[{"id":"7d07adf3.860fb4","type":"comment","z":"664a81a4.aeb01","name":"Reading out and controlling heaters with the digital electricity meter","info":"","x":560,"y":40,"wires":[]},{"id":"40072d90.c2ac44","type":"ui_gauge","z":"664a81a4.aeb01","name":"Consumption/Productie","group":"84cb27a7.18e288","order":1,"width":7,"height":3,"gtype":"gage","title":"Consumption/Production electricity","label":"kWatt","format":"{{value}}","min":"-5","max":"5","colors":["#f75959","#0fe600","#10cb26"],"seg1":"-0.1","seg2":"3","x":330,"y":1400,"wires":[]},{"id":"59a92226.a05a4c","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":280,"wires":[["4b77747.038178c"]]},{"id":"d0b89db0.5a7a8","type":"ui_numeric","z":"664a81a4.aeb01","name":"Delta kWatt","label":"Delta kWatt","tooltip":"","group":"f95af1f4.f770f","order":9,"width":"3","height":1,"wrap":false,"passthru":true,"topic":"delta","format":"{{value}}","min":0,"max":"0.5","step":"0.1","x":470,"y":480,"wires":[["59a92226.a05a4c","1b16d3da.ccc98c","94079aab.1fbb78","f1fb8ddc.ee144","e8de599b.d8f258","6ee87bae.868f64"]]},{"id":"f1667af0.fd9d38","type":"tradfri-out","z":"664a81a4.aeb01","name":"Tweede verbruiker","dtype":"device","tradfri_id":"65655","hub":"ae8834b9.079c48","output":true,"x":1610,"y":580,"wires":[]},{"id":"f040d03a.aaef9","type":"ui_text","z":"664a81a4.aeb01","group":"f95af1f4.f770f","order":6,"width":"4","height":1,"name":"Heater1","label":"Heater1 on:","format":"<font color={{msg.color}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"row-left","x":1360,"y":280,"wires":[]},{"id":"249f3654.62768a","type":"function","z":"664a81a4.aeb01","name":"LED","func":"msg.color = (msg.payload === \"on\")?\"lime\":\"red\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1210,"y":280,"wires":[["f040d03a.aaef9"]]},{"id":"c26803e9.9440d","type":"ui_text","z":"664a81a4.aeb01","group":"f95af1f4.f770f","order":7,"width":"4","height":1,"name":"Heater 2","label":"Heater 2 on:","format":"<font color={{msg.color}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"row-left","x":1360,"y":620,"wires":[]},{"id":"2d6dfc6b.ed4174","type":"tradfri-out","z":"664a81a4.aeb01","name":"Eerste verbruiker","dtype":"device","tradfri_id":"65583","hub":"ae8834b9.079c48","output":true,"x":1610,"y":240,"wires":[]},{"id":"1b16d3da.ccc98c","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":240,"wires":[["bca5eb16.011948"]]},{"id":"bca5eb16.011948","type":"function","z":"664a81a4.aeb01","name":"Aan","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\nvar heater01 = msg.payload.heater01;\nvar delta = msg.payload.delta;\n msg.topic = \"heat_1_on\";\nif (E_load >= (heater01 + delta)) {\n \n msg.payload = \"on\";\n return msg;\n}\n\nelse {\n null;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":240,"wires":[["249f3654.62768a","2d6dfc6b.ed4174","eb66bb32.55fa28","a4646c5e.ecc49","3e442766.928058","179b07ae.19ed78"]]},{"id":"4b77747.038178c","type":"function","z":"664a81a4.aeb01","name":"Af","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\n msg.topic = \"heat_1_on\";\nif (E_load <= -0.22) {\n\n msg.payload = \"off\";\n return msg;\n}\nelse;\n{\n null;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":280,"wires":[["249f3654.62768a","2d6dfc6b.ed4174","eb66bb32.55fa28","3e442766.928058","179b07ae.19ed78"]]},{"id":"6ee87bae.868f64","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":620,"wires":[["17ba6d7.47c2693"]]},{"id":"17ba6d7.47c2693","type":"function","z":"664a81a4.aeb01","name":"Af","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\nvar delta = msg.payload.delta;\n msg.topic = \"heat_2_on\";\nif (E_load < -0.18) {\n\n msg.payload = \"off\";\n return msg;\n}\nelse;\n{\n null\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":620,"wires":[["f1667af0.fd9d38","f1fb8ddc.ee144","9145f4e0.2ffa88","85c96bc5.778818","179b07ae.19ed78"]]},{"id":"66cc5613.58ace8","type":"function","z":"664a81a4.aeb01","name":"aan","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\nvar heater02 = msg.payload.heater02;\nvar delta = msg.payload.delta;\nvar heat_1_on = msg.payload.heat_1_on;\n msg.topic = \"heat_2_on\";\nif (E_load >= (heater02 + (delta * 1.3)) && (heat_1_on == \"on\")) {\n\n msg.payload = \"on\";\n return msg;\n}\nelse {\n null;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":580,"wires":[["f1667af0.fd9d38","278864f6.55889c","9145f4e0.2ffa88","85c96bc5.778818","179b07ae.19ed78"]]},{"id":"85c96bc5.778818","type":"function","z":"664a81a4.aeb01","name":"LED","func":"msg.color = (msg.payload === \"on\")?\"lime\":\"red\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1210,"y":620,"wires":[["c26803e9.9440d"]]},{"id":"82115a5b.5b9f78","type":"ui_chart","z":"664a81a4.aeb01","name":"1ste heater 0.8 kWatt","group":"f596e3f5.2093e","order":1,"width":"5","height":"5","label":"1ste heater 0.8 kWatt","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"step","nodata":"","dot":false,"ymin":"0","ymax":"1.5","removeOlder":"8","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1340,"y":320,"wires":[[]]},{"id":"eb66bb32.55fa28","type":"change","z":"664a81a4.aeb01","name":"on = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1170,"y":320,"wires":[["82115a5b.5b9f78"]]},{"id":"15c390fa.52c68f","type":"ui_chart","z":"664a81a4.aeb01","name":"2de heater 0.8 kWatt","group":"f596e3f5.2093e","order":2,"width":"5","height":"5","label":"2de heater 1 kWatt","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"step","nodata":"","dot":false,"ymin":"0","ymax":"1.5","removeOlder":"8","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1340,"y":660,"wires":[[]]},{"id":"9145f4e0.2ffa88","type":"change","z":"664a81a4.aeb01","name":"on = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1170,"y":660,"wires":[["15c390fa.52c68f"]]},{"id":"1053f5f9.1361da","type":"comment","z":"664a81a4.aeb01","name":"Controlling heater 1","info":"","x":810,"y":180,"wires":[]},{"id":"6c19e803.2ef358","type":"comment","z":"664a81a4.aeb01","name":"Controlling heater 2","info":"","x":810,"y":480,"wires":[]},{"id":"94079aab.1fbb78","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":580,"wires":[["66cc5613.58ace8"]]},{"id":"f692345c.b3e458","type":"tradfri-out","z":"664a81a4.aeb01","name":"Derde verbruiker","dtype":"device","tradfri_id":"65577","hub":"ae8834b9.079c48","output":true,"x":1610,"y":840,"wires":[]},{"id":"d3ac9732.6bb4d8","type":"ui_text","z":"664a81a4.aeb01","group":"f95af1f4.f770f","order":8,"width":"4","height":1,"name":"Heater 3","label":"Heater 3 on:","format":"<font color={{msg.color}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"row-left","x":1360,"y":900,"wires":[]},{"id":"e8de599b.d8f258","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":900,"wires":[["137d8a51.0b3566"]]},{"id":"137d8a51.0b3566","type":"function","z":"664a81a4.aeb01","name":"Af","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\nvar delta = msg.payload.delta;\n msg.topic = \"heat_3_on\";\nif (E_load <= -0.1) {\n\n msg.payload = \"off\";\n return msg;\n}\nelse;\n{\n null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":900,"wires":[["f692345c.b3e458","c14a96e7.cabf48","612706d7.5b19e8","179b07ae.19ed78"]]},{"id":"1904a9c6.350b06","type":"function","z":"664a81a4.aeb01","name":"aan","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\nvar heater03= msg.payload.heater03;\nvar delta = msg.payload.delta;\nvar heat_1_on = msg.payload.heat_1_on;\nvar heat_2_on = msg.payload.heat_2_on;\n msg.topic = \"heat_3_on\";\nif (E_load >= (heater03 + (delta * 1.1)) && (heat_1_on === \"on\") && (heat_2_on === \"on\")) {\n\n msg.payload = \"on\";\n return msg;\n}\nelse {\n null;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":860,"wires":[["f692345c.b3e458","612706d7.5b19e8","c14a96e7.cabf48","179b07ae.19ed78"]]},{"id":"612706d7.5b19e8","type":"function","z":"664a81a4.aeb01","name":"LED","func":"msg.color = (msg.payload === \"on\")?\"lime\":\"red\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1210,"y":900,"wires":[["d3ac9732.6bb4d8"]]},{"id":"d2f2956c.096178","type":"ui_chart","z":"664a81a4.aeb01","name":"3de heater 1 kWatt","group":"f596e3f5.2093e","order":3,"width":"5","height":"5","label":"3de heater1 kWatt","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"step","nodata":"","dot":false,"ymin":"0","ymax":"1.5","removeOlder":"8","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1330,"y":940,"wires":[[]]},{"id":"c14a96e7.cabf48","type":"change","z":"664a81a4.aeb01","name":"on = 1","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1150,"y":940,"wires":[["d2f2956c.096178"]]},{"id":"33e7ae41.8b6092","type":"comment","z":"664a81a4.aeb01","name":"Controlling heater 3","info":"","x":810,"y":740,"wires":[]},{"id":"f1fb8ddc.ee144","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":860,"wires":[["1904a9c6.350b06"]]},{"id":"727e13ec.53781c","type":"trigger","z":"664a81a4.aeb01","name":"T 20 sec","op1":"","op2":"on","op1type":"nul","op2type":"str","duration":"20","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":880,"y":520,"wires":[["94079aab.1fbb78"]],"info":"Geeft een 1 door bij inschakelen van heat_on_1 en dit zal niets doen maar na 15 sec geeft de trigger wel een \"on\" door met payload \"heat_on_1\".\nDit om de traagheid van de meting te kunnen compenseren en zodat heat_on_2 niet mee ingaat!!"},{"id":"a4646c5e.ecc49","type":"trigger","z":"664a81a4.aeb01","name":"T 30 sec","op1":"","op2":"on","op1type":"nul","op2type":"str","duration":"30","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":800,"y":780,"wires":[["f1fb8ddc.ee144"]],"info":"Geeft een 1 door bij inschakelen van heat_on_1 en dit zal niets doen maar na 15 sec geeft de trigger wel een \"on\" door met payload \"heat_on_1\".\nDit om de traagheid van de meting te kunnen compenseren en zodat heat_on_3 niet onmiddelijk mee ingaat!!"},{"id":"278864f6.55889c","type":"trigger","z":"664a81a4.aeb01","name":"T15 sec","op1":"","op2":"on","op1type":"nul","op2type":"str","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":800,"y":820,"wires":[["f1fb8ddc.ee144"]],"info":"Geeft een 1 door bij inschakelen van heat_on_2 en dit zal niets doen maar na 15 sec geeft de trigger wel een \"on\" door met payload \"heat_on_1\".\nDit om de traagheid van de meting te kunnen compenseren en zodat heat_on_3 niet onmiddelijk mee ingaat!!"},{"id":"6f5f76ba.0c0cd8","type":"ui_numeric","z":"664a81a4.aeb01","name":"","label":"Heater 1: set in kWatt","tooltip":"","group":"f95af1f4.f770f","order":10,"width":"5","height":"1","wrap":false,"passthru":true,"topic":"heater01","format":"{{value}}","min":0,"max":"2","step":"0.05","x":280,"y":240,"wires":[["1b16d3da.ccc98c"]]},{"id":"f6efb199.a502e","type":"ui_numeric","z":"664a81a4.aeb01","name":"","label":"Heater 2: set in kWatt","tooltip":"","group":"f95af1f4.f770f","order":11,"width":"5","height":"1","wrap":false,"passthru":true,"topic":"heater02","format":"{{value}}","min":0,"max":"2","step":"0.05","x":280,"y":580,"wires":[["94079aab.1fbb78"]]},{"id":"729743d6.dcf8dc","type":"ui_numeric","z":"664a81a4.aeb01","name":"","label":"Heater 3: set in kWatt","tooltip":"","group":"f95af1f4.f770f","order":12,"width":"5","height":"1","wrap":false,"passthru":true,"topic":"heater03","format":"{{value}}","min":0,"max":"2","step":"0.1","x":300,"y":860,"wires":[["f1fb8ddc.ee144"]]},{"id":"9d1fd5ff.b5eac8","type":"ui_chart","z":"664a81a4.aeb01","name":"verbruik/productie","group":"84cb27a7.18e288","order":6,"width":"8","height":"3","label":"Verbruik/productie van -1 kWatt tot 1 kWatt","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"-1","ymax":"1","removeOlder":"8","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#309ce8","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":350,"y":1440,"wires":[[]]},{"id":"5ad2d3a9.be057c","type":"ui_button","z":"664a81a4.aeb01","name":"On","group":"f95af1f4.f770f","order":13,"width":"2","height":"1","passthru":false,"label":"On","tooltip":"","color":"","bgcolor":"","icon":"","payload":"on","payloadType":"str","topic":"","x":1110,"y":120,"wires":[["249f3654.62768a","2d6dfc6b.ed4174"]]},{"id":"b75e413.d81d3c","type":"ui_button","z":"664a81a4.aeb01","name":"On","group":"f95af1f4.f770f","order":17,"width":"2","height":"1","passthru":false,"label":"On","tooltip":"","color":"","bgcolor":"","icon":"","payload":"on","payloadType":"str","topic":"","x":1110,"y":760,"wires":[["f692345c.b3e458","612706d7.5b19e8"]]},{"id":"1b9ba291.55852d","type":"ui_button","z":"664a81a4.aeb01","name":"Off","group":"f95af1f4.f770f","order":14,"width":"2","height":"1","passthru":false,"label":"Off","tooltip":"","color":"","bgcolor":"","icon":"","payload":"off","payloadType":"str","topic":"","x":1110,"y":160,"wires":[["249f3654.62768a","2d6dfc6b.ed4174"]]},{"id":"d523df8b.c5ff1","type":"ui_button","z":"664a81a4.aeb01","name":"Off","group":"f95af1f4.f770f","order":16,"width":"2","height":"1","passthru":false,"label":"Off","tooltip":"","color":"","bgcolor":"","icon":"","payload":"off","payloadType":"str","topic":"","x":1130,"y":500,"wires":[["f1667af0.fd9d38","85c96bc5.778818"]]},{"id":"d13b3c3f.35115","type":"ui_button","z":"664a81a4.aeb01","name":"Off","group":"f95af1f4.f770f","order":18,"width":"2","height":"1","passthru":false,"label":"Off","tooltip":"","color":"","bgcolor":"","icon":"","payload":"off","payloadType":"str","topic":"","x":1110,"y":800,"wires":[["f692345c.b3e458","612706d7.5b19e8"]]},{"id":"10f207d7.f6f938","type":"comment","z":"664a81a4.aeb01","name":"Ikea smart switch 3","info":"","x":1330,"y":820,"wires":[]},{"id":"d1606eec.3cac","type":"comment","z":"664a81a4.aeb01","name":"Ikea smart switch 2","info":"","x":1350,"y":540,"wires":[]},{"id":"463357a1.193fe8","type":"comment","z":"664a81a4.aeb01","name":"Ikea smart switch 1","info":"","x":1350,"y":200,"wires":[]},{"id":"3967d9bf.375b56","type":"mqtt out","z":"664a81a4.aeb01","name":"","topic":"ClientServoKemo_01/Positie","qos":"","retain":"","broker":"e2ed99fb.aa45d8","x":1300,"y":1260,"wires":[]},{"id":"ac7b325f.d59a8","type":"mqtt in","z":"664a81a4.aeb01","name":"Injectie","topic":"p1monitor/smartmeter/production_kw","qos":"0","datatype":"auto","broker":"e2ed99fb.aa45d8","x":210,"y":1220,"wires":[["ca8c81df.c2697"]]},{"id":"26463d67.8ef202","type":"ui_chart","z":"664a81a4.aeb01","name":"","group":"84cb27a7.18e288","order":7,"width":"8","height":"3","label":"Signaal-> Kemo: 0=min, 100=max","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"100","removeOlder":"8","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1280,"y":1360,"wires":[[]]},{"id":"f7c190fc.01f41","type":"PID","z":"664a81a4.aeb01","name":"","setpoint":"0.2","pb":"35","ti":"1","td":"0","integral_default":"1","smooth_factor":"0","max_interval":"60","enable":1,"disabled_op":"0.6","x":730,"y":1280,"wires":[["e0bd5cd1.d1855","29cdb54c.6ad86a"]]},{"id":"7fa5a95c.c532c8","type":"ui_text","z":"664a81a4.aeb01","group":"f95af1f4.f770f","order":2,"width":"5","height":"1","name":"%Output naar PID controller heater Kemo","label":"% Output heater Kemo :","format":"{{msg.payload}}","layout":"row-left","x":1260,"y":1320,"wires":[]},{"id":"e0bd5cd1.d1855","type":"range","z":"664a81a4.aeb01","minin":"0","maxin":"1","minout":"50","maxout":"0","action":"clamp","round":true,"property":"payload","name":"Map pid->Kemo","x":940,"y":1280,"wires":[["3967d9bf.375b56","f753f7cc.abeba8","e2a3e171.fdb17"]]},{"id":"cc3ad2a6.78966","type":"ui_numeric","z":"664a81a4.aeb01","name":"Set max injection","label":"Set max injection in kWatt:","tooltip":"","group":"f95af1f4.f770f","order":5,"width":"6","height":"1","wrap":false,"passthru":true,"topic":"setpoint","format":"{{value}}","min":0,"max":"0.5","step":"0.1","x":430,"y":1160,"wires":[["f7c190fc.01f41"]]},{"id":"1f10a5b.eb33a5a","type":"mqtt in","z":"664a81a4.aeb01","name":"Consumption","topic":"p1monitor/smartmeter/consumption_kw","qos":"2","datatype":"auto","broker":"e2ed99fb.aa45d8","x":230,"y":1340,"wires":[["714eab3f.822d84"]]},{"id":"24bbe3d3.bbffac","type":"function","z":"664a81a4.aeb01","name":"Cons/prod","func":"var injectie = msg.payload[\"p1monitor/smartmeter/production_kw\"];\nvar consumption = msg.payload[\"p1monitor/smartmeter/consumption_kw\"];\nif (injectie > 0) {\n msg.payload = injectie;\n return msg;\n}\n\nelse;\n{\n consumption = consumption *-1;\n msg.payload = consumption;\n return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":1280,"wires":[["40072d90.c2ac44","9d1fd5ff.b5eac8","8996ab21.fa9328"]]},{"id":"ca8c81df.c2697","type":"function","z":"664a81a4.aeb01","name":"str->nr","func":"msg.payload = Number(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":1220,"wires":[["7461619f.d1cba"]]},{"id":"714eab3f.822d84","type":"function","z":"664a81a4.aeb01","name":"Str->nr","func":"msg.payload = Number(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":1340,"wires":[["7461619f.d1cba"]]},{"id":"7461619f.d1cba","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":210,"y":1280,"wires":[["24bbe3d3.bbffac"]]},{"id":"bc435e13.5feea","type":"function","z":"664a81a4.aeb01","name":"Heat extra in","func":"var E_load = msg.payload[\"p1monitor/smartmeter/E_load\"];\nvar kemo = msg.payload.kemo;\n\nvar heat_1_on = msg.payload.heat_1_on;\nvar heat_2_on = msg.payload.heat_2_on;\nvar heat_3_on = msg.payload.heat_3_on;\nif ((kemo === 0) && (E_load >= 0.3))\n{\n if (heat_1_on == \"off\")\n {\n msg.topic = \"heat_extra_01\";\n msg.payload = \"on\";\n return [msg, null, null];\n }\n else if\n (heat_2_on == \"off\")\n {\n msg.topic = \"heat_extra_02\";\n msg.payload = \"on\";\n return [null, msg, null];\n }\n else if \n (heat_3_on == \"off\")\n {\n msg.topic = \"heat_extra_03\";\n msg.payload = \"on\";\n return [null, null, msg];\n }\n}\nelse;\n{\n return null;\n}","outputs":3,"noerr":0,"initialize":"","finalize":"","x":1350,"y":1020,"wires":[["249f3654.62768a","2d6dfc6b.ed4174"],["f1667af0.fd9d38","85c96bc5.778818"],["f692345c.b3e458","612706d7.5b19e8"]]},{"id":"f7d36ee7.3be9e","type":"inject","z":"664a81a4.aeb01","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"num","x":230,"y":1160,"wires":[["cc3ad2a6.78966"]]},{"id":"bc0271b6.da4c6","type":"ui_text","z":"664a81a4.aeb01","group":"f95af1f4.f770f","order":4,"width":"4","height":1,"name":"Heater 4","label":"Heater Kemo on:","format":"<font color={{msg.color}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"row-left","x":1360,"y":1220,"wires":[]},{"id":"ad001103.83fac","type":"function","z":"664a81a4.aeb01","name":"LED","func":"msg.color = (msg.payload === \"on\")?\"lime\":\"red\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1230,"y":1220,"wires":[["bc0271b6.da4c6"]]},{"id":"f753f7cc.abeba8","type":"function","z":"664a81a4.aeb01","name":"","func":"var kemo = msg.payload;\nif (kemo > 0) {\n msg.payload = \"on\";\n return msg;\n}\nelse;\n{\n msg.payload = \"off\";\n return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1100,"y":1220,"wires":[["ad001103.83fac"]]},{"id":"e2a3e171.fdb17","type":"range","z":"664a81a4.aeb01","minin":"0","maxin":"50","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"Map Kemo ->100%","x":950,"y":1340,"wires":[["26463d67.8ef202","7fa5a95c.c532c8"]]},{"id":"dc2074e9.3005d8","type":"comment","z":"664a81a4.aeb01","name":"Kemo power control 4000 KV sturing","info":"","x":300,"y":1100,"wires":[]},{"id":"cd891255.6a27e","type":"comment","z":"664a81a4.aeb01","name":"Map ESP8266","info":"","x":930,"y":1240,"wires":[]},{"id":"5035c40c.f339ac","type":"ui_button","z":"664a81a4.aeb01","name":"On","group":"f95af1f4.f770f","order":15,"width":"2","height":"1","passthru":false,"label":"On","tooltip":"","color":"","bgcolor":"","icon":"","payload":"on","payloadType":"str","topic":"","x":1130,"y":460,"wires":[["f1667af0.fd9d38","85c96bc5.778818"]]},{"id":"7389eb63.5f0824","type":"trigger","z":"664a81a4.aeb01","name":"T on 26 sec","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"26","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":550,"y":560,"wires":[["94079aab.1fbb78"]],"info":"When triggerd, wait x sec and then send the value to the join node to start heaater02.\nwhitout the delay, heater02 wil start at the same moment as heater01. Heater02 may only start when heater01 is in and the injection is decreased with 850 watt."},{"id":"3e442766.928058","type":"function","z":"664a81a4.aeb01","name":"1 x on/off","func":"var payload=msg.payload;\nvar alarm_flag=context.get(\"alarm_flag\");\n\nif(typeof alarm_flag==\"undefined\")\nalarm_flag=false;\nif (payload==\"on\" && !alarm_flag)\n{\n alarm_flag=true;\n msg.alarm=\"on\";\n context.set(\"alarm_flag\",alarm_flag);\n return msg;\n}\nif (payload==\"off\" && alarm_flag)\n{\n alarm_flag=false;\n msg.alarm=\"off\";\n context.set(\"alarm_flag\",alarm_flag);\n return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":740,"y":520,"wires":[["727e13ec.53781c"]]},{"id":"b75d06c6.086d18","type":"trigger","z":"664a81a4.aeb01","name":"T off 25 sec","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"25","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":570,"y":620,"wires":[["6ee87bae.868f64"]],"info":"When triggerd, wait x sec and then send the value to the join node to start heaater02.\nwhitout the delay, heater02 wil start at the same moment as heater01. Heater02 may only start when heater01 is in and the injection is decreased with 850 watt."},{"id":"269796a2.00962a","type":"trigger","z":"664a81a4.aeb01","name":"T off 35 sec","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"35","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":570,"y":280,"wires":[["59a92226.a05a4c"]],"info":"When triggerd, wait x sec and then send the value to the join node to start heaater02.\nwhitout the delay, heater02 wil start at the same moment as heater01. Heater02 may only start when heater01 is in and the injection is decreased with 850 watt."},{"id":"8996ab21.fa9328","type":"change","z":"664a81a4.aeb01","name":"E_load","rules":[{"t":"change","p":"topic","pt":"msg","from":"consumption_kw","fromt":"str","to":"E_load","tot":"str"},{"t":"change","p":"topic","pt":"msg","from":"production_kw","fromt":"str","to":"E_load","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":1280,"wires":[["f1fb8ddc.ee144","f7c190fc.01f41","7389eb63.5f0824","b75d06c6.086d18","269796a2.00962a","c41b91d5.3c3d2","179b07ae.19ed78","d1a451ec.11d22"]]},{"id":"d1a451ec.11d22","type":"trigger","z":"664a81a4.aeb01","name":"T on 8 sec","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"8","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":570,"y":200,"wires":[["1b16d3da.ccc98c"]],"info":"When triggerd, wait x sec and then send the value to the join node to start heaater02.\nwhitout the delay, heater02 wil start at the same moment as heater01. Heater02 may only start when heater01 is in and the injection is decreased with 850 watt."},{"id":"c41b91d5.3c3d2","type":"trigger","z":"664a81a4.aeb01","name":"T off 14 sec","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"14","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":570,"y":900,"wires":[["e8de599b.d8f258"]],"info":"When triggerd, wait x sec and then send the value to the join node to start heaater02.\nwhitout the delay, heater02 wil start at the same moment as heater01. Heater02 may only start when heater01 is in and the injection is decreased with 850 watt."},{"id":"179b07ae.19ed78","type":"join","z":"664a81a4.aeb01","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1170,"y":1020,"wires":[["bc435e13.5feea"]]},{"id":"29cdb54c.6ad86a","type":"function","z":"664a81a4.aeb01","name":"","func":"msg.topic = \"kemo\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":740,"y":1340,"wires":[["179b07ae.19ed78"]]},{"id":"84cb27a7.18e288","type":"ui_group","name":"Consumption and Procution of electricity in kWatt","tab":"16694e6c.5ee9e2","order":1,"disp":true,"width":"16","collapse":true},{"id":"f95af1f4.f770f","type":"ui_group","name":"Overview recuperation of electricity in heat","tab":"16694e6c.5ee9e2","order":2,"disp":true,"width":"16","collapse":true},{"id":"ae8834b9.079c48","type":"tradfri-config","name":"Gateway","hubip":"192.168.1.31","sid":"UGmbXswPjpqHn9iT","coap":"/home/pi/.node-red/node_modules/node-tradfri-argon/lib/coap-client-raspbian","identity":"R0BoUAGsbHc7U","preshared_key":"MvgthsFe2a2JdqWh"},{"id":"f596e3f5.2093e","type":"ui_group","name":"Logging of recuperation electricity to heat","tab":"16694e6c.5ee9e2","order":3,"disp":true,"width":"16","collapse":true},{"id":"e2ed99fb.aa45d8","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"16694e6c.5ee9e2","type":"ui_tab","name":"De Voecht","icon":"Zonneboiler","disabled":false,"hidden":false}]
