Hello All
I have this following conundrum
Consider that I have the following flow variable
and the following function node
Tudo =flow.get('firstFloorState');
delete Tudo["temp.guest"];
delete Tudo["temp.girl"];
delete Tudo["temp.master"];
delete Tudo["temp.boy"];
delete Tudo["temp.sala"];
delete Tudo["temp.ext"]
msg.payload=Tudo
now my Flow variables are
Should this function without any flow set, alter the variables?
PS:
I am using the V19.2
Thank you
Yes - it isn't ideal, but its how its always worked. The 'get' is returning a reference to the object in memory. The delete operates on that object, so modifies the object in context.
But you have to be careful. If you're using a persistent context, rather than in-memory, if you don't do the 'flow.set' call, the updates to the object will not be saved.
Understood
Is there another way around way to accomplish the removal of the object?
JLG
If you mean you want to retrieve the context value and only pass on certain properties, you can either:
clone the context object so you can modify it in place
var Tudo = RED.util.cloneMessage(flow.get('firstFloorState'));
delete Tudo['temp.guest'];
delete ...
create a new object locally and copy in the values you do want
var Tudo = flow.get('firstFloorState');
msg.payload = {
"Luz.Master": Tudo['Luz.Master'],
