Displaying a list of Numbers from an array of objects
good day
I have the problem when outputting from a json The output payload looks like this:
"{{msg.payload.value[0].callerNumber}}"
This works fine so far. But I have a dynamic number as value. So not only 0 or 1 or 2 etc. but it is about a phone log history. I.e. I read the log from teams and there are more than only one number which should be read. This array also grows and I will still include that you can enter a date range, so there will be more output.
How can I include that all values of, in this example "Caller Number" are output in a list?
So there are no solution for this?
Of course there is always a solution however I personally skipped this one because I could not really see what you wanted?
You ask in the #general category (meaning its NOT a #dashboard thing) with a title "Number setting in json output" (which suggests you want to set values in some json) ask how you can get "Caller Number" output in a list (does that mean on a dashboard? in an array? in msg.payload only?)
Maybe if you showed sample data and explained exactly where and how you want it to appear?
I apologize for the late reply and putting the wrong forum group.
It looks like this:
I get the call logs via the MS api for teams
Reading a number works. But the JSON always contains more than one number because I want to read the history of a day and display it in a list.
grafik
So how can I display them in a list?
OK, now it makes more sense.
I have updated the category and the title to attract the kind of guys who can help with these type of questions.
If this were my dashboard, I would simply install node-red-node-ui-table and display the list in tabular format.
grafik
Thanks for the tip with the ui table. I think this is exactly what I need. Only I still do not know how I can display all numbers (on this day there are 19 entries) Can unfortunately not include an array there instead of the number, otherwise I would have simply created an array from this number and this then included there.
So how can I have all the values (in this case 19 pieces) read out?
Thanks for your help
You get 1 entry because you set the payload to 1 entry of the array.
Try passing the FULL array to payload...
msg.payload = msg.payload.value
return msg
If necessary, you could filter out the extra properties in the array entries using map e.g...
msg.payload = msg.payload.value.map(e => {
  return {
    callerNumber: e.callerNumber
return msg
Ah i understand. Thank you for your great help.
Now it works realy good
