Hello!
I would like to click on a button on the dashboard that would then trigger a flow and then download the file as a buffer.
How do I do this best?
Does anyone have a tip for me?
Thanks in advance.
Hello!
Thanks in advance.
You need to serve the file and then the client (browser) needs to request it.
To serve a file you can add a static entry in settings.js or you can use a pair of HTTP-IN ~ HTTP-Response nodes to create an endpoint.
Here is such an example to give you ideas: Download a file from node-red using standard nodes (flow) - Node-RED
How to do it?
And how will it work?
See httpStatic in Configuration : Node-RED
Also, covered many times on the forum
Thank you very much.
Sorry for asking a banal question - I just didn't know what it was called yet httpStatic !
I'm going to study it now.
Maybe you will have a little time to answer a question near to this topic as a creator:
A solution has appeared:
