As of this Problem I changed my docker-compose to take the Dockerfile instead of directly nodered/node-red:latest and added a RUN in to my Dockerfile to add a package, but that fails because of Permissions denied.
What do I have to do, to install an aditional package in the same container as node-red?
docker-compose.yaml:
version: "3.7"
services:
node-red:
build:
context: .
dockerfile: Dockerfile
environment:
- 'TZ=Europe/Zurich'
- 'NODE_ENV=production'
network_mode: host
ports:
- '1880:1880'
volumes:
- 'node-red-data:/data'
restart: 'always'
volumes:
node-red-data:
Dockerfile:
FROM nodered/node-red:latest
RUN apk update \
apk add avahi
output:
$ docker-compose up
Building node-red
Step 1/2 : FROM nodered/node-red:latest
---> db209923532e
Step 2/2 : RUN apk update apk add avahi
---> Running in bf2b984ce393
ERROR: Unable to lock database: Permission denied
ERROR: Failed to open apk database: Permission denied
ERROR: Service 'node-red' failed to build : The command '/bin/sh -c apk update apk add avahi' returned a non-zero code: 99
