Do not write columns if there is no data
Hello Community
I generate a pdf-file with node-red. Inside this dokument i work with columns. Now my question: Can I write a script that won't write the column if there is no data?
	{text: 'Heizung', style: 'header', decoration: 'underline'},
		    columns: [
		            type: 'none',
		            ul: [
		                {text: 'Zählerart', fontSize: 8},
		                {text: 'Wärmezähler'}
		            type: 'none',
		            ul: [
		                {text: 'Zähler-ID', fontSize: 8},
		                {text: global.get("0x_0x_we_id")}
		            type: 'none',
		            ul: [
		                {text: 'Zählerstand alt', fontSize: 8},
		                {text: global.get("0x_0x_we_alt")+' '+'kWh'}
                    type: 'none',
                    ul:  [
                        {text: 'Zählerstand neu', fontSize: 8},
                        {text: global.get("0x_0x_we_neu")+' '+'kWh'}
                    type: 'none',
                    ul: [
                        {text: 'Differenz', fontSize: 8},
                        {text: global.get("0x_0x_we_diff")+' '+'kWh'}
If there is no data in "0x_0x_we_id" or it's " = 0" then the column should nod be written...
Thanks for your answers!
CU Mauri
I have had to make assumptions of your object as it is a section and not a complete object.
I would create a column list and use that to create the columns, I would set up your initial object and leave columns empty, I would the push the items from column list if they pass conditionals.
e.g.
[{"id":"93318f82.625168","type":"inject","z":"bf9e1e33.030598","name":"1","props":[{"p":"global_context","v":"1","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":2080,"wires":[["5159e2e6.9ec724"]]},{"id":"5159e2e6.9ec724","type":"function","z":"bf9e1e33.030598","name":"","func":"column_list = [\n    {\"type\": \"none\", \"text\": [\"Zählerart\",\"Wärmezähler\"],\"fontSize\":8},\n    {\"type\": \"none\", \"text\": [\"Zähler-ID\",msg.global_context],\"fontSize\":8} // any context or var could be used here\n];\n\nmsg.payload = [{text: 'Heizung', style: 'header', decoration: 'underline'},\n\t{\n\t\tcolumns: []\n\t}\n];\ncolumn_list.forEach(obj => {\n    if(obj.text[1]){\n        msg.payload[1].columns.push({\n            type: obj.type,\n\t\t    ul: [\n\t\t        {text: obj.text[0], fontSize: obj.fontSize},\n\t\t        {text: obj.text[1]}\n            ]\n\t    })\n    }\n});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":2080,"wires":[["7dae4206.4a76f4"]]},{"id":"fa8a79c0.7b1ea8","type":"inject","z":"bf9e1e33.030598","name":"0","props":[{"p":"global_context","v":"0","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":2120,"wires":[["5159e2e6.9ec724"]]},{"id":"7dae4206.4a76f4","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":620,"y":2080,"wires":[]}]
column_list = [
    {"type": "none", "text": ["Zählerart","Wärmezähler"],"fontSize":8},
    {"type": "none", "text": ["Zähler-ID",msg.global_context],"fontSize":8} // any context or var could be used here
		columns: []
    if(obj.text[1]){
            type: obj.type,
		    ul: [
		        {text: obj.text[1]}
The full code is to big to show all, but you can show it in this txt file
        "id": "85cf28dd7d884341",
        "type": "function",
        "z": "0df7cbc7b280fbe5",
        "name": "Abrechnung erstellen",
        "func": "var dd = {\n\tcontent: [\n\t\t{text: global.get(\"00_00_name_owner\")},\n\t\t{text: global.get(\"00_00_adr_owner\")},\n\t\t{text: global.get(\"00_00_plz_owner\") + \" \" + global.get(\"00_00_ort_owner\")},\n\t\t{\n\t\t\tcolumns: [\n\t\t\t\t{\n\t\t\t\t\tul: [\n\t\t\t\t\t\t\n\t\t\t\t\t]\n\t\t\t\t},\n\t\t\t\t{\n\t\t\t\t\tul: [\n\t\t\t\t\t\t\n\t\t\t\t\t]\n\t\t\t\t},\n\t\t\t\t{\n\t\t\t\t    type: 'none',\n\t\t\t\t\tol:[\n\t\t\t\t\t\tglobal.get(\"00_00_allg_datum\"),\n\t\t\t\t\t\t{text: ' '},\n\t\t\t\t\t\tglobal.get(\"0x_0x_whg_bez\"),\n\t\t\t\t\t\t{text: global.get(\"0x_0x_name_mieter\"), style: 'header'},\n\t\t\t\t\t\tglobal.get(\"0x_00_adr_objekt\"),\n\t\t\t\t\t\tglobal.get(\"0x_00_plz_objekt\") + \" \" + global.get(\"0x_00_ort_objekt\")\n\t\t\t\t\t]\n\t\t\t\t}\n\t\t\t]\n\t\t},\n\t\t{text: ' '},\n\t\t{text: 'Zeitraum von' + \" \" + global.get(\"00_00_zr_start\")+ \" \" + 'bis' + \" \"  + global.get(\"00_00_zr_ende\"), style: 'header', decoration: 'underline', fontSize: 15},\n\t\t{text: \" \"},\n\t\t{text: \" \"},\n\t\t{text: 'Ihre Abrechnung', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Ihre Gesamtkosten', decoration: 'underline'},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text:'CHF'+' '+ global.get(\"0x_0x_kosten_mieter\"), decoration: 'underline'}\n                    ]\n\t\t        }\n            ]\n\t\t},\n\t\t{text: \" \"},\n\t\t{text: \" \"},\n\t\t{text: \" \"},\n\t\t\n\t\t{text: 'Ihre Ablese- und Verbrauchswerte', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Zählerart', fontSize: 10, style: 'header'},\n\t\t                {text: 'Wärmezähler', fontSize: 8},\n\t\t                {text: 'Warmwasserzähler', fontSize: 8},\n\t\t                {text: 'Kaltwasserzähler', fontSize: 8},\n\t\t                {text: 'Strom', fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Zähler-ID', fontSize: 10, style:'header'},\n\t\t                {text: global.get(\"0x_0x_we_id\"), fontSize: 8},\n\t\t                {text: global.get(\"0x_0x_ww_id\"), fontSize: 8},\n\t\t                {text: global.get(\"0x_0x_kw_id\"), fontSize: 8},\n\t\t                {text: global.get(\"0x_0x_el_id\"), fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Zählerstand alt', fontSize: 10, style:'header'},\n\t\t                {text: global.get(\"0x_0x_we_alt\")+' '+ 'kWh', fontSize: 8},\n\t\t                {text: global.get(\"0x_0x_ww_alt\")+' '+'m³', fontSize: 8},\n\t\t                {text: global.get(\"0x_0x_kw_alt\")+' '+'m³', fontSize: 8},\n\t\t                {text: global.get(\"0x_0x_el_alt\")+' '+ 'kWh', fontSize: 8},\n                    ]\n\t\t        },\n                {\n                    type: 'none',\n                    ul:  [\n                        {text: 'Zählerstand neu', fontSize: 10, style:'header'},\n                        {text: global.get(\"0x_0x_we_neu\")+' '+ 'kWh', fontSize: 8},\n                        {text: global.get(\"0x_0x_ww_neu\")+' '+'m³', fontSize: 8},\n                        {text: global.get(\"0x_0x_kw_neu\")+' '+'m³', fontSize: 8},\n                        {text: global.get(\"0x_0x_el_neu\")+' '+ 'kWh', fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: 'Differenz', fontSize: 10, style:'header'},\n                        {text: global.get(\"0x_0x_we_diff\")+' '+ 'kWh', fontSize: 8},\n                        {text: global.get(\"0x_0x_ww_diff\")+' '+'m³', fontSize: 8},\n                        {text: global.get(\"0x_0x_kw_diff\")+' '+'m³', fontSize: 8},\n                        {text: global.get(\"0x_0x_el_diff\")+' '+ 'kWh', fontSize: 8},\n                    ]\n                }\n\t\t        \n            ]\n\t\t},\n\t\t\n\t\t{text: \" \"},\n\t\t{text: 'Aufstellung Wärmekosten', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', fontSize: 10, style: 'header'},\n\t\t                {text: ' ', fontSize: 8},\n\t\t                {text: ' ', fontSize: 8},\n\t\t                {text: 'Ermittlung der Heizkosten', fontSize: 8},\n\t\t                {text: 'Kosten Heizung', fontSize: 8},\n\t\t                {text: 'Anteil WW-Erwärmung -', fontSize: 8},\n\t\t                {text: 'Anteil Heizkosten =', fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', fontSize: 10, style: 'header'},\n\t\t                {text: 'Kosten Heizanlage :', fontSize: 10, style: 'header'},\n\t\t                {text:'CHF'+' '+ global.get(\"0x_00_chf_wp\"), fontSize: 8, decoration: 'underline'},\n\t\t                {text: ' ', fontSize: 8},\n\t\t                {text: ' ', fontSize: 8},\n\t\t                {text:'CHF'+' '+ global.get(\"0x_00_chf_wp\"), fontSize: 8},\n\t\t                {text:'CHF'+' '+ global.get(\"0x_00_chf_ww\"), fontSize: 8},\n\t\t                {text:'CHF'+' '+ global.get(\"0x_00_chf_we\"), fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', fontSize: 10, style: 'header'},\n\t\t                {text: 'Gesamtwärme x', fontSize: 10, style: 'header'},\n\t\t                {text: global.get(\"0x_00_el_wp\")+' '+'kWh', fontSize: 8, decoration: 'underline'},\n\t\t                {text: ' ', fontSize: 8},\n\t\t                {text: ' ', fontSize: 8},\n                    ]\n\t\t        },\n                {\n                    type: 'none',\n                    ul:  [\n                        {text: 'Wärmemenge für Warmwasser =', fontSize: 10, style: 'header'},\n                        {text: global.get(\"0x_00_we_ww\")+' '+'kWh', fontSize: 8, decoration: 'underline'},\n                        {text: ' ', fontSize: 8},\n                        {text: ' ', fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: 'Anteil an WW von Gesamtheizkosten', fontSize: 10, style: 'header'},\n                        {text: 'CHF'+' '+ global.get(\"0x_00_chf_ww\"), fontSize: 8, decoration: 'underline'},\n                        {text: ' ', fontSize: 8},\n                        {text: ' ', fontSize: 8}\n                    ]\n                }\n\t\t        \n            ]\n\t\t},\n\t\t{text: \" \"},\n\t\t{text: 'Aufteilung der Heizkosten', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Kostenart', style: 'header', fontSize: 10},\n\t\t                {text: 'Heizkosten', fontSize: 8},\n\t\t                {text: 'davon', fontSize: 8},\n\t\t                {text: global.get(\"0x_00_gkhz_pz\")+'%' + ' ' + 'GK Heizung', fontSize: 8},\n\t\t                {text: global.get(\"0x_00_vkhz_pz\")+'%' + ' ' + 'VK Heizung', fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Gesamtbetrag :', style: 'header', fontSize: 10},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_chf_we\"), fontSize: 8},\n\t\t                {text: \" \", fontSize: 8},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_gk_hz\"), fontSize: 8},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_vk_hz\"), fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Gesamteinheit Gebäude =', style: 'header', fontSize: 10},\n\t\t                {text: \" \", fontSize: 8 },\n\t\t                {text: \" \", fontSize: 8},\n\t\t                {text: global.get(\"0x_00_m2_tot\")+\" \"+'m²', fontSize: 8},\n\t\t                {text: global.get(\"0x_00_we_hz\")+' ' + 'kWh', fontSize: 8},\n                    ]\n\t\t        },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: 'Betrag pro Einheit x', style: 'header', fontSize: 10},\n                        {text: \" \", fontSize: 8},\n                        {text: \" \", fontSize: 8},\n                        {text: global.get(\"0x_00_einh_gkhz\"), fontSize: 8},\n                        {text: global.get(\"0x_00_einh_vkhz\"), fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header',fontSize: 10},\n                        {text: 'Ihre Einheiten =', style: 'header', fontSize: 10},\n                        {text: ' ', fontSize: 8},\n                        {text: ' ', fontSize: 8},\n                        {text: global.get(\"0x_0x_m2_mieter\")+\" \"+'m²', fontSize: 8},\n                        {text: global.get(\"0x_0x_we_diff\")+' ' + 'kWh', fontSize: 8},\n                        {text: \"Total:\", fontSize: 8, style: 'header'},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header',fontSize: 10},\n                        {text: 'Ihr Kostenanteil', style: 'header', fontSize:10},\n                        {text:' ', fontSize: 8},\n                        {text:' ', fontSize: 8},\n                        {text: 'CHF'+' '+ global.get(\"0x_0x_gkhz_mieter\"), fontSize: 8}, \n                        {text: 'CHF'+' '+ global.get(\"0x_0x_vkhz_mieter\"), fontSize: 8}, \n                        {text: 'CHF'+' '+ global.get(\"0x_0x_we_kosten\"), style: 'header', fontSize: 8},\n                    ]\n                },\n            \n           ]\n\t\t},\n\t\t\t\t{text: \" \"},\n\t\t{text: 'Aufteilung der Warmwasserkosten', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Kostenart', style: 'header', fontSize: 10},\n\t\t                {text: 'WW-Kosten', fontSize: 8},\n\t\t                {text: 'davon', fontSize: 8},\n\t\t                {text: global.get(\"0x_00_gkww_pz\")+'%' + ' ' + 'GK WW', fontSize: 8},\n\t\t                {text: global.get(\"0x_00_vkww_pz\")+'%' + ' ' + 'VK WW', fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Gesamtbetrag :', style: 'header', fontSize: 10},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_chf_ww\"), fontSize: 8},\n\t\t                {text: \" \", fontSize: 8},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_gk_ww\"), fontSize: 8},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_vk_ww\"), fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Gesamteinheit Gebäude =', style: 'header', fontSize: 10},\n\t\t                {text: \" \", fontSize: 8 },\n\t\t                {text: \" \", fontSize: 8},\n\t\t                {text: global.get(\"0x_00_m2_tot\")+\" \"+'m²', fontSize: 8},\n\t\t                {text: global.get(\"0x_00_we_ww\")+' ' + 'kWh', fontSize: 8},\n                    ]\n\t\t        },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: 'Betrag pro Einheit x', style: 'header', fontSize: 10},\n                        {text: \" \", fontSize: 8},\n                        {text: \" \", fontSize: 8},\n                        {text: global.get(\"0x_00_einh_gkww\"), fontSize: 8},\n                        {text: global.get(\"0x_00_einh_vkww\"), fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header',fontSize: 10},\n                        {text: 'Ihre Einheiten =', style: 'header', fontSize: 10},\n                        {text: ' ', fontSize: 8},\n                        {text: ' ', fontSize: 8},\n                        {text: global.get(\"0x_0x_m2_mieter\")+\" \"+'m²', fontSize: 8},\n                        {text: global.get(\"0x_0x_ww_diff\")+' ' + 'kWh', fontSize: 8},\n                        {text: \"Total:\", fontSize: 8, style: 'header'},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header',fontSize: 10},\n                        {text: 'Ihr Kostenanteil', style: 'header', fontSize:10},\n                        {text:' ', fontSize: 8},\n                        {text:' ', fontSize: 8},\n                        {text: 'CHF'+' '+ global.get(\"0x_0x_gkww_mieter\"), fontSize: 8}, \n                        {text: 'CHF'+' '+ global.get(\"0x_0x_vkww_mieter\"), fontSize: 8}, \n                        {text: 'CHF'+' '+ global.get(\"0x_0x_ww_kosten\"), style: 'header', fontSize: 8},\n                    ]\n                },\n            \n           ]\n\t\t},\n\t\n\t\t{text: \" \"},\n\t\t{text: 'Aufstellung Wasserkosten', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Kostenart', style: 'header', fontSize: 10},\n\t\t                {text: 'Frischwasser', fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Gesamtbetrag :', style: 'header', fontSize: 10},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_wsk_ges\"), fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Gesamteinheit Gebäude =', style: 'header', fontSize: 10},\n\t\t                {text: global.get(\"0x_00_ws_ges\")+\" \"+'m³', fontSize: 8},\n                    ]\n\t\t        },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: 'Betrag pro Einheit x', style: 'header', fontSize: 10},\n                        {text: global.get(\"0x_00_einh_ws\"), fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header', fontSize: 10},\n                        {text: 'Ihre Einheiten =', style: 'header', fontSize: 10},\n                        {text: global.get(\"0x_0x_ws_ges\")+\" \"+'m³', fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header', fontSize: 10},\n                        {text: 'Ihr Kostenanteil', style: 'header', fontSize: 10},\n                        {text: 'CHF'+' '+ global.get(\"0x_0x_wk_mieter\"), style: 'header', fontSize: 8},\n                    ]\n                },\n\t\t        \n            ]\n\t\t},\n\t\t{text: \" \"},\n\t\t{text: 'Aufstellung Stromkosten', style: 'header', decoration: 'underline'},\n\t\t{\n\t\t    columns: [\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Kostenart', style: 'header', fontSize: 10},\n\t\t                {text: 'Strom', fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: ' ', style: 'header',fontSize: 10},\n\t\t                {text: 'Gesamtbetrag :', style: 'header', fontSize: 10},\n\t\t                {text: 'CHF'+' '+ global.get(\"0x_00_elk_bez\"), fontSize: 8},\n                    ]\n\t\t        },\n\t\t        {\n\t\t            type: 'none',\n\t\t            ul: [\n\t\t                {text: 'Gesamteinheit Gebäude =', style: 'header', fontSize: 10},\n\t\t                {text: global.get(\"0x_00_el_bez\")+' ' + 'kWh', fontSize: 8},\n                    ]\n\t\t        },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: 'Betrag pro Einheit x', style: 'header', fontSize: 10},\n                        {text: global.get(\"0x_00_tarif_mt\"), fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header', fontSize: 10},\n                        {text: 'Ihre Einheiten =', style: 'header', fontSize: 10},\n                        {text: global.get(\"0x_0x_el_diff\")+' ' + 'kWh', fontSize: 8},\n                    ]\n                },\n                {\n                    type: 'none',\n                    ul: [\n                        {text: ' ', style: 'header', fontSize: 10},\n                        {text: 'Ihr Kostenanteil', style: 'header', fontSize: 10},\n                        {text: 'CHF'+' '+ global.get(\"0x_0x_sk_mieter\"), style: 'header', fontSize: 8,},\n                    ]\n                },\n\t\t        \n            ]\n\t\t},\n\t],\n\tstyles: {\n\t    header: {\n\t        bold: true,\n\t        fontSize: 12\n\t    }\n\t},\n\tdeafultStyle: {\n\t    fontSize: 12\n\t}\n}\n\n\n\n\nmsg.payload = dd;\n\nconst saveplace = global.get(\"0x_00_pdf_speicherort\")\nconst reportName = global.get(\"00_00_zr_start\") + \" \" + global.get(\"00_00_zr_ende\") +\" \"+ global.get(\"0x_0x_name_mieter\")\nmsg.filename =`${saveplace}${reportName}.pdf`\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 960,
        "y": 2400,
                "cf21d173d24640c3"
Always if the global variable "...._id" is == 0 then the full column should not be written... You know what i mean?
Do you mean the full columns array or the columns element/index.
you may need to supply an copy of the object as it would appear if all id's are present, and a copy of how it should appear if a id is equal to 0. As I am not 100% sure what you mean.
I think I mean the full columns array....
Ok, if all ID's are present, the object look like this:
{"content":[{"text":"CFM Automation"},{"text":"Wiesenstrasse 26"},{"text":"5400 Baden"},{"columns":[{"ul":[]},{"ul":[]},{"type":"none","ol":["31.12.2021",{"text":" "},"EG mitte",{"text":"Maurus Andreas Streiff","style":"header"},"Farnsburgerstrasse 37","4466 Ormalingen"]}]},{"text":" "},{"text":"Zeitraum von 01.01.2021 bis 31.12.2021","style":"header","decoration":"underline","fontSize":15},{"text":" "},{"text":"Heizung","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Wärmezähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":0}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"10519.4 Wh"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"10550.4 Wh"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"31 Wh"}]}]},{"text":" "},{"text":"Strom","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Elektrozähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":7890123456}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"49324.2 Wh"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"49241.2 Wh"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"-18223 Wh"}]}]},{"text":" "},{"text":"Warmwasser","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Durchflusszähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":791038230}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"122.1 m³"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"152.22 m³"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"30.12 m³"}]}]},{"text":" "},{"text":"Kaltwasser","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Durchflusszähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":619816740}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"173.62 m³"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"211.34 m³"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"37.72 m³"}]}]}],"styles":{"header":{"bold":true,"fontSize":12}},"deafultStyle":{"fontSize":12}}
Per example the ID from the heat counter does not exist, the object should look like following code:
{"content":[{"text":"CFM Automation"},{"text":"Wiesenstrasse 26"},{"text":"5400 Baden"},{"columns":[{"ul":[]},{"ul":[]},{"type":"none","ol":["31.12.2021",{"text":" "},"EG mitte",{"text":"Maurus Andreas Streiff","style":"header"},"Farnsburgerstrasse 37","4466 Ormalingen"]}]},{"text":" "},{"text":"Zeitraum von 01.01.2021 bis 31.12.2021","style":"header","decoration":"underline","fontSize":15},{"text":" "},{"text":" "},{"text":"Strom","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Elektrozähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":7890123456}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"49324.2 Wh"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"49241.2 Wh"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"-18223 Wh"}]}]},{"text":" "},{"text":"Warmwasser","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Durchflusszähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":791038230}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"122.1 m³"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"152.22 m³"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"30.12 m³"}]}]},{"text":" "},{"text":"Kaltwasser","style":"header","decoration":"underline"},{"columns":[{"type":"none","ul":[{"text":"Zählerart","fontSize":8},{"text":"Durchflusszähler"}]},{"type":"none","ul":[{"text":"Zähler-ID","fontSize":8},{"text":619816740}]},{"type":"none","ul":[{"text":"Zählerstand alt","fontSize":8},{"text":"173.62 m³"}]},{"type":"none","ul":[{"text":"Zählerstand neu","fontSize":8},{"text":"211.34 m³"}]},{"type":"none","ul":[{"text":"Differenz","fontSize":8},{"text":"37.72 m³"}]}]}],"styles":{"header":{"bold":true,"fontSize":12}},"deafultStyle":{"fontSize":12}}
I hope you undterstand what I mean... If it help, i can generate a pdf with both ways. Maybe you can unterstand better then...
thx
I may not understand, but try something like this
create your dd.content array but leave it empty.
Then you can push values if conditions are met.
The below examples shows how if msg.payload.id2 is missing that section is not pushed.
[{"id":"90a53194.dec4b","type":"inject","z":"30af2d3e.d94ea2","name":"","props":[{"p":"payload.id1","v":"1","vt":"num"},{"p":"payload.id2","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":200,"y":960,"wires":[["58cd8c4a.324c1c"]]},{"id":"7b8feab7.0e19ac","type":"inject","z":"30af2d3e.d94ea2","name":"","props":[{"p":"payload.id1","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"str","x":210,"y":1000,"wires":[["58cd8c4a.324c1c"]]},{"id":"58cd8c4a.324c1c","type":"function","z":"30af2d3e.d94ea2","name":"Abrechnung erstellen","func":"var dd = {\n\tcontent: [\n\t\t],\n\tstyles: {\n\t    header: {\n\t        bold: true,\n\t        fontSize: 12\n\t    }\n\t},\n\tdeafultStyle: {\n\t    fontSize: 12\n\t}\n}\nif (msg.payload.id1){\n    \tdd.content.push({text: global.get(\"00_00_name_owner\")});\n\t\tdd.content.push({text: global.get(\"00_00_adr_owner\")});\n\t\tdd.content.push({text: global.get(\"00_00_plz_owner\") + \" \" + global.get(\"00_00_ort_owner\")},\n    \t\t{\n    \t\t\tcolumns: [\n    \t\t\t\t{\n\t    \t\t\t\tul: [\n\t    \t\t\t\t]\n\t\t    \t\t},\n\t\t\t    \t{\n\t\t\t\t    \tul: [\n    \t\t\t\t\t]\n    \t\t\t\t},\n    \t\t\t\t{\n    \t\t\t\t    type: 'none',\n    \t\t\t\t\tol:[\n    \t\t\t\t\t\tglobal.get(\"00_00_allg_datum\"),\n    \t\t\t\t\t\t{text: ' '},\n    \t\t\t\t\t\tglobal.get(\"0x_0x_whg_bez\"),\n    \t\t\t\t\t\t{text: global.get(\"0x_0x_name_mieter\"), style: 'header'},\n    \t\t\t\t\t\tglobal.get(\"0x_00_adr_objekt\"),\n    \t\t\t\t\t\tglobal.get(\"0x_00_plz_objekt\") + \" \" + global.get(\"0x_00_ort_objekt\")\n    \t\t\t\t\t]\n    \t\t\t\t}\n    \t\t\t]\n    \t\t});\n}\nif(msg.payload.id2){\n    \tdd.content.push({text: ' '});\n\t\tdd.content.push({text: 'Zeitraum von' + \" \" + global.get(\"00_00_zr_start\")+ \" \" + 'bis' + \" \"  + global.get(\"00_00_zr_ende\"), style: 'header', decoration: 'underline', fontSize: 15});\n\t\tdd.content.push({text: \" \"});\n\t\tdd.content.push({text: \" \"});\n\t\tdd.content.push({text: 'Ihre Abrechnung', style: 'header', decoration: 'underline'},\n\t\t    {\n\t\t        columns: [\n\t\t            {\n\t\t                type: 'none',\n\t    \t            ul: [\n\t    \t                {text: 'Ihre Gesamtkosten', decoration: 'underline'},\n                        ]\n\t    \t        },\n\t    \t        {\n\t    \t            type: 'none',\n\t    \t            ul: [\n                       ]\n\t\t            },\n\t\t            {\n\t\t                type: 'none',\n\t\t                ul: [\n\t\t                    {text:'CHF'+' '+ global.get(\"0x_0x_kosten_mieter\"), decoration: 'underline'}\n                        ]\n\t    \t        }\n                ]\n\t    \t}); \n}\n\t\n\nmsg.payload = dd;\n\nconst saveplace = global.get(\"0x_00_pdf_speicherort\")\nconst reportName = global.get(\"00_00_zr_start\") + \" \" + global.get(\"00_00_zr_ende\") +\" \"+ global.get(\"0x_0x_name_mieter\")\nmsg.filename =`${saveplace}${reportName}.pdf`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":940,"wires":[["c75be667.e7b968"]]},{"id":"c75be667.e7b968","type":"debug","z":"30af2d3e.d94ea2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":840,"wires":[]}]
I used payload.id2 etc rather than context just for example, as i do not have your data or context store. Alter as needed.
