Delay node behaviour change on reset message
I have been using a delay node for a while to rate limit messages. On a specific event, I send a message msg.reset.
I have just done an update and now when I send the reset message, that message gets sent.
Is this expected behaviour?
  1. how have you got the delay node configured?
  2. What version of NR and you running (see startup log)
  3. Please provide a small test flow showing the issue
I raised this issue,
It has since been fixed, but not sure if its released yet, but its already known (and is fixed in code)
