Download and rename file
Hi iam able to download file(document) or photo from telegram but it saves as file_(number+)[example : file_5] is their any way to rename or save the file or photo with the name we want.. i want to keep replacing on the existing file soo having same filename could be useful
code i use to download documents
if (msg.payload.type === 'document'){
    msg.payload.download = {
        fileId: msg.originalMessage.document.file_id,
        filePath: "/config/tmp/)"
How are you saving it?
What version of Node-RED are you using?
What node (full name please - i.e. node-red-contrib-??????) are you using?
Put a debug node - set ti display the complete msg object - on the output of the telegram node and expand it all and copy and paste it's information.
and export and pastine your flow would be helpful too.
Im using node-red-contrib-telegrambot to receive files to nodered from telegram
Im using nodered inside homeassistant as addon
NR verison: 13.4.0
im able to download and save file locally but it saves with name file_1 or file_2
Instead i want to save file with my own name .
Not being a home assistant user, you might be better served asking on a homeassistant forum
@zenofmud no issue thanks for responding.. one small doubt:
how do i join two numbers together
say i want to join 77 and 99 together and look like 7799?
they both are numbers ...should i first change them to sting to get this work?
there may be more than one way to do it. I would do as below.
[{"id":"565838c7796500b7","type":"inject","z":"a1ac2470d38f86ae","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":320,"wires":[["63d4fc10d17300af"]]},{"id":"63d4fc10d17300af","type":"change","z":"a1ac2470d38f86ae","name":"","rules":[{"t":"set","p":"payload1","pt":"msg","to":"77","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":320,"wires":[["9287144ac76e7e86"]]},{"id":"9287144ac76e7e86","type":"change","z":"a1ac2470d38f86ae","name":"","rules":[{"t":"set","p":"payload2","pt":"msg","to":"99","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":320,"wires":[["a16fc10379116f22"]]},{"id":"a16fc10379116f22","type":"change","z":"a1ac2470d38f86ae","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload1&payload2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":320,"wires":[["c9e2039bd6797d4f"]]},{"id":"c9e2039bd6797d4f","type":"debug","z":"a1ac2470d38f86ae","name":"debug 55","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":960,"y":320,"wires":[]},{"id":"d2a0ef194a20a6ea","type":"inject","z":"a1ac2470d38f86ae","name":"","props":[{"p":"payload2","v":"99","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"two","x":250,"y":200,"wires":[["91519fde8037d4f7"]]},{"id":"92cba9bc15051242","type":"inject","z":"a1ac2470d38f86ae","name":"","props":[{"p":"payload1","v":"77","vt":"num"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"one","x":250,"y":120,"wires":[["91519fde8037d4f7"]]},{"id":"91519fde8037d4f7","type":"join","z":"a1ac2470d38f86ae","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":450,"y":140,"wires":[["8f98676c9c460e19"]]},{"id":"8f98676c9c460e19","type":"change","z":"a1ac2470d38f86ae","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload1&payload2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":140,"wires":[["6842ace0db2ede15"]]},{"id":"6842ace0db2ede15","type":"debug","z":"a1ac2470d38f86ae","name":"debug 54","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":820,"y":140,"wires":[]}]
if you use the web request you can do it directly, if you use the function block you have to rename the file after downloading it
