"message\": \"Rookmelder Slaapkamer Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":900,"y":800,"wires":[[]]},{"id":"5697f35.f30c00c","type":"api-call-service","z":"d4e49684.c7b908","name":"Telefoon Rookmelder Zolder","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"notify","service":"notify","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\": \"Rookmelder Zolder.\", \"message\": \"Rookmelder Zolder Gaat Af!!!\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":880,"y":840,"wires":[[]]},{"id":"b4fb356e.e09888","type":"change","z":"d4e49684.c7b908","name":"Stop Melding","rules":[{"t":"set","p":"payload","pt":"msg","to":"STOP","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":720,"wires":[["439c307a.f66fa","b8225e.85939da","817ba97.5efa858","48dba081.9f9c9","b391a3e7.07a16","8e81d4ec.08d228","132b67a3.dcec28"]]},{"id":"b7ed0916.42d458","type":"api-call-service","z":"d4e49684.c7b908","name":"Buiten Lamp Aan","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.buiten_lamp"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1190,"y":460,"wires":[[]]},{"id":"ffaa738d.8dbb6","type":"api-call-service","z":"d4e49684.c7b908","name":"Buiten Lamp Uit","server":"af3a37e2.d6c9b8","version":3,"debugenabled":false,"service":"turn_off","entityId":"light.buiten_lamp","data":"","dataType":"json","mustacheAltTags":false,"outputProperties":[],"queue":"none","service_domain":"light","mergecontext":"","x":1180,"y":600,"wires":[[]]},{"id":"995563a2.8b24e","type":"api-call-service","z":"d4e49684.c7b908","name":"Hall Lamp Aan Bright","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":[],"entityId":["light.hal_lamp"],"data":"{\"brightness\": 130}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1200,"y":400,"wires":[[]]},{"id":"cd629d57.6e19a","type":"api-call-service","z":"d4e49684.c7b908","name":"Hal Lamp Uit","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.hal_lamp"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1170,"y":540,"wires":[[]]},{"id":"132b67a3.dcec28","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":600,"wires":[["f14b9e4b.2142e"],[]]},{"id":"439c307a.f66fa","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":640,"wires":[["10dc8365.2e52cd"],[]]},{"id":"b8225e.85939da","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":680,"wires":[["5107a1e3.5611e"],[]]},{"id":"817ba97.5efa858","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":720,"wires":[["9d9bbc48.9413"],[]]},{"id":"48dba081.9f9c9","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":760,"wires":[["3070cf21.d658b"],[]]},{"id":"b391a3e7.07a16","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":800,"wires":[["7d9fcc3c.aefcc4"],[]]},{"id":"8e81d4ec.08d228","type":"looptimer","z":"d4e49684.c7b908","duration":"1","units":"Minute","maxloops":"30","maxtimeout":"1","maxtimeoutunits":"Hour","name":"Herhaal Alarm Melding","x":620,"y":840,"wires":[["5697f35.f30c00c"],[]]},{"id":"0f5c71764199a19e","type":"api-call-service","z":"d4e49684.c7b908","name":"Extra Sirene Aan","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"siren","service":"turn_on","areaId":[],"deviceId":["1415022a162c11ebbc14759547a49195","8a625efc138f11eb9878fb779a320497"],"entityId":[],"data":"{\"duration\": 600}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1210,"y":40,"wires":[[]]},{"id":"8d4c3169126b470e","type":"api-call-service","z":"d4e49684.c7b908","name":"Extra Sirene Uit","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"siren","service":"turn_off","areaId":[],"deviceId":["1415022a162c11ebbc14759547a49195","8a625efc138f11eb9878fb779a320497"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1200,"y":120,"wires":[[]]},{"id":"e01d9adf99d646a8","type":"change","z":"d4e49684.c7b908","name":"off naar reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":140,"wires":[["89c307492652ea21"]]},{"id":"c2d2e7530b316f4d","type":"server-state-changed","z":"d4e49684.c7b908","name":"Rook Alarm Via Interface","server":"af3a37e2.d6c9b8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.rook_alarm","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":40,"wires":[["b4fb356e.e09888","e01d9adf99d646a8","8d4c3169126b470e"]]},{"id":"54c80f1a6a67a1c3","type":"api-call-service","z":"d4e49684.c7b908","name":"Lovelace Rook Alarm Switch","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.rook_alarm"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":740,"y":440,"wires":[[]]},{"id":"e3b4ff3e5945987d","type":"api-call-service","z":"d4e49684.c7b908","name":"Lovelace Rook Alarm Switch","server":"af3a37e2.d6c9b8","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.rook_alarm"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":740,"y":480,"wires":[[]]},{"id":"89c307492652ea21","type":"delay","z":"d4e49684.c7b908","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":980,"y":40,"wires":[["2fd8b0ea242dee94"]]},{"id":"2fd8b0ea242dee94","type":"debug","z":"d4e49684.c7b908","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1100,"y":240,"wires":[]},{"id":"af3a37e2.d6c9b8","type":"server","name":"Home Assistant","version":2,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
edit * found my error, was updating the input_boolean that I made to have a button on the HA interface, updating the button to correctly represent the state was retriggering the 'off'
