Hello, I'm working on a weather forcast dashboard and I'm wondering if I can display the names of days and months in another language than English, French in my case
{{msg.payload | date:"EEE, d MMMM yyyy"}}
in this case I want it to be Dim, 17 Mars 2019. How can I get to that ?!
You can try my node-red-contrib-moment node.
These setttings for example:
Give you this output
Thank you, it worked but still need the name of the day though
That's not a problem, you just need to adjust the output format. If you check the help in the sidebar, it gives a link to the page that gives you all of the details you need.
Thanks a lot, it worked by using this format ddd DD MMM YYYY
