Hi.
Has anyone had success with Moes/Smart Knob button setup with Node Red? It seems Z2M is accepting 4 actions: single press, double press, long press and rotate (left/right).
I'm not been able to work with it and I'd be thankful if anyone has some example.
Thanks.
What's not working? What did you tried yourself?
The first thing you need to find out on what topic zigbee2mqtt is publishing the messages from this knob.
If you know that it's simple to add a mqtt node to NR. Add a debug node to it and see what happens.
