Downloading pdf file from internet
Maybe anyone can help me with this problem.
I am trying to download a pdf file from a web address and store it on RPI. THis file is not secured, I think. I can normally download it my self from the web. But If I download the file, it seems it is empty.
I am confused. Here is the flow.
[{"id":"85a8308c80750364","type":"http request","z":"70e5f74f5e9b1992","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"https://www.lampiris.be/sites/default/files/pricesgrids/current/tarif_tip_elec_fla_nl_-_resi.pdf","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":520,"y":1540,"wires":[["eecd1c36ce19a5da"]]},{"id":"f7f56ac39d0a067e","type":"inject","z":"70e5f74f5e9b1992","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":340,"y":1540,"wires":[["85a8308c80750364"]]},{"id":"f37ad39bdf1d2694","type":"debug","z":"70e5f74f5e9b1992","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":1480,"wires":[]},{"id":"3c3e0504195ec439","type":"file","z":"70e5f74f5e9b1992","name":"Lampiris file","filename":"","appendNewline":false,"createDir":true,"overwriteFile":"true","x":870,"y":1540,"wires":[[]]},{"id":"eecd1c36ce19a5da","type":"function","z":"70e5f74f5e9b1992","name":"","func":"let folder = global.get('file.lampiris_folder');\nlet file = \"Lampiris_tarif_\" + Date().toString() + \".pdf\";\n\nmsg.filename = folder + file;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":700,"y":1540,"wires":[["3c3e0504195ec439","f37ad39bdf1d2694"]]}]
Check the output of the function node, particularly the filename. I think you might want
(new Date()).toString()
I don't know whether UTF8 string is the correct output format for the html node. It might be better as a binary buffer.
@Colin As always, you're right. Thanks very much for the help again !!!
If only that were true.
Did you have to change it to a buffer?
Yes, indeed, @Colin , it is working perfectly now. As you might have seen, I needed that file to get elctricity tarifs from my distributor so I can update costprice in order to calculate energy costs. That's working now. Thanks!!!
greetings.
