Hello, anybody know how to disable dropdown UI? For example, grayout the dropdow when a trigger comes and just release it when the trigger out. We have enable feature with button, switch but no with dropdown
Welcome to the forum
Is that the old node-red-dashboard (which is now deprecated) or the new @flowfuse/node-red-dashboard?
It is old dashboard. 1.0 Colin
To grey it out you should be able to send msg.enabled false, then true to enable.
It worked, thank you a lot E1cid.
