Display array data in table one by one
There is a great example for that, so I will ask my question based on this example.
https://flows.nodered.org/flow/76cd6afbd14426f88656c90aedf10423
How can I display data in three td ?
I mean instead
{{item}}
to have one td for first element of array, then one td for second one, and so on..
thanks
I'm not clear on what you are asking. If you run the code from that flow you will see this:
The sample data is built into an array in the function node.
Note: this was built on dashboard 1
I want to have 3 x td not only one for every line. Basically i want each array entry into a variable
I'm not sure what you mean, can you sketch up what it should look like in a table?
In the table looks the same, but:
instead have
 <td ng-repeat="item in row" >{{item}}</td>
I want something like
 <td ng-repeat="item in row" >{{item.name}}</td>
 <td ng-repeat="item in row" >{{item.surname}}</td>
 <td ng-repeat="item in row" >{{item.age}}</td>
Basically I want "Paul" , "Doe" and "24" like 3 different variables, not like one array line.
This would lead me to believe you array is an array of objects not a 2d array
Please supply your data to save any confusion.
Try
<td ng-repeat="(key, item) in row">{{item}}</td>
key would hold the property names name, surname, age.
My data is a result of a select from db
let nr_teste = msg.payload.length;
let arhiva_array = [];
for (let i = 0; i < nr_teste; i++) {
    arhiva_array[i] = [
            msg.payload[i].id,
            msg.payload[i].data_test,
            msg.payload[i].inspector,
            msg.payload[i].nr_inmatriculare,
            msg.payload[i].REZULTAT
msg.payload = arhiva_array;
and in table i have
 <tr ng-repeat="row in msg.payload">
        <td ng-repeat="item in row">{{item}}</td>
My goal is to make id on each line as link and do something when click on it
Thank you
Please create some dummy data that would go into the function node and paste it to a reply.
Thinking about it, I think this might be what you are looking for, a display like this:
and in this case, the IP address can be clicked and it links to the Node-RED site on that IP address.
This is what the template looks like:
<div id="et_home">
<h2 style="text-align: center;">PyPI Display Home </h2>
<p style="text-align: center;">List of Raspberry Pi's found on your LAN<p>
<p style="text-align: center;">Click on a 'Hostname' will get you details of that device<p>
<p style="text-align: center;">Click on a 'IP' will attempt to open Node-RED on that Pi<p>
<br/>
<table id="table" border="1">
    <tr>
        <th>Hostname</th>
        <th>User</th>
        <th>IP</th>
        <th>Last Seen</th>
        <th>Model</th>
        <th>OS</th>
        <th>Disk Used</th>
        <th>Temperature</th>
    </tr>
    <tbody style="text-align: center">
        <tr ng-repeat="x in msg.payload">
            <td ng-if="x.device_status ==  'database is empty'" class="warning_red" >DATABASE IS EMPTY</td>
            <td ng-if='x.device_status ==  1' class="device_online" style="text-align: left">
                <md-button ng-click="send({host: x.hostname})">{{x.hostname}}</md-button>
            </td>
            <td ng-if='x.device_status ==  0' class="device_offline" style="text-align: left">
            </td>
            <td ng-if='x.device_status ==  1' class="device_online"  >{{x.user}} </td>
            <td ng-if='x.device_status ==  0' class="device_offline" >{{x.user}} </td>
            <td ng-if='x.device_status ==  1' class="device_online" ><a href="http://{{x.hostname}}.local:1880" target="_blank"> {{x.ip}} </a></td>
            <td ng-if='x.device_status ==  0' class="device_offline" ><a href="http://{{x.hostname}}.local:1880" target="_blank"> {{x.ip}} </a></td>
            <td ng-if='x.device_status ==  1' class="device_online"  >{{x.last_seen_text}} </td>
            <td ng-if='x.device_status ==  0' class="device_offline" >{{x.last_seen_text}} </td>
            <td ng-if='x.device_status ==  1' class="device_online"  >{{x.model}} </td>
            <td ng-if='x.device_status ==  0' class="device_offline" >{{x.model}} </td>
            <td ng-if='x.device_status ==  1' class="device_online"  >{{x.osrelease}} </td>
            <td ng-if='x.device_status ==  0' class="device_offline" >{{x.osrelease}} </td>
            <td ng-if='x.device_status ==  1' class="device_online"  >{{x.disk_percentused}} </td>
            <td ng-if='x.device_status ==  0' class="device_offline" >{{x.disk_percentused}} </td>
            <td ng-if='x.device_status ==  1' class="device_online"  >{{x.temperature}} </td>
            <td ng-if='x.device_status ==  0' class="device_offline" >{{x.temperature}} </td>
         </tr>
    </tbody>
</table>
</div>
and here is the data being sent to the template node:
[{"disk_percentused":"3%","last_seen":1733507594190,"ip":"192.168.1.3","model":"Pi 4 Model B Rev 1.4","osrelease":"buster","temperature":42.8,"uptime":"up 1 week, 4 days, 7 hours, 10 minutes","user":"pi","hostname":"argonpi","device_status":1,"last_seen_text":"12/6/2024, 12:53:14 PM"},{"disk_percentused":"16%","last_seen":1733507594243,"ip":"192.168.1.173","model":"Pi 3 Model B Plus Rev 1.3","osrelease":"buster","temperature":49.4,"uptime":"up 11 weeks, 2 days, 3 hours, 19 minutes","user":"pi","hostname":"fastpi","device_status":1,"last_seen_text":"12/6/2024, 12:53:14 PM"},{"disk_percentused":"7%","last_seen":1733507595452,"ip":"192.168.1.228","model":"Pi Zero W Rev 1.1","osrelease":"buster","temperature":33.6,"uptime":"up 1 week, 4 days, 6 hours, 35 minutes","user":"pi","hostname":"mqttpizw","device_status":1,"last_seen_text":"12/6/2024, 12:53:15 PM"},{"disk_percentused":"15%","last_seen":1733507594113,"ip":"192.168.1.233","model":"Pi 4 Model B Rev 1.2","osrelease":"bullseye","temperature":49.1,"uptime":"up 2 weeks, 8 hours, 52 minutes","user":"pmw","hostname":"superpi","device_status":1,"last_seen_text":"12/6/2024, 12:53:14 PM"},{"disk_percentused":"48%","last_seen":1732683964253,"ip":"192.168.1.174","model":"Pi 3 Model B Rev 1.2","osrelease":"bullseye","temperature":49.9,"uptime":"up 6 days, 3 hours, 55 minutes","user":"pmw","hostname":"testpi","device_status":0,"last_seen_text":"11/27/2024, 12:06:04 AM"},{"disk_percentused":"19%","last_seen":1728391239124,"ip":"192.168.1.175","model":"Pi 3 Model B Rev 1.2","osrelease":"buster","temperature":49.9,"uptime":"up 2 weeks, 5 days, 22 hours, 7 minutes","user":"pi","hostname":"yellowpi","device_status":0,"last_seen_text":"10/8/2024, 8:40:39 AM"}]
This is from my pypi-info project GitHub - juggledad/pypi-info: Python program to run cmds sent via MQTT and return results
This is my msg.payload , which is a result of a selection of 4 rows from db
[[40,"2024-10-11T07:25:03.000Z","nume111 prenume1","GR20BIS","ADMIS"],[39,"2024-10-09T04:23:59.000Z","nume111 prenume1","nr_inm0","ADMIS"],[38,"2024-09-08T07:28:24.000Z","nume111 prenume1","nr_inm0","ADMIS"],[37,"2024-10-08T07:28:24.000Z","nume111 prenume1","nr_inm0","ADMIS"]]
<div id="et_home">
<br/>
    <tr>
        <th>Hostname</th>
        <th>User</th>
        <th>IP</th>
        <th>Last Seen</th>
        <th>Model</th>
        <th>OS</th>
        <th>Disk Used</th>
    </tr>
            </td>
            </td>
         </tr>
    </tbody>
</table>
</div>
Note one thing, this runs on dashboard 1. I haven't looked at changing it for dashboard 2 yet.
Is a very intersting example, but your data format looks different than mine ...
thanks anyway, i will see maybe can adapt something
The difference is that I have an array of objects and you have an array of arrays. By using the objects it makes it easy to see what each item is.
